Question about LG KU990 Viewty
LG View Wont Turn on, stuck on start up screen.
I was downloading files to my computer via USB, I disconnected from my LG, however when I pulled the USB out of my computer the phone turned of. Now what happens it just keeps on blinking at the start up and the call butons only flash, as if the phone is only coming on and off but nothing else is happening. When I take out the battery it turns of and when I put it back and try to turn it back on it's the same problem. When I try to charge it it comes on and does the same thing. I dont even see the charging screen. It does nothing but just flash as if its coming on then off. Please help me. I am in Trinidad and I hope I dont have to ship this product to an LG service center. Thanks
  • 4 more comments
  • stunew60 Apr 18, 2009
    same problem with KU990
  • Anonymous Apr 21, 2009
    my lg viewty keeps showing the lg logo and it just keeps flashing on and off.
  • markandeleri Apr 22, 2009
    i have the same problem with a LG KC910 Renoir, after only 1/2 hour of having
    the phone. It appeared after i put my memory card in.
  • Anonymous Apr 22, 2009
    i have the same problem with a LG KC910 Renoir, after only 1/2 hour of having the phone. It appeared after i put my memory card in.
  • hlalchan Apr 29, 2009
    I find this to be very helpful. Will let you know if it works.
  • Anonymous May 05, 2009
    I have this exact same problem. This morning it was working fine, my alarm wen off and woke me up. One hour later as I was checking the time I noticed the screen with just the LG symbol. I can't think of what the problem could be, I left it on charger over night and I do that almost every night so maybe I have over charged it, if that is possible. I have already had 2 problems with my LG viewty so I am taking it to a 3 shop and they will give me a new phone.
There may be a problem with the charger, as this is what happened to me. If you bought the phone abroad and only received a 2-pin charger, it means that this has messed up the data on your phone. Because the chargers abroad can only hold up to 120volt, so if you have  plugged it into a shaver socket or into a two-pin converter which gives you a 3-pin, it will still mess up your phone. I recommend you take it to a shop to fix. It cost me £25 to fix, but it's working fine now.
Posted on Apr 28, 2009
How do i bypass screen lock on my lg-m153?
Here is a simple method on how to unlock LG phone screen lock. For this method, you need to download the Android SDK and install it on your computer. This method will only work if you have previously activated USB debugging in your phone's developer menu and also if you have connected your LG phone to connect to your computer via ADB.
1.Start by downloading the Android SDK from http://developer.android.com/sdk/index.html#Other .
2.Connect your phone to the computer via USB.
Go to the folder where you have installed the ADB.
4.Hold 'shift' and right click on the ADB folder and select "open command window here". This will launch the command prompt.
5.You have to enter the command here to unlock your screen. The command is "adb shell rm /data/system/gesture.key". After entering the command press enter.
6.Now all you have to do is disconnect your phone and reboot. You will have complete access to your phone. Make sure you set a new code as soon as you switch it on, the old password will be restored when the phone reboots again unless you set a new one.
Mar 12, 2018 | Cell Phones
I was charging my lg phone on my laptop so i decide tu download some music i unplugged the phone and then plugged it back and a window on my laptop appeared to dowload and lg site so the computer can...
You have bricked your phone by disconnecting it while it was updating. Emergency mode is the safe mode of phones, you should never disconnect your phone while it is updating or transferring files.
Apr 28, 2011 | LG GT540 Cell Phone
Hii have a lggd510 mobile .how to download a thems and install
On your phone you can go directly to the url link of LG (in some phones it is already there under bookmarks). This will display the information available which can be downloaded. It can be games, themes,wallpapers, music etc. You can select your themes and download. Once the download is over you will be asked to save. Once it is saved it can be used whenever you want it. The other ways are:
Bluetooth is probably the easiest way of transferring a file from your computer to your phone. You can also use the LG PC Suite via your sync cable. You can refer to the users guide provided with the phone.
PC Sync You can synchronise your PC with your phone to make sure all your important details and dates match. Also, you can download files ( Themes ,Wall papers, Games, Music, Media and any other data ) from computer to phone.
Installing LG PC Suite on your computer
1 From the Home screen press and select Connectivity on the SETTINGS tab. 2 Select USB connection mode and touch PC Suite. 3 Connect the handset and PC via USB cable and wait for a while. Installation guide message will be displayed. 4 Follow the instructions on the screen to complete the LG PC Suite Installer wizard. 5 Once installation is complete, the LG PC Suite icon will appear on your desktop.
Connecting your phone and PC
1 From the Home screen press and select Connectivity on the SETTINGS tab. 2 Select USB connection mode. 3 Touch PC Suite. 4 Connect the handset and PC via USB cable and wait for a while. PC Suite runs automatically.
Backing up and restoring the information on your phone 1 Connect your phone to your PC as outlined above. 2 Click on the Backup icon, and select Backup or Restore. 3 Mark the content you would like to backup or restore. Select the location you would like to backup information to, or restore information from. Click Start icon. 4 Your information will be backed up or restored.
Dec 02, 2010 | LG GD510 Cell Phone
Fprgot password to my Ipod 8gb.
Click "Start"
Click "My computer"
Switch to the classic view (if you're using Windows XP.)
Click "Folder Options"
Click the tab called "View"
Check "Show hidden files or folders"
If you also wish to view system files, Uncheck "Hide protected operating system files"
Plug in your iPod.
Wait for it to load completely.
Open My Computer (or computer if on Vista). Make sure you can view hidden files.
Go to iPod_control.
Go to the folder named Device.
If your iPod is locked, there will be a file _locked . Rename the file to _unlocked.
Safely remove your iPod and it will be cleared.
If you need more help, let me know !!
Sep 10, 2009 | Apple iPod touch
Cannot connect my LG Viewty to the computer via the LG PC suite
hey.. if u connect ur phone via usb, be sure that ur phone is in home screen, because if not, for example if you connect your phone and you're in your message menu then you will open some apps in your pc suite the message will appear saying 'Fail to connect to the mobile handset, Please check the COM port and connect in idle screen. Due to the multifunction, despite idle screen, it can be failed to connect' now try it by connecting the phone but in home screen mode.. gotcha buddy?? hope soo..
Apr 13, 2009 | LG KU990 Viewty
Can not delete msn photo upload tool. attemps cause crashes.
some programs require the disc to uninstall, the uninstall feature is not downloaded on your computer
Apr 02, 2009 | Computers & Internet
Can't view LG KU990's files on my computer
Nah!! i dissagree that solution is way to compicated when you can simply just plug in your USB cord and open the USB driver corresponding to the phone. You do have to have the phone set to Mass storage to do it. {Plug it in and open my computer, the icon will appear by itself, then you'll be able to view and add files and everything else.} No need for any software really.
Mar 16, 2009 | LG KU990 Viewty
Lg viewty usb connection problem
try clicking the button on top right hand of screen (multitasking button) see if there are any menus open . pc suit wont connect if there are any open menus. so u will need to close any b4 tring to connect.
May 30, 2008 | LG KU990 Viewty
Download images to view the computer
With the camera turned off, connect the USB cable to the PC and plug the smaller end into the camera. The camera will turn on and display the selection screen for USB. Use the arrow keys to select the PC option and then press the OK button. The camera will be recognized by the computer as a removable drive. There are instructions available at our web site (http://www.olympusamerica.com/download). For editing and managing image files with a PC, install the Olympus Master 1.0 software from the supplied CD-ROM. After installing the software, connect your camera to the PC via the USB cable provided.
Aug 31, 2005 | Olympus D-545 Zoom Digital Camera
LG KU990 Viewty Logo
741 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
