Question about Kenmore Refrigerators
There is water in the bottom of my refrigerator
Food on the shelves gets wet. Water collects under the crisper drawers and sometimes leaks out onto the floor.
  • nerakretrop Apr 16, 2009
    where is the drain? I have looked for it but everything seems to be encllosed.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
You have drain clogged
Posted on Apr 16, 2009
SOURCE:
Water appearing on glass above crispers and onto the floor under the crispers. Happens only occasionally. No obvious source of leak. Back of fridge wall not wet.
Do you have a cooling plate at the rear or the fridge with a narrow tray at the bottom to collect the defrost water? Check the drain hole for obstruction.
Apr 08, 2016 | Refrigerators
Why did the shelf under lower bin freeze?
Many refrigerators today are having issues with the drain hoses clogging. This lets water collect in the lower drawers/shelves where they either leak onto the floor or freeze. Unclogging the hose is the only fix for this. Manufacturers know about the problem, but are doing nothing about it since they rarely need cleaning before the end of the warranty periods.
Oct 22, 2015 | Kenmore Refrigerators
I have the subzero 632 side by side and there is water dripping from under the bottom drawers onto the bottom of frig and then onto floor. Could that be the rubber gasket stripping on the bottom of the...
Behind the crispers and the shelves at the bottom is a drain trough. This drain trough is clogged and would need to be cleared by air pressure. You can use canned air you can seal the opening to keep the pressure in the tube. Once cleared you should be fine.
This happens when food or foreign object get into this trough clog or slow water flow out of the fridge section.
I hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Oct 05, 2013 | Sub-Zero Overlay Design 632/O Side-By-Side...
Water under crisper drawers and then leaking outside underneath.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Sep 28, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Water collects under crisper drawers
Does it have darin at the bottom to drain out the bottom of the frifge into the drip pan? if it does push a wire threw the hole with the unit unplugged.
Aug 28, 2009 | Refrigerators
Water draining under crisper bins & onto shelves. Try again
Your drain tube is stopped up. Take the panel off in the freezer section and chip away the ice in the pan below the coil. When you get to the drain hole pour hot water in it until it free flows. You will need a towel in the freezer to catch the excess water. Run some extra hot water through it to assure that you clean the drain out good.
Mar 15, 2009 | Frigidaire FRT21H8 Top Freezer...
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Roper Refrigerator
open the freezer compartment loo for ice build up on floor of frezer especally towards rear behind back panel. sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Mar 05, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Refrigerator
check behind the drawers is there a water tank for water in thew door that would be my first guess
Feb 10, 2008 | Kenmore 63074 Top Freezer Refrigerator
Fridge filling with water
There usually is a drain at the back of the fridge it's possible that this is clogged, This drain leads to an evaporation tray usually in the base of the fridge.
Oct 09, 2007 | Kenmore 94499 Refrigerator
Refrigerators Logo
342 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
Jimmy
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
