Question about Neff T2346 Gas Cooktop
Trying to get hold of a fitting instruction leaflet plus list of spare parts for a gas hob code no. E4NE T2484SOEU/01
Why do you need a fitting manual ? Any competent gas engineer should know the contents of BS6172 / BS6891 which both apply to the fitting of domestic gas cookers / hobs. What spares do you need. You can get a spares inventory from Neff. Ensure that it is the correct appliance for the fuel gas you are connecting to. The jet sizes for LPG & Natural Gas are very different.
Posted on Apr 16, 2009
Flame leaking under lower ring. Common?
no it is a problem with the hob
consider this
as it is a rental property it is the responsibility of the land lord to get a gas fitter in to fix / replace the problem
If you do not ask him to fix it , if there is a problem and the thing explodes, catches fire or gases some one to death, there is every possibility that he will try to blame you for not reporting it
if he refuses to fix it or tries to fix it himself then I would advise that you seek alternative rental accommodation as the problem is for an accredited gas fitter and not a landlord.
Sep 23, 2015 | Smeg 23 in. SE64 Gas Cooktop
I have acquired a Rosiers hob with 3 gas rings and 1 electric, but 2 of the gas fittings are missing is there any chance of getting new ones . I think the model is the Tologne The rings are the med and...
hello there, the model name does not match any of our documents or any documents online. Please check your unit for the model number to enable us get the parts list to determine the part number. The gas rings are usually available for sale although most of the time gas rings from other makes would fit but lets see if we can get the exact ones for your unit. Please furnish me with the model number.
Hoping to hear from you soon.
Thank you for visiting FixYa.
Aug 06, 2011 | Cooktops
Want a narrow ceramic cook top / hob
Look at Baumatic 90cm Slimline 4 Hyperspeed Zone Ceramic Hob. Dimensions are 350mm x 880mm
Apr 26, 2010 | DeLonghi Cooktops
Gas injectors
well it is aproblem with the gas pressure u should get it checkded
Jul 22, 2009 | Cooktops
No gas to hobs
use mactches for ur gas burner if the ignition not really work.put all gas in off position b4 cleaning by using a vacium in the place of the control knob,turn off the power b4 try to clean,tnx
Nov 24, 2008 | Dacor Preference SGM466 Gas Cooktop
Gas Hob Flame
Hello
Tha sounds to me like the air mixture nedds to be adjusted on the stove, It's not difficult to do, just rotate it until the flames loose the yellow or your pans will be stained with soot.
The should be by the fittings (convertion fittings), you know?
LP Gas to Natural Gas or Natural Gas to LP Gas.
Hope this help
Eddie Rentas
Tupper Lake NY
Jul 30, 2008 | Cooktops
Operating manual
Hello
To get a manual for that stove go to this link:
http://www.technika.com.au/
I hope that help...Good luck
Eddie Rentas
Tupper Lake NY
Jul 18, 2008 | Tecnik Cooktops
Converting gas hob to electric hob
If you are in the USA most codes require a seperate circuit for the oven and the cooktop. Most cooktops require 30 amps and at least #10 wire.
Jun 09, 2008 | Cooktops
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Neff T2346 Gas Cooktop Logo
506 people viewed this question
Top Neff Cooktops Experts
Jim London
Jim London
Samyfam
Samyfam
ray gallant
Are you a Neff Cooktop Expert? Answer questions, earn points and help others
