Question about Pioneer DEH-P7900BT CD Player
Pionee DEH-P7900Bt i am having trouble being able to answer the bluetooth via the pioneer unit. the unit acknowledges the call, but it will not answer.
This may be a long shot but who knows... I am one of those that reads the manual after I have figured most things out. I had the same problem but it was due to the above :) When a call was coming in I was pushing the phone button on the receiver. After reading the manual I discovered that is the "ignore" button for incoming calls. To answer the call you simply push the multifunction knob.
Posted on Sep 19, 2007
SOURCE:
Plays music for about 3 mins then stops
Possibly shorted unit. But sounds more like it reset all settings to 0. check ground on head unit itself.
Feb 27, 2014 | Pioneer DEH-P7900BT CD Player
Flashing blue light
The flashing blue light notes connection attempt to a bluetooth device.
Oct 29, 2013 | Pioneer DEH-P7900BT CD Player
I have the Pioneer DEH-p7900bt and when i hook it up in my car the everything works except the screen, only the top third or so of the display screen lights up. but all everything else lights up. i dont...
I say it is the screen or face if you well mine did the same thing and it is cheaper to find one on ebay than to repair it. I checked one place out and they wanted like 60.00 well good luck and take care
Mar 18, 2011 | Pioneer DEH-P7900BT CD Player
I need to know how to pair my phone to my c.d player
Turn the bluetooth on in ur phone.
Use MULTI-CONTROL to select
Connection open in the function menu.
Press MULTI-CONTROL to open the connection.
Always waiting is displayed. This unit is now
on standby for connection from Bluetooth
device(ur phone).
If your Bluetooth is set ready for
Bluetooth wireless connection, connection to
this unit will be automatically established.
Jul 04, 2010 | Pioneer DEH-P7900BT CD Player
Hola mi nombre es christian, yo tengo un pioneer DEH-P7900BT y cuando lo conecto solo prende las luces de los botones pero la pantalla no, no se si esta mal conectado o el stereo no cirva. por favor...
Esto no es una solucion, pero la misma cosa esta pasando a mi. Estava trabajando, pero en un momentito se cebro.
pienso que tu radio no cirva. La misma cosa esta pasando a otros dos personas en estos forums.
my espanol es muy mal.
Dec 08, 2009 | Pioneer DEH-P7900BT CD Player
Twice my Pioneed DEH-P7900BT has just stopped working. Keyboard went dark and the unit shut off. I pressed the button to open the face place and it opened and is stuck that way. It also didn't eject my CD...
This sounds like a wiring problem. Double check all of you connections. If the Connections look good then I would check the connections inside the radio. Check the power wire mostly. The wire could have a bad solder joint inside the radio itself.
Mar 02, 2009 | Pioneer DEH-P7900BT CD Player
How do you eject the damn cd out of the pioneer DEH-P7900BT
Your Manual
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/429287552DEHP7900BTOperationManual0328.pdf
will go over all the functions in detail.
3 EJECT button
Press to eject a CD from your built-in CD
player.
Press and hold to open or close the front
panel.
Bottom rightmost button.
Nov 11, 2008 | Pioneer DEH-P7900BT CD Player
Code for blue tooth access to Pioneer DEH-P7900BT car stereo.
try 0000 that is the default code for my bluetooth device for my phone , "Hey you never know "
Sep 14, 2008 | Pioneer Car Audio & Video
Pioneer DEH-P7900BT CD Player Logo
113 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
