Question about Compaq Computers & Internet
Formatting C Drive and Re-Installing Windows XP - BSOD
I have Windows XP on my Compaq Presario Model: SR1720IL. Now, somehow certain Spyware came into the PC through Internet even though I had the Cyberdefender running on the PC. Now, due to the spyware the computer got a problem of restarting on running the spyware scan and on opening ebay etc.
So, I decided to reformat the C drive on which Windows XP was running and reinstall it from the CD. So, on rebooting from the CD I pressed ENTER at the ''Welcome to Setup'' screen and then pressed F8 to agree to the license. Next, there was an option to Repair my existing installation or Install a fresh copy. So, I pressed ENTER to Install a fresh XP. Now, I pressed D to delete the C Drive Partition on which Windows XP was installed then, pressed L to confirm the delete. Later, I pressed C on the un-partitioned space to create the new partition and it already showed the maximum space available so, I pressed ENTER. Then, I chose NTFS to Format the partition. After the format as I pressed enter to go ahead with the installation of Windows XP on C Drive just a few seconds later a Blue screen appeared showing: A problem has been detected and windows has been shut down to prevent damage to your computer.
Page_Fault_In_Nonpaged_Area with the Technical Information: STOP: 0x00000050 (0xE95D5618, 0x00000000, 0x8081882C, 0x00000002)
I wonder why it showed that Windows has been shut down because I had already formatted the C Drive containing the Windows XP and its reinstall was still in process.
Now, later I realized that my system was a FAT32. So, I again did the same procedure and converted it into FAT32 from NTFS but still the same screen appeared and I am unable to install the Windows XP any longer. The system's hardware is absolutely fine because I had started using it a fresh since 2 weeks back only, and it was doing wonderfully well before that spyware came in.
Please help me, what to do next as I have never seen or heard of such an error earlier. Also, I had stored my DATA from C Drive to E Drive how can I access that?
  • nauratanshar Apr 16, 2009
    Dear Balajik,
    Please go through my problem properly, I already did what you are suggesting now, and was unable to execute it, only after which I have put up this question on this Forum.
Just take a backup c drive and profile documents
and format the c drive and install the operating sysytem
Posted on Apr 16, 2009
BSOD and shutdown on Miniclip
XP does that, loves to.
for sure bad memory.
why run XP? why run with no SP3, that be super bad idea. of all
XP was demo's by GILL BATES on stage and it BSOD'd
2001 year.
this OS is not supported by anyone, not MS nor HP.
its DEAD.
try upgrading shock wave?
pray.
reload XP, or better 1000x better UPGRADE IT?
XP H3LL is and endless topic. see the upgrade disk?
http://pcdied.com/he%27s%20dead%20jim.html
Jul 04, 2017 | HP Compaq Presario 2100 Laptop
I formatted my hard drive somehow and cant access windows, how can i get into my hard drive? compaq presario 2100 laptop
If you formatted your hardrive you don't have windows anymore. The format erased it. You'll need to get your Windows CD out and re-install.
Nov 15, 2009 | Compaq Presario 2100T Notebook
HELLO
Boot your computer with winxp disk then enter in recovery console mode.
Then type in command prompt 'chkdsk /r"
then press "y"
then it fix error on harddisk .
then try again try 3 to 4 times deleting c and format it you done it.
Aug 18, 2009 | Microsoft Windows 2000 Professional Full...
Sound driver installation failed
Maybe the sound driver is not designed for you OS or hardware. You can check the compatibility before installing.
May 03, 2009 | Compaq Presario Notebook
Compaq presario r3000 amd athlon laptop cuts off after 10 minutes
from my experience this might be one of two things...
if it's shutting down while you're installing windows, i'm thinking you might have a problem with the motherboard channel for your CD drive. i saw this happen to a computer at work - we couldn't install windows because it cut off halfway through and blue screened on us.
it might also be a case of a bad hard drive, if you have any testing utility like drive fitness test i'd give that a shot. it sounds like a new one, but they're bad out of the box sometimes.
hope this helps
Jan 15, 2009 | Compaq Presario R3000 Notebook
Compaq v2000 sound driver problems
Try to download microsoft update Kb888111 first run this and than run the sound driver that you get from Hp site should work.
Nov 02, 2008 | HP Compaq Presario V2000 Notebook
Installing windows xp to compaq presario 700 pc notebook
HP Compaq Presario 700 series was originally designed for XP and Vista, therefore you can install XP on it.
After installing Windows XP, you will need to install all drivers.
You can download drivers and software for your laptop from HP here.
Oct 07, 2008 | Compaq Presario 700 470024-192 Notebook
Fireball lct 40 gig friend opened Hallmark email virus on computer. will not run XP
There is a freeware program out there cald 'KILLDISK " that will write 1's & 0's to the HD once and wipe the hard drive - then reformat the HD and start over - I just did this on a compaq 6330 for my buddy using the old **** QML20000LD-A Fireball LCT20 - this HD stinks and it has 1990 size 128kb Buffer and a slow 4500RPM speed
Aug 15, 2008 | Quantum Fireball Lct20 (QML20000LD-A) 20...
No sound can
hello. sir. i have lost sound from my lap top Compaq presario C700 after installing windows XP. kindly help me. my laptop is also showing pproblem during installation of hard drive for same driver, every time i turn on my laptop. i donot have the installation mother board for the same laptop
Jul 13, 2008 | Compaq Ensoniq AudioPCI Sound Card
Drivers for HP Compaq Presario V2000 laptop
pls send compaq notebook presario v2000 audio driver
Jan 08, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
97 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
