Question about D-Link 2.4GHz Wireless g Laptop PCMCIA Card (DLINKWIRELESSG)
Using a dlink extender
I have a linksys WRTG54G router and I told to purchase a DLINK Wireless extender to reach my computers in the basement. How do I set up the dlink extender? Thank you for your help.
  • 71 Answers
I'm assuming you mean a wrt54g, if that's the case look on the bottom of the router and see what version it is. If you have a ver. 1, 2, 3, or 4 then you don't need an extender. you can flash a 3rd party firmware into that router and turn it into a super router. If you are interested, then leave a comment and i will tell you how to do this. An extender will just cut your broadband speed in half so I would avoid that if possible. Let me know.
Posted on Sep 17, 2007
SOURCE:
I want to connect d'link 2640t to linksys wrt120n, hi i have a DLink 2640T modem+router with IP 192.168.2.1, i want to extend my home network so i bought a WRT120N router with IP 192.168.1.1, i am...
This is too involved to just post your router settings. I would recommend reading up on how to "cascade" your router or to make your Modem/Router act as a bridge.
The dlink will need to have its DNS disabled and have the Linksys do the DNS. Then the LInksys will be using the Dlink as its host. you may be better off seeing if you can make the dlink run in Gateway mode instead of router mode.
Then see how to implement the cascading router with your particular situation and WAN IP.
Jan 02, 2018 | Linksys WRT120N Wireless Router
Kindle will not connect to wireless service through d link router
Are You Looking For Dlink Phone Support Or Chat Support?
If You then keep Reading the Post till Last And Know How to Contact dlink customer service. We will reveal all simple ways to contact Dlink Customer service. Typically d-link provides Full Support for 30 Days From the date of purchase but if you register the product with them right after you Buy the Dlink Than it Can be extended up to 90 Days ( 3 Months)Free Support & Warranty.
https://wirelessrouterexpert.com/customer-support/contact-dlink-tech-support
Nov 17, 2010 | D-Link DI 514 Wireless Router (DI-514)
I have a Linksys 5-port switch connected to a cox cable modem and I'm trying to use it to connect two computers at the same time. Only one works at a time and I have to reset the switch and modem to get...
Because the cox cable modem will only bind to one mac address (computer). You need to purchase a router, any router linksys, dlink, will do, get a wireless one so you can setup wifi as well. Plug your cox cable modem into the wan port on the router, plug your pc into one of the ethernet switch ports, you can use your web browser IE to login to the router and secure your wifi signal, power cycle your modem to make it bind to the new router. Most linksys dlink are programmed for a class c network, you could in theory put 254 devices, computers on your connection now.
Aug 27, 2010 | Linksys EZXS55W EtherFast 10/100 5-Port...
How do I change my unsecured wireless network to WPA?
We will reveal all simple ways to contact Dlink Customer service. Typically d-link provides Full Support for 30 Days From the date of purchase but if you register the product with them right after you Buy the Dlink Than it Can be extended up to 90 Days ( 3 Months)Free Support & Warranty. https://wirelessrouterexpert.com/customer-support/contact-dlink-tech-support
Jul 10, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Dlink dap 1522
I think I was having a similar problem with my DAP-1522 ... FW Version 1.10 being used as an access point. I recently discovered that I was not able to connect to the configuration pages using a web browser by typing in it's IP address (192.168.0.50). When I originally set this up device up on my network, it worked just fine, but at some point in time, it stopped working. My solution to this problem was to set the switch on the back of the 1522 from Auto to AP, then re-boot the DAP-1522 by removing power, waiting 10 seconds, then plugging power back in. Once the AP re-booted, I was then able to access the configuration login page by typing 192.168.0.50 into my browser. My DAP-1522 access point is connected via port 1 to my D-link router, a DGL-4100, via a DGS-2208, 8 port gigabit switch. Hope this helps!
Aug 16, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Low signal in the basement
maybe you should try to purchase a better wireless adapter,like dlink dwa-110
Jan 29, 2009 | D-Link AirPlus DI-524 Wireless Router
Wifi problem of DIR-300 dlink
just open the dlink ip homepage and configure the wireless settings
sagar
Jan 27, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Wireless g range extender
Hi there ....
before anything else, can you please what is the version of range expander is is wre54g v1,v2,v3?
1) either which, please do verify your wireless settings of your DLINK router
-- the network name or ssid
-- security if you enabled any on your router
-- wireless channel
-- please check the default gateway of your router if it is 192.168.1.1
** please take note also that the best location for your expander would be inbetween your router and your computers
2) once you have gathered the wireless settings
-- you would need to manually configure your expander coz it didnt work .. Please remember that the LINKsys expander is designed to work with linksys routers, so it may or may not work.. I just need to set your expectations on this ...
3) once you have verfied the default gateway of your DLink router ... please reply to this thread and let us proceed in configuring your wre...
Thanks and good luck!
Oct 31, 2008 | Linksys : WRE54G Wireless Range Extender...
Dlink di-524 connect to RV042
Hi.
You need to cascade the Dlink wireless router to your RV042.
Suppose your RV042 has a default IP Address of 192.168.1.1, and the DLINK IP uses 192.168.0.1. Your Physical connection is from the regular port of the RV042 going to the WAN/Internet Port of the DLink wireless router.
Once you do that, your Dlink router should automatically obtain an IP from the main router. If it did, configure your wireless settings and you should be able to connect via wireless.
This is just one way to cascade your router to another router.
For more information, click here.
Jul 21, 2008 | D-Link AirPlus DI-524 Wireless Router
Open Questions:
See all D-Link 2.4GHz Wireless g Laptop PCMCIA Card Questions
Computers & Internet Logo
69 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
