Question about Boating
I bought an attwood fuel/water separtaor but it came with no installation instruction. How do you install the separator
  • 490 Answers
In the fuel line between the tank and the motor
mount it someplace convenient and from the tank to the inlet side of the separator then out of the separator to the motor
Posted on Apr 16, 2009
Pilot light will not stay lit. already replaced thermal coupler. 6 gallon
A thermocouple makes 30MV power by a temperature differential across the end of the thermocouple, many times people set the entire end inthe flame heating the entire end thus dropping out the power, you cannot bake them into working there must be a temperature differential from the base to tip about a 1.5 inch section. It wil not work correctly if the entire end is hot.
Otherwise the gas valve is bad.
Nov 06, 2013 | Atwood 10 Gal LP Gas /Elect. WATER HEATER
Should the return line come into drain of water heater or cold in.
Your question is not complete.
You have gas water heater in attic?
You are installing recirculation system? Which recirculation do you have? .. so expert can read instruction manual alongside you.
You can connect the recirc return line to the water heater drain valve only IF you have plumbed a separate return line for that installation.
Otherwise, the recirculation return line recirculates into the cold water inlet on water heater.
Copy following link for general illustrations showing both types of installation.
http://waterheatertimer.org/Water-heater-recirculation-system.html
Aug 08, 2012 | Grundfos UP10-16BU/ATLC Comfort Series...
How to replace a diesel pomp
  1. CAUTION
  2. Smoking or open flame of any type must not be present when working near fuel or fuel vapor.
  1. Disconnect both battery ground cables.
  1. Raise and support the vehicle.
  1. Before servicing the vehicle, refer to the Precautions Section.
    CAUTION Smoking or open flame of any type must not be present when working near fuel or fuel vapor.
  2. Disconnect both battery ground cables.
  3. Raise and support the vehicle.
  4. Open the fuel/water separator drain valve to release the fuel pressure.
  5. Disconnect the electrical connectors.
  6. Disconnect the fuel pump electrical connector.
  7. Disconnect the fuel warmer electrical connector.
  8. Disconnect the water-in-fuel electrical connector.
  9. Disconnect the fuel hoses.
  10. Remove the fuel hose retaining clips and discard. Disconnect the fuel hoses from the fuel pump.
  11. Press in the retaining clips and release the fuel hoses.
  12. Remove the mounting nuts and the fuel conditioning module.
  13. To install, reverse the removal procedure. Torque the nuts to 11 ft. lbs. (15 Nm).
  1. Open the fuel/water separator drain valve to release the fuel pressure.
Dec 18, 2011 | 2007 Ford E-350 Super Duty Length XLT
I HAVE AN ATTWOOD WATER HEATER I LIGHT THE PILOT ON GAS AN PILOT WILL NOT STAY LITE AFTER RELEASING THE BLUE KNOB SO I CHANGE THE HEATING COUPLING AN STILL DOING THE SAME THING
Try spraying some WD-40 in hole where thermocouple attaches to gas valve, then twirl a small piece of steel wool in your fingers and insert it in that same hole and twirl it as you push it in to clean surface where thermocouple makes contact. Then blow out with compressed air if possible and then re-install thermocouple fitting snuggly. If that doesn't do it, you'll have to get a new gas valve/control.
Jul 21, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
How do I change the fuel, water separator filter
#1 Disconnect the battery ground cables from both batteries.#2 Drain fuel from the fuel filter into a sutable container.#3Remove the water drain tube from the bottom of the filter assembly.#4 Unscrew water separator drain bowl and remove. Remove the filter element.#5 Installation is the reverse of the removal procedure.Screw a new filter element onto the filter base until seal contacts ,then tighten filter one half to 1 turn.I hope this is helpfull, good luck.
Dec 06, 2010 | 1990 Ford F350
Location of 2nd fuel filter
one is in the tank.
Filter Removal and Installation
s3o~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Do not smoke or carry lighted tobacco or open flame of any type when working on or near any fuel related component. Highly flammable mixtures are always present and may be ignited, resulting in possible personal injury.
  1. Relieve the fuel system pressure. For additional information, refer to Section 310-00 .
  1. Disconnect the fuel lines from the fuel filter. For additional information, refer to Section 310-00 .
  1. Remove the fuel filter.
    • Loosen the fuel filter clamp screw.
  1. NOTE: Make sure that an audible click is heard when installing the fuel lines. Pull back on the fuel lines to confirm engagement.
Filter -Water Separator Removal
s3o~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Smoking or open flame of any type must not be present when working near fuel or fuel vapor.
s3o~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The fuel system contains pressurized fuel after the vehicle is shut down and will maintain this pressure for a long period of time.
  1. Disconnect both battery ground cables. On vehicles equipped with dual batteries, refer to Section 414-01 .
  1. Open the fuel filter/water separator drain valve to release the fuel pressure. Completely drain the fuel filter/water separator assembly.
  1. Disconnect the fuel supply and fuel return lines.
  1. Disconnect the two cylinder head fuel supply lines.
  1. NOTE: The turbocharger compressor manifold is removed for clarity.
    Disconnect the electrical connector from the fuel filter/water separator.
  1. Remove the fuel filter/water separator from the vehicle.
    1. Disconnect the exhaust back pressure sensor electrical connector.
    1. Remove the fuel filter/water separator bolts.
Installation
  1. s3o~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Clean all the fuel residue from the engine compartment. Failure to do so can cause personal injury or damage to the vehicle.
Nov 19, 2010 | 2003 Ford F350 Super Duty DRW SuperCab
Hard starting have changed fuel filter four times in two weeks
Either carry a lot of fuel filters or drain the fuel tank after it sits for a full two days, You have water in the fuelor a ton of algae. Confirm the water by pouring out the fuel filter. Any water will be obvious. The water in the tank will separate from the fuel if left standing. Then the water can be drained out the bottom of the tank.Water in the fuel can blow tips off injectors so take heed. and good luck.If you don't have a fuel water seperator, consider having a RACOR separater installed.
Sep 23, 2009 | 2007 Dodge Ram 3500 Quad Cab Laramie
I have an Attwood GE 16TE hot water tank with what a bad element,
this is not a typical unit, you might want to consider calling the company for directions, go to there web site if they have one and look for elements and where they are located
Jun 15, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Boating Logo
372 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
