Question about Lands Phones
The handset has a new battery. It worked well for a few days after battery was installed, then failed to work: has no dial tone.
  • halfrosen Apr 16, 2009
    I tried a different phone and got a dial tone, so I guess that means it works. The "bad" phone does show things on the screen. It shows "out of range" and identifies the handset "Handset #3, New Cid:100.
    The handset was not restoreed to use. However, it was not his fault, becausle I discovered that the base unit is Panasonic and all the remote units are Uniden. I think I will have to replace the three remote un idts and probably the base.
    President:
  • 1,223 Answers
Pls tell me ur problem in detail and ur EXACT model of the handset and base unit so i can help u
Posted on Apr 22, 2009
    Genius:
  • 1,847 Answers
Try a differant phone on the same port, if you get dial then it is issue with the phone.
Is the phone completely dead or you can seen something on the screen.?
Let me know .... Kevin
Posted on Apr 16, 2009
  • Legin Varghese
    Legin Varghese Apr 16, 2009
    You should do the Deregistration and then do the Registration again.
    Take the phone out of the cradle (charger). Press and hold simultaneously for more than 5 seconds the red telephone-symbol key and the # key.
    You will hear a confirmation tone and DEREGISTRATION COMPLETE appears.\
    put the deregistered second handset in the MAIN cradle. The window displays a few messages and then REGISTRATION COMPLETE.
    This will work...Kevin
No dial tone but dial tone on hands free
The battery in the handset may be faulty/flat. If it does not charge up then replace the battery.
Feb 06, 2012 | Lands Phones
The phone is not ringing and it is plug on charge and my wife got new battery for it too. What can i do to get it working? What size of Batteries cani use for this cordless phone
You need the specific battery pack: 5-2814 for the handset. This is a 850 mAh Nickel Metal hydride battery.
When I see a cordless phone that doesn't ring, the first thing I recommend checking is the phone jack and line itself with a second phone. I prefer to use a corded handset with a new phone cord to check for dial tone. If no dial tone at the jack, check for dial tone at the service entry box. If you have no dial tone at the service box, contact your provider. If it's only a problem at the jack, you will need to check your inside wiring.
To check the base, try a new cable (RJ-11) (double check the power as well).
To check the handset, first make sure the handset is fully charged (16 hours) and that the battery is fully installed. Does the handset beep when the Talk button is pressed? Next check that the handset ringer software is on. With the phone off (not in the talk mode), press the Mute/menu OK button. Use the Caller ID/volume (up/down) buttons to get to the Handset setup menu. Press the Mute/Menu OK button to access the menu. Use these buttons to check the Ringer Volume (should be on) and Ringer Tone. Press Mute/Menu OK to save the settings at each sub-menu. Check that the Do Not Disturb function is not on - this toggles with the Do Not Disturb button and should be noted on the handset screen when on.
If you have multiple extensions on the phone line, try unplugging some of them.
I hope this helps.
Jul 07, 2010 | GE T28821FE2 19 GHz Twin 1Line Cordless...
Replaced battery in handset. Got a dial tone and all was well. Picked up handset later in the day and it was dead. Unplugged and reattached everything - no luck.
Try taking batteries out, but also unplug base station. The aim is to disperse all power in the phone so that it resets itself. I would leave everything unplugged for 24 hours and then reassemble and see if the problem has gone. Its worked for me loads of times with different electrical appliances. Hope that helps.
Apr 23, 2009 | Sony SPP A1050 Cordless Phone
Handset
I guess its time to get new batteries
Sep 23, 2008 | Sony SPP AQ600 Cordless Phone
My KX-TG 8231B
Make sure the phone is pluggd into the wall properly. If so and no dial tone is detectable make sure you installed the batterys on the handsets correctly and that they are fully charged. If you have a friendly neighbor with a working phone line plug youre phone into their line and if it does not work and you followed my previous instructions seek a repair center in youre area that honors panasonic warranties. If the phone is pluggd in at the neighbors house and it works use it to call the phone company.
Mar 26, 2008 | Panasonic KX-TG1033S Cordless Phone
No dial tone unless on speaker
Suggest you check battery in non working handset is connected and charged. If this is ok, suggest you check this handset is registered with the base station, as out of the box they arent always set to the same channels
Jan 25, 2008 | Lands Phones
Handset has No link to base
I was having the same problem with the same model phone, and fixed the problem by rebooting the phone – unplugging the AC and phone cord from the base station and plugging both back it, then removing and replacing the handset to regenerate the security code.
Nov 17, 2007 | Xact Communication XG2200 Cordless Phone
Brand new cordless handset -- no dial tone, no ring!
I doubt it's the battery. As I understand it the base works fine and the problem is only with a cordless phone. Are you using an external charger stand for the cordless handset? These phones need to be registered to the base unit. That is usually done by installing the cordless phone in the base unit but you may need to do that shortly after insalling the battery or you could have a register button or setting.
Jun 18, 2007 | GE 27851FE2 Phone
Handset No Link To Base error and no dial tone
I have the problem. I think it is because the battery i have in it was a Ni-MH and it should be a Ni-Cd. I am now looking for the right baterry Good luck Frank wolfgang24@verizon.net
Jan 27, 2007 | GE 900 MHz Phone
Handset ?No Link To Base? error and no dial tone
2/29 Have you registered or re-registered the handset?
"No link" can mean handset is not accepting radio wave of base unit. At Mfgr website pull-down operator's manual and look for registration instructions. Some sequence of buttons will create a radio signal from base (have handset off base) then another sequence of buttons on handset will accept radio signal. If handset has "menu" button, try "menu", then "00" (zero zero) then select an accept or "OK" button. Good luck.
Jan 14, 2007 | Xact Communication XG2200 Cordless Phone
Lands Phones Logo
54 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
