Question about RCA RT2250 System
CHK SPEAKER MESSAGE UPON POWERED ON
Whenever I turn on my receiver, it displays a message to CHK SPEAKERS. I checked , replaced and rechecked all the cables and I am still getting the same message.
  • Anonymous Dec 31, 2007
    exactly same problem
  • Anonymous Jan 02, 2008
    Mine makes three clicks while it displays the message, then shuts off.
I've got that problem too. Mine makes a clicking noise three times while displaying that message, then shuts off.
Posted on Jan 02, 2008
SOURCE:
My amplifier cuts out and displays the message "check sp cable", what does it mean?
It simply means to check your (sp)eaker cables. It is likely that one of your speaker cables is damaged or not correctly connected. This is causing an overload in the receiver and the cut-out indicates the receiver has gone into 'self-protect' mode, to prevent damage to the internal components.
This could happen if you have cross-wired + and - to one or more of the speakers. It could also be that a cable to one of the speakers has been partially severed and +/- are shorted together or it could be as simple as one of the speaker connections having become detached. Speaker connections are polarised positive + and negative - the same as your household electrics and need to be wired to the correct poles.
To fix this problem, you should initially check all of the speaker connections at both the receiver and speaker ends. Make sure everything is properly connected and that + and - on the receiver are correctly wired to + and - on all speakers. If all of the connections are correct and the error message persists, disconnect each speaker one at a time, reset the receiver and test again.
If you disconnect a particular speaker and the error message no longer appears, you have found the cause of the problem. Examine the cable for any sign of damage and replace the cable. If there is no visible damage, it is still advisable to replace the cable for this speaker as damaged cables are not always visible to the eye.
Please check all of your speakers as above, then let me know if you need further assistance. The message could be erroneous and may indicate a fault with the receiver.
Hope this helps.
Regards,
BElectric.
Feb 26, 2011 | Yamaha HTR-6030 Receiver
Connecting 5.1 speakers it comes up with error message: WA1- out of phase. I have rechecked all the speakers and it is not a problem with the connection. It is the front speakers that seem to be the...
It's telling you that based on its diagnostics the speakers are wired Out of Phase with each other. Carefully recheck the polarity of the speaker wring: + to +; - to -.
Dec 31, 2010 | Yamaha RXV667 Receiver
The display say "PROTECT" whenever you turn it on.
your sony channels receiver it says protect bec ther is to much power on the speakers to fix it get les powered speakers then it will work
Jul 26, 2010 | Sony STR-DE345 Receiver
NO sound, display says CHECK SP cable? Just bought yamaha292 theater system with AV receiver HTR-6230, all speakers are wired, plug with 1 optical to my TV, selected the inputs and there's no sound. ...
Probably the speakers are not wired correctly. Check this by turning on the receiver without speakers connected. If the message is gone, issue was in the connection of speakers. Check that you have not short-wired the + and -.
Dec 13, 2009 | Yamaha HTR-6130 Receiver
My technics sa-dx930 receiver stops working and an error message is displayed that says "overload" when i use the "b" speakers for my patio. This is a new problem. i have had the same outside speakers,...
Hey, I own one of these systems. Whenever I touch two of the wires together (shorting it out) the system shuts down and overload appears on the display. My suggestion is too check your wiring (especially in the spliced areas) or replace the wiring to the outside speakers and try it again. If you dont want to try that, take the wires you have hooked to the A speakers and see if they will work on the B setting (a quick troubleshooting technique). Please let me know if it worked for you. Good Luck!
Sep 09, 2009 | Technics SA-DX930 Receiver
No display info on receiver
Try plugging a video monitor AKA your TV into that monitor output connector on the rear of the yamaha.
Select video in on the TV and see if anything shows up from the yamaha
Sounds though like the receiver has serious issues. If you can get your moeny back , do so
Feb 24, 2008 | Yamaha RX-V661 Receiver
How to activate the HOLD ON SAMSUNG E250
chk for the call waiting option in ur mobile phone
is available or not if available
then activate it by clicking on it and wait
then u can receive a message saying that the call waiting option is being activated.
Feb 07, 2008 | Samsung SGH-E900 Cellular Phone
Unable to receive music
select default memory in ur phone of memory card…else chk whether the song is more than 5 mb as according  to ur phone memory,
Oct 03, 2007 | Nokia 6230
Short in speakercable
Check the speaker cable connections between the Plasma Display and the speakers. replace it if needed. it will work.
Oct 11, 2005 | Pioneer PureVision Pro-1120HD 50 in. HDTV...
RCA RT2250 System Logo
276 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
