Question about RCA D52W19 52" Rear Projection Television
Working fine, then shut off.. won't come on, no power
I have a 2005 D52W19 rca hdtv. It's been working fine and last night it shut off and will not come back on. No power at all. The surge protector that it was plugged into also had my satelite and dvd player plugged in as well, and they are both fine. When it shut off, I immediately checked the outlets and I could smell heat. Not really smoke, but the tv smelled very hot.
  • taurus754 Apr 30, 2009
    I HAVE AN RCA REAR PROJECTION 52" BIG SCREEN TV-MODEL #P52730-IT WAS WORKING FINE UNTIL THERE WAS A PIP PIP SOUND THE GREEN POWER LIGHT FLASHED TWICE-THERE WAS NO PICTURE AND NO SOUND-CANNOT TURN ON WITH REMOTE NOR WITH THE POWER BUTTON ON THE TV
    ANY THOUGHTS ON WHAT TO DO OR WHAT THE PROBLEM COULD BE?
  • Anonymous May 14, 2009
    mine was working fine monday then monday night it just quit . we unpluged it and waited til next morning worked for about an hour and quit again. whats wrong with it? this is getting old. is it worth fixing?
    Problem Solver:
  • 16 Answers
A clogged air vent will cause the unit to overheat and not turn on.
Posted on Apr 16, 2009
Does the 2005 rca tv d52w19 have a reset button and where is it at
No it doesn't have one, but it has protection circuit to shut the power supply, if you unplug the tv for 10 minutes it will reset the power supply and it should work if there is no problem on the board
Aug 25, 2014 | RCA Televison & Video
RCA D52W20 HDTV TRIES TO TURN ON 3 TIMES BUT WONT POWER UP
remove all the electrical wire connections from the back of the tv .remove the power plug from the electrical outlet and wait for two minutes and replug the wire and then ckeck.it should work.
reply.
Oct 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA HDTV remote won't work with the regular tv. It was working fine last night until i pressed the tv botton and the volume button.
One thing you can try is to take the batteries out of the remote and then press every button on the remote, then replace the batteries. I have used this technique several times and it works. If that doesn't help try leaving the batteries out over night, this may reset the remote.
I hope this helps.
asnowman
Aug 01, 2009 | RCA HD52W59 HDTV Projection Television
My RCA Bigscreen HDTV will not turn on.
If this is similar to the d52w20 then I almost garantee you need to replace a capacitor. You can check to make sure that's what you need by unplugging the tv, taking off the back cover and feeling the top of 3 capacitors. On my d52w20, CP150 (rated at 2200uf 16V) was blown and the top was bulged out. You should also check CP120 and CP114 to see if either are blown. I don't have a clear picture of where it's located, but I have a picture of what you should see after you take off the back cover.
http://i265.photobucket.com/albums/ii209/fillmore85welder/KodakMoment003-1.jpg
In the middle of the picture you see an aluminum heatsink in the shape of a 'C' with the opening facing away from you. That is where CP150 is located. CP120 and CP114 should be located nearby, but if you can feel a bulge on any of the tops of those 3 capacitors replacing them should fix your problem. Replace the existing capacitors with a higher voltage rating of either 25v or 35v.
"4 capacitors on the power/deflection board. CP110 220uf 200v. CP120 220uf 35 Volts. CP114 220uf 35 volts. CP150 2200 16 volt. also check entire delfection board for cold solder especially around flyback. bad connections here can cause problems like some of the fp fuses blowing and cutting off convergence supply"
Jun 02, 2009 | RCA D52W19 52" Rear Projection Television
Thats either the flyback or the HV splitter. If the sound is coming from the rear left side its the flyback. If its coming from the front of the set its the HV splitter. They are both easy to replace. I will post a link where you can get replacements with instructions if you would like.
May 06, 2009 | RCA D52W19 52" Rear Projection Television
D52W19 RCA 46 inch t.v.
my RCA D52W19 52" rear projection TV will not power up ( turn on )
Nov 17, 2008 | RCA D52W19 52" Rear Projection Television
D52W23 colors not aligning
replace FL231 400ma located in front of FBT.This is what is wrong with your tv.
Mar 03, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
343 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
