Question about Maytag MDB9600A Jetclean II Built-in Dishwasher
Detergent dispenser My dishwasher is a Maytag jetclean series 01, model # VU304, serial # 218223 . The dish degertent dispenser won't flip open. I am not sure when it is supposed to do so during the wash, so I go ahead and flip it open manually during the final wash (when I remember to do so). Hope this is an easy fix@ Thanks loads
  • droth878 Apr 19, 2009
    Same problem soap dish doesn't always open; nothing blocking it from the inside
  • 1462 Answers
SOURCE: Maytag Jetclean Super Quite Plus II Dishwasher
open the door when working and check the spray arms are rotating. if not, the jets in the spray arms may be blocked. very fiddly to clear but doable
Posted on Apr 09, 2007
  • 76 Answers
SOURCE: maytag mjd 2005dishwasher
Try what my wife does. She uses the individually contained detergent/rinse bubble packs (tab packs). No messy granular detergent and easy to simply place inside the silverware basket. Your dishes should wash spotless, like ours. ZT3000 "Beta tester of "0"s and "1's"
Posted on Aug 19, 2007
  • 172 Answers
SOURCE: My Maytag dishwasher does not drain water after the wash cycle is over
Hi olabrk,
If you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump. Good luck to you.
Mike Anderson
Posted on Oct 30, 2008
  • 10865 Answers
SOURCE: soap dispenser doesn't open
My recommendation is to switch over to a tablet and merely put the tablet on the floor of the dishwasher bypassing the soap holder all together. It should work just fine that way. good luck.
Posted on Jan 27, 2009
rickzilla
  • 706 Answers
SOURCE: Dishes not getting clean, white film
Hello cljjtm,
You will need to clean the wash arm and unclog the spray holes.. use white vinegar to break down the soap deposit and a sharp metal tool such as an awl to free these holes up from any build up.. white vinegar may be applied while unclogging the openings..
Then, once the spray arm holes are freed of deposits..Start with an empty dishwasher.. and then start a wash on the hottest available setting and then after a few minutes of it cycling.. pause it and add a cup or two of white vinegar to the wash ( the white vinegar should break down any soap residue and allow it to be rinsed away)..once complete.. use about 1/3 less detergent than you have been. See if that gets your DW back in working order.. Hope that helps..
Regards,
Rick
Posted on Feb 16, 2009
My office's GE QuietPower 3 dishwasher detergent
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Jul 29, 2011 | Maytag Dishwasher
Hi. My problem is with my dishwasher detergent dispenser. It does open (at least it is open at completion of cleaning cycle), appears to deliver soap to dishes (as they appear clean), however, from the...
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
heatman101
Feb 14, 2011 | Maytag MDBH985AWB / MDBH985AWS 24 in....
I have a 13 year old Maytag that works great. But recently the flipper door that dispences the dry detergent doesn't open during the wash cycle. I've tried cleaning it thoroughly, but that hasn't made a...
heatman101
Sep 17, 2010 | Maytag 24 in. MDB6600A Jetclean II...
Dishes not coming out clean
heatman101
Apr 10, 2010 | Maytag 24 in. MDB8750AWS Jetclean II...
Maytag dishwasher soap dispenser won't open durning wash
Just put a soap tablet in the cutlery basket. Normally after a couple of washes the dish will start working again
Apr 02, 2009 | Maytag MDB9600A Jetclean II Built-in...
Soap dispenser doesn't open
Dec 29, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
KitchenAid dishwasher soap door won't open
I took the door apart and found the degertent door solinoid looking like it over heated and melted to the cover flap and the insulation. See picture. I can't post pic as the max is 150kb.
I applied power and it only got hot and wouldn't operate.
Next I go to Kitchenaid for a replacement - FREE it should be.
Oct 07, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwasher
detergent dispenser solenoid
May 10, 2007 | Maytag 24 in. MDB8600AWS Jetclean II...
Maytag MDB9600A Jetclean II Built-in Dishwasher Logo
61 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
