Trouble code E7-11
I have a sharp ar 285 and after it turns on it says call for service code E7-11 can any tell me what this means
    New Friend:
  • 91 Answers
You have laser unit trouble. You should replace the lser unit
Posted on Apr 20, 2009
What's your question? My Sharp photocopier AR-161 display E7. and can't make copies what is the problem?
Here is a list of error code meanings for your device. You need to find out the sub code should be E7-?? To find the root cause. Sharp AR 161 Error Codes Trouble Codes
E7
E7 03 LSU trouble
E7 04 CCD white level trouble
E7 05 CCD black level trouble
Sep 25, 2015 | Sharp Office Equipment & Supplies
SHARP-235, lp 6-10 CALL FOR SERVICE CODE...Sep 2010 ... What does error code L6-10 mean on a Sharp AR-235 ... my machine sharp a 235 say call for service lp 6-10 what dos it mean
L6 10 Content Polygon motor lock trouble
Details The polygon motor does not rotate.
The motor lock signal is detected for 6sec
or more after the polygon motor rotates.
The motor lock signal is detected for 1sec
during rotation of the polygon motor.
Cause Polygon motor unit failure
Polygon motor connection harness trouble
or disconnection
MCU PWB failure
Check
and
remedy
Check the polygon motor operation with
SIM 61-1.
Check connector/harness of polygon
motor
Replace the polygon motor.
Replace the MCU PWB.
If the polygon motor isn't working then you will neeto buy a new Laser Unit. They can be expensive if you can get one. To replace it will tak alot of disassembly as well. Might be better and more cost effective to get a new machine.
Oct 22, 2011 | Sharp AR-235 Copier
I have an Error on my Sharp AR-M350n+ copier that says "L6-10" Can you please tell me that that error code means? Thanks
L6 10 Polygon motor trouble
it is a very common problem on sharp copiers
that means the laser unit is defective, tou have to change it , allso is very expensive..
regards,
Adi
Nov 03, 2010 | Sharp AR-M350N Copier
Don work my printer (sharp AR-285) just say error
Check the copy lamp which is not lighting up.
Oct 28, 2009 | Office Equipment & Supplies
I have a sharp copier, model AR-285, H4-01
H4 error pertains to lamp errors.
that would either be the copy lamp or the heater lamp.
check both lamps.
with heater lamps,it's usually caused by either a broken heater lamp or a dirty thermostat on the heater roller assembly.
Jun 09, 2009 | Sharp Office Equipment & Supplies
When you turn on the Sharp AR 285 copier it won't start up
There may be a reset button on back of printer - check owner's manual....if not, firmware may need updating.
You need to weigh up the cost of a service call vs price of new machine.
Apr 10, 2009 | Sharp AR-275 Copier
Sharp Copiers Error code : F1-14
I was making copies through the document feeder and got the F1 error, and it's blinking and I can't make copies. Any ideas? Thanks!!! Christine
Mar 02, 2009 | Sharp Office Equipment & Supplies
Sharp AR-285 reporting code F2 and smeared copies
to find the sub code press start key,if it shows 04,then ic chip present in it gone bad,replace the toner ic chip.
Apr 20, 2008 | Office Equipment & Supplies
308 people viewed this question
k24674
jasbo
jasbo
