It looks like it depends upon whether your Taurus has a four cylinder or a V6 ......I am guessing the V6 has the timing chain and the 4 has the timing belt.
1st you need to establish if you have misfire, by going to auto zone and have them read your computer, from therefrom can decide what need to be done, but I donot believe you have timing issues
The 2.3 uses a timing belt with an tension idler adjustment. Replacement is straight forward, just make sure to mark upper and lower cog pulleys before removing the old belt so that you can keep the timing in sync.
Hello;
The Ford motors are pretty good. I had 280K on a 2.9 V-8 that only needed the oil changed every 3K. Unless you have fluctuatuation in the timing then you should be ok.
These engines use a chain rather than a belt and have excellent life.
Thanks;
Rich RPM Northwest
This truck should have a timing chain, not a belt. If the engine is running fine and there are no noises such as the chain hitting the timing cover, you are OK.
I will assume you are referring to the timing procedure for a replacement timing belt (4 cyl) or timing chain (V6) With the V6 timing chain you simply line up the timing marks on the two sprockets so that they are pointing directly toward each other, crankshaft sprocket with the mark pointing straight up, camshaft mark straight down. With the 2.3 L 4 cylinder engine, you must first position the crankshaft at TDC, and then position the oil pump and camshaft sprockets with their timing marks to line up with their respective marks on the inner cover. Install the belt and release the spring tensioner to let it adjust itself, tighten the tensioner bolt, and turn the engine over for 2 rotations (always clockwise as viewed from the front, never backwards). Make sure the marks still line up, loosen the tensioner, allow it to retension itself, and tighten the tensioner bolt. If the oil pump sprocket is not timed correctly, the camshaft position sensor signal will be incorrectly timed.
