Question about Haier BC112G Wine Cooler
Wine cooler ( model HVF060ABL) runs continuously
Does shut off when reaching set temp. Happened several month ago - I vacuum rear of cooler and plugged it back in and it operated fine ( for several months) and same problem returned. Back of unit is quite clean. Suspect it was the moving that may have jarred a citical connection in the sensor or control board that fixed it in the past. But that isn't doing it this time. Can I assume the likely culprit is in the control board rather than the sensor ( where is that) ? Any advice on diagnosing to identify source of problem ?
  • 10,515 Answers
Hi sig2,
 Whenever such sitaution arises, whether its runs continouslyor sometimes even not working.....There is only one defect - Circuit board.
Either repair it, if you are aware of it...check voltage and continuity ....If you find any blown diodes or capacitors - replace them...........
There are millions of connections in a board , so it's not so easy to catch each and every aspect...but still try to fix it...
If not, either call a tech to check what's wrong......get an estimate of the repair...and then decide whether to buy a new one or want to repair the existing one....
You can also search for used circuit board on
http://www.ebay.com
Any further help, let me know.
Thanks for using Fixya.
Do rate the solution.
Posted on Apr 16, 2009
My beverage cooler MCBC58DST wont stay cool after it reaches target temp.
Throw it out and get another model from another company. Their units are junk!
They last a year, at best. Them and Magic Chef are one and the same...so you may have to bite the bullet and get a real unit.
Good luck. I speak from experience...I've had four now. Complete junk!!
Nov 23, 2014 | Vissani 5.8 cu. ft. Wine and Beverage...
Why is our EuroCave DUO wine cooler model D264 freezing 1/4 inch of ice on back wall inside cooler?
Most cases of ice build up can be traced to seals that leak humid air into the cooler. Check the door seal carefully using a fresh $1 bill. The bill should not pull out easily when the door is closed. If the unit has a self defrost feature it it is not coming on. Ice buildup inside a wine cooler is very rare. The cooler box should not reach 32deg in normal operation. Does the unit seem to run continuously?
Sep 10, 2014 | Furniture
Vinotemp wine cooler just stop working.
Ok check the power supply input. Assume you have do e that and all ok. More than likely it could be a thermostat or compressor gas leakage. Has the compressor been running more than usual before it gave up working. Check for rust on the internal coils as sometimes they fail. Depending on what you paid for the wine cooler it may be cheaper to simply replace it. Can highly recommend Delongi 145
litre bar fridge, after replacing several cheaper brands and it is very reliable and cools really well though they are not at the cheap end of the market. You get what you pay for with appliances. Best of luck resolving the problem but if the wine cooler no longer is getting cold but the compressor continues to run, you can bet that it's out if gas from a leak in the internal pipe work and generally not worth attempting to either locate and or repair.
Apr 28, 2014 | VinoTemp (VT60GNV) Wine Cooler
Danby DWC2727BLS temperature does not go lower than 60 degrees
am having the same problem, and same circumstance. Did you find a solution?
Jun 11, 2012 | Danby Silhouette® DWC276BLS Wine Cooler
My wine cooler will not run at all. The compressor is Ok. The cooler uses relay 41006036 rev E. I do get continuity on both the pot and the thermistor. What is the correct resistance for the thermistor...
Hi
Please check this link to read detailed information related to wine cooler as per your query:-
http://www.winecoolerexpert.com/wine-cooler-faq.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 05, 2011 | Marvel (6SBARBSG) Wine Cooler
As I can improve the yield of refrigeration of the digging, it is already difficult to maintain the indicated temperature
Here is the breakdown on this machine by temperature - it only works optimally in a room that is 68-70 degrees, which is a little on the cold side:
to actually reach 7 degrees Celsius, the room temp must be 68 degrees Farenheit or below
to reach 9 C, room must be 70 F or below
to reach 11 C, room must be 72 F or below
ETC...
all problems with this wine cellar will be aggravated during the summer months
Jul 22, 2009 | Cuisinart Private Reserve CWC-900 Wine...
I have a magic chef wine cooler (Model MCWC50DBT) and the labels keep falling off of the bottles. The temperature is set to red and we don't seem to have any other problems.
All the wine chiller set 2 temp red and white, red wine temp only for 18- 20 oC , your using white wine don't set red wine temp , set only for white temp mode,white and red wine set temp are different temp
May 27, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Danby Wine cooler runs and runs
not hard to replace but you are correct if it is not cycling off at the temp you want it to then the temp control is the problem
Apr 12, 2008 | Danby DWC283BLS Wine Cooler
Marvel 61WC Wine Cooler
sorry for the delay in response time you definatly have a bad thermistor, not able to stabilze temp so it contionues run never shutting doen freezing everything, who ever repairs it (if they haven already,)make sure they put all 3 new peices in, thermistor, potentiometer, and contol box. all 3 come in one kit, 20 min to install
Dec 02, 2007 | Marvel 61WC Wine Cooler
Haier BC112G Wine Cooler Logo
67 people viewed this question
Top Haier Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
jasbo
jasbo
Are you a Haier Furniture Expert? Answer questions, earn points and help others
