Question about Matsonic MS9337c Motherboard
Intel P4 2.66GHz/512/533 is not working on MS9337C+.
At this time P4 2Ghz is working normally, but I failed to start P4 2.66GHz on MS9337C+.
Do you have any ideea to make Intel P4 2.66GHz/512/533 to start on MS9337C+ mainboard? Is it posible?
There are no jumpers to change mainboard speed.
BIOS: Phoenix Award BIOS v6.00 and I can not find a newer one. I failed to download BIOS from www.driverguide.com.
It a pitty Matsonic web page support is gone. Matsonic was a significant company during 2000-2002.
  • Anonymous Apr 26, 2009
    umcds235,
    Motherboard MS9377C+ fails to start at all with cpu Intel P4 2.66GHz/512/533 or P4 2.8GHz/512/800. I mean I can view only a blank screen (dark screen, dead on start) with no video signal to monitor, obviously with no option to acces BIOS setup, so your suggestions can not be applied. These 2 CPU were tested working on other Matsonic motherboard, chipset VIA PT800, MS9167C. I do not expect your Prescott 3.0E / 800Mhz to work on MS9377C+. My BIOS file is s8a210c.BIN /Jan 16, 2003 which can be found athttp://members.driverguide.com/driver/de...
    What BIOS driver do you use?
My cpu p4 2.66 pinless
Posted on Mar 11, 2011
#1. Does the CPU fan run if not then you may have a conductivity problem between fan and CPu. Did you use thermal paste or grease?
If fan is running follow directions below from my manual for MS9377C+ mainboard.
Go into the BIOS setup ,go to CPU setup, select proper voltage for you CPU. On Advanced setup page see if the hyperthreading function is revaeled. If so your CPU has this function. Set "Enabled " to test HT CPU function. If this doesn't work try "Disabling" the function. Good luck. I am about to attempt tp upgrade to a Prescott 3.0E which the box says this board supports. Sure hope so . Am running a 1.7 now.
umcds@sssnet.com
Posted on Apr 24, 2009
What's your problem?AMD athlon 2Ghz processor will suitable for asusp5gc mx x-series motherboard
No... Absolutely not.
You can't put an AMD processor in a motherboard that only supports Intel processors.
Aug 17, 2012 | Intel Computers & Internet
I have mirus intel laptop everytime i start it up it says boot up or but in boot media device help
Remove any USB stick before booting up. When you start your computer press DEL/F2/F1 to initiate the DOS screen, select or change the boot priority to HDD and it should work properly.
Nov 16, 2010 | Dell Latitude C640 PIV 2Ghz, 20-40Gb,...
Fujitsu seimens scenic p300 no chipset drivers where can i get them from
Specification Processor:
Celeron
Intel P4
up to 2GHz
up to 2.66GHz
up to 2GHz
up to 2.66GHz
up to 2.4GHz
up to 3.0GHz
up to 2.6GHz
up to 3.2GHz Motherboard: D1451 D1521 D1561 D1761 Chipset i845GV i845GE i865G SiS661FX Video: On-board On-board + AGP slot On-board + AGP slot On-board + AGP Slot Max Memory 1GB DDR333* 2GB DDR333 2GB DDR** 2GB DDR Memory slots 2 2 4 2 Audio STAC9750 AD198x AD198x Realtek ALC655 On Board Lan AN983B 82562ET 82562EZ AN983N Hard Disk: Depends on choice at time of purchase - 20/40GB (5400rpm), 20/40/80GB (7200rpm silent). CD/DVD Drive: Depends on choice at time of purchase - Cdrom ,DVD or CDRW * 2GB (DDR333) with future memory modules
** 4GB (DDR333/400) with future memory modules
http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/professionalpc/Scenic/ScenicP/scenicP.htm
You know, if you can decipher your motherboard, You'll be able to find the intel chipset and do a download. Make sure you save/rename your old.
Apr 18, 2010 | Fujitsu Siemens SCENIC P300 PC Desktop
Code oxc18a0001
disconnect the printer, remove ink cartriges, turn printer off, wait a minute, then turn it back on, replace ink and connect to computer again. If this doesn't work you will need to contact HP support,
Jan 22, 2010 | HP COMPAQ DESKTOPS DC7800 ULTRA-SLIM...
No sound coming out from cptr. Motherboard MS9337C. All my speakers are working on another cptr. When I run music cptr states no audio installed. Started when I reformated system and reinstalled windows...
May be you have not installed the sound driver.pls installed the sound driver from motherboard CD.after installed the driver it is not work then may be your motherboard sound card has been faulty then you can checked it from service center.
Oct 27, 2009 | Matsonic MS9337c Motherboard
Need a new processor
http://www.dell.com/content/products/productdetails.aspx/inspn_e1405?c=us&cs=22&l=en&s=dfh&~section=specs#tabtop
Select Tech Specs:
Intel® CoreTM 2 Duo Processor T5500 (1.66GHz, 2MB L2 Cache, 667MHz FSB) Intel® CoreTM 2 Duo Processor T5600 (1.83GHz, 2MB L2 Cache, 667MHz FSB) Intel® CoreTM 2 Duo Processor T7200 (2GHz, 4MB L2 Cache, 667MHz FSB) Intel® CoreTM 2 Duo Processor T7400 (2.16GHz, 4MB L2 Cache, 667MHz FSB) You can order the processor from Dell sales and then take it to a local computer shop like Fry's. And they can can install it for a good price. I normally would not recommend replacing a laptop processor unless you have done it previously several times.
Apr 29, 2009 | Computers & Internet
New procesor not work
you might check the jumper for processor settings, maybe the jumper is not set to celeron? if it is working using the intel pentium check the specification of the mother board if you can use the celeron processor.
Mar 15, 2009 | Computers & Internet
Matsonic MS9337c Motherboard Logo
493 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Computer Links
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
