Question about Sony Cyber-shot DSC-W50 Digital Camera
The lens is stuck
Please help! I dropped my camera last night, and the lens is jammed. It's at a little bit of an angle, and I can't get the camera to stay on, nor the lens to go back down. What do I do?
  • Anonymous Dec 08, 2007
    camera dropped and now the lens is jammed and won't come out
  • scottandyael Dec 09, 2007
    Did not drop it. Just had it in my back jeans pocket and didn't even sit on it. Have tried to gently pull and push in like everyone suggested and it's still not working. What should I do next?
My daughter sat on ours while it was on and the lens wouldn't retract. I tried the banging repair suggested for a stuck lens. After quite a few tries, it got the lens to retract when turned off but it wouldn't stay out when on, so i grabbed the lens and gently pulled it all the way out while it was on and it worked! (phew!)
Posted on Sep 21, 2007
EOS 1v viewfinder is black and shutter glass is half way closed
There could be something stuck (grains of sand, grit, etc...) in the lens mechanism. Try googling "How to fix stuck lens digital camera". If that doesn't work, try altering the search.
Hope I helped!
Dec 08, 2013 | Cameras
I dropped my Nikon Coolpix S3000 camera and now the lens is jammed I tried to push it back in so it wasn't on an angle but now its stuck completely in and its all blured if I took it apart could i...
your best bet is to gently wiggle the lens - try to open it and assist it to open - try to close it and assist it to close - a drop or two of electronic such as Max Professional Electronics Lubricant for Electronics - Amazon.com for about $10. and repeat to assist it along...
Nov 03, 2010 | Nikon Coolpix S3000 Digital Camera
Camera dropped. lens is stuck in open position, won't turn on
Hello
Thank you for using FixYa for your problem
Zoom lens is jammed, It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Jan 20, 2010 | Cameras
Nikon cool pix was dropped with lens out, now jammed and there is a lens error...ANY WAY to fix??? PLEASE HELP
This one is almost assuredly headed for the repair shop, but you might try pulling on the lens a little bit. What has happened is that a gear tooth was skipped because of the impact on the lens, and it is probably cocked to one side. Look at the lens orientation carefully. You might be able to **** it back. Good luck.
Nov 28, 2009 | Nikon COOLPIX L3 Digital Camera
Dropped the Camera, Lens is stuck open
I already tried posting this but I think it falied. Just in case, here it is again!
I just now fixed my own Nikon S220 (very similar to 210) which suffered the same fate as yours. However, I laid my camera down on a cushioned foot-rest (you could use a couch cushion or pillow on a table) with the lens facing UP, pressed down on both sides of lens front gently yet firmly, and BAM, the lens went back in all the way. I turned the power back on and the camera is good as new (except for the small dent from the fall of course).
I suggest you try this before spending $100 on repairs and/or buying a new camera!
Sep 09, 2009 | Nikon Coolpix S210 Digital Camera
Lens is stuck out, camera makes a three beep noise
I'd say the lens gears are stripped or at least out of alignment. Probably due to dropping it on the lens while extended. The camera will have to be sent to the factory or a factory authorized service center. You can also call the customer service folks for help but that will most likely be in vain.
Jul 13, 2009 | Samsung S1070 Digital Camera
E18-lens stuck out-not fully out-won't budgein or out any further
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try. As you've dropped it, you might need to start with Fix #7:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 06, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
Canon PowerShot SX100 IS Lens Stuck
If the lens does not extend/retract when the camera is powered on, then lens assembly is damaged.
Unfortunately, such Canon SX100 (and the SX110 too) has a very fragile lens assembly, and it's damaged very easily. Most of the times the internal gears, the plastic post guides and the motor are damaged at the same time, so the only solution is to replace the whole lens assembly.
The lens replacement requires a qualified camera repair technician, unless you want to try in repair it yourself, which requires tools (scredrivers, soldering iron, desoldering tool, magnifier glass with light, etc).
Best regards,
Oct 14, 2008 | Canon PowerShot SX100 IS Digital Camera
Dropped camera lightly, lens wont retract
my acm dropped and i messed up the lsenes it wont go in please help me how can i fix it my self?
Nov 03, 2007 | Canon PowerShot A540 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
175 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
