Question about AudioBahn A2300HCT Car Audio Amplifier
AUDIOBAHN a2300hct problems
Just fitted this,was running fine after 15 mins the amp cut out with the red led coming on,The amp still tries to kick back in as the blue led flickers on and a pulse of sound comes through the subs.I have tried disconnecting the subs but the red light still stays in,Can anyone help please?
  • 6 more comments
  • SupraTTJames Sep 16, 2007
    Thanks buddy,My battery looks as though its on its last legs,Could that be a factor in why my amps went loco?
    Yeah It occurs whether it is running or not, Iv got a battery coming within the hour ill have that hooked up Iv also had a voltmeter installed into my dash,When the car lights are on and tha amp pulses the lights and all the other electrics go really dim
    Hey buddy Iv had the battery fitted,the amp readings from the alternator seem to be above board, Even with the speakers disconnected the amp still continues to pulse and you can see a very small reading on the output dial,When this happens all the electrics inside the car flicker at the same time, I disconnected all the leads from the amplifier and there still a small reading on the voltmeter,Is that normal? I appreciate all your help
  • SupraTTJames Sep 17, 2007
    Just in from work,hooked up the amp ground to the battery and the amp has now got a blue light, But what does this mean? Im a plumber so aint gotta clue Thanks again for all your efforts,Very much appreciated
  • SupraTTJames Sep 18, 2007
    Hi Is it safe for me to hook up the amp ground directly to the battery? Has the previous earth that was hooked up been the cause of the hastle?
  • SupraTTJames Sep 20, 2007
    Hi,Iv just finished hooking up my amp to the battery with 4 gauge wire, the problem still persists, but when I use very small speaker cable it fires up no problem.but the cable only lasts a few minutes before melting the plastic coating off,Can you help me please?
  • SupraTTJames Sep 26, 2007
    Have You checked the fuses mate? Im a gas engineer and a plumber but iv done this before a while back,Turned out the main power fuse and blown
  • awalracing Sep 02, 2008
    SAME THING HERE< HELP>
It's a blown driver or drivers my friend. Put mine into an electronic repair place, cost me £70 to repair.
Posted on Sep 08, 2008
  • Tim Badger
    Tim Badger Feb 24, 2011
    where is u take the amp . did they tell u wat was wrong with is .
    Problem Solver:
Same amp same problem
Posted on Sep 02, 2008
    Genius:
  • 1,139 Answers
This indicates a possibility of a power supply issue, you may have to open up the unit and take voltage measurements to determine if the voltages are correct. In order to do this you will need a schematic diagram of the unit. Once you have the schematic you will be abor to tell which voltages are legitimate. I hope this helps
Posted on Sep 16, 2007
  • 3 more comments
  • Henry McKelvey
    Henry McKelvey Sep 16, 2007
    You should also check the voltage regulator just in case. Does the problem occur when the vehicle is running?
  • Henry McKelvey
    Ok when you get the new battery in test it under load. If the problem still occurs, which it should not, check the amperage from the alternator, if it is over specifications consider adding a new alterantor, battery, and voltage regulator for the audio amplifier, in addition check the ohmic rating of your speakers to make sure they are matching with the amplifier and are not creating a high current drain. I wish you well on this.
  • Henry McKelvey
    Henry McKelvey Sep 17, 2007
    It looks like you are drawing a lot of current. Keep the speakers connected and connect a ground wire from the battery terminal to the ground on the Amplifier. make it (The connection)one continous run with a large gauge wire.
  • Henry McKelvey
    Henry McKelvey Sep 18, 2007
    Yes it is safe as long as you tie it directly to the battery negative line terminal connector.
  • Henry McKelvey
    Henry McKelvey Sep 21, 2007
    Interesting What is the ohmic rating of your speakers and your sub?
    The reason I ask is because the smaller the wire the more resistance and the fact that you are burning the wire up means that it is dissipating heat. This could mean an impedance mismatch between the speakers and the amplifier. make sure the amplifier and the speakers (total impedance) match each other.
I have a honda van and i goy 2 15 kickers
Nope, sell it all on ebay. You shouldn't be behind the wheel anyways.
Jun 29, 2010 | AudioBahn A2300HCT Car Audio Amplifier
A2300HCT Car Audio Amplifier: i have a audiobahn a 2300 hct amp and it has stopp...
Well, sounds like you have an internal damage since it smokes, if it smokes as soon as it kicks on, and blowing the fuse right away, I would have it fixed. But my guess would be something with the ground that is making this happen, or some how your power is grounding on the amp. When ever smoke comes into play, thats never good any way at this point you gotta admitt that thiers internal damage.. blowing fuses can also be cause by over working your amp. along with the sub load at 1 ohm make sure your amp can do the same.. hope this was helpful in some way
May 16, 2010 | AudioBahn A2300HCT Car Audio Amplifier
Heeey. I have the Audiobahn A2300HCT and it has a very strange problem. When i start the amp its in the normal blue mode but i have no sound. The one power output (LEFT) indicator shows +3DB (full) the...
My brother just bought an A2300HCX and almost the same thing happen. 1 of the gauges (left side) was no movement. We tryed hooking the amp to the right side, and it works. The Left side turns out was shot, had to get it fixed. So sorry to tell you but sounds like one of the channels has internal damage. I know this isn't the good new you were wanting to hear, but hope it was helpful
Apr 08, 2010 | AudioBahn A2300HCT Car Audio Amplifier
Hooked up the amp, lights up, fans kick on and run fine, speakers hooked up proper, no sound? hooked up speakers to another amp and they work fine. Fuses are all good too. Thoughts?
could be bad rca cables or no output from the radio rca outputs. the sub control may be turned off on the radio (ive seen that alot at my work). if all that is fine, the amplifier may be bad. the rca cables may be plugged into the "out" section of the amp. gotta look at all the small obvious things first. good luck.
Dec 18, 2009 | AudioBahn A2300HCT Car Audio Amplifier
Audiobahn 2300hct red led light comes on when engine revs up at idle amp goes blue and works fine. volts are running at 13.5 to 14.0 when reved and 12.4 at idle. what going on? amp worked fine when car was...
this is happening simply because your ground wire is either going bad, or it has a bad connection to your vehicle. check the spot where your ground wire connects to your car, and look for corrosion or a change of color in the wire. if you find anything like this, i would recommend replacing your entire ground wire. if the wire looks fine, just tighten your connection point, or move it all together.
Jun 06, 2009 | AudioBahn A2300HCT Car Audio Amplifier
Red light comes on but amp still tries to kick.
Try removing the caps out of the system. It sounds like they have gone out. What is happening is the caps start storing up the power like they are supposed to do but then they are being discharged as soon as they are full. Bypass the caps and that should correct your problem.
Mar 14, 2009 | AudioBahn A2300HCT Car Audio Amplifier
Audiobahn a2300hct
check rca, faulty ground does that
Sep 02, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Red status light on no power goes to my subs
no but u only need one. it needs to be no more than 10 inches from the positive battery terminal.
Apr 20, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Wierd stopped working audiobahn a2300hct
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up normally, the wiring and speakers need to be checked. If it still shuts down, the amp likely has blown output transistors.
Apr 05, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Audiobahn A2300HCt wont work
you might not have enough power pushing the amp.... I have two batteries and two caps running
Apr 02, 2007 | AudioBahn A2300HCT Car Audio Amplifier
AudioBahn A2300HCT Car Audio Amplifier Logo
276 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Jerry Naidoo
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
