Question about Welding Tools
Can you help with the settings on this mig welder
Can you describe the settings for a cosmo 170 gas/less mig welder
Can you explain what settings you want to know
http://www.mig-welding.co.uk would be where I'd go
Posted on May 09, 2009
Ihave a cigweld wire wasp gasless mig welder it gives me a lot of spatter how do you change it to positve earth?
change the position of the earth strap at the front of the unit
there should be two terminals one marked - and one +
normal gas welding is -, gas less welding is +
Oct 25, 2016 | Welding Tools
I have a hobart beta-mig 170 welder that I just put a new wire feed motor on but still won't work. The old motor I could tap on every now and then until it just quit. Any ideas?
Check the Switch on the handle. Many times the two wires from the trigger down to the Mig Unit break or get a bad connection
Jun 01, 2015 | Hobart Welding Tools
Would like to know how leads hook up
for normal wire on gas the + wire is the hand electrode
the - terminal ( clamp )goes to earth on the job
when using gas-less wire in a mig the wires are connected in reverse
when using a stick hand piece in the mig the stick hand piece is on the + terminal , the same as gas less wire
all of this would be in your user hand book or can be down loaded for your machine
May 18, 2015 | Welding Tools
Why wont the wire come through my cosmo gas gasless welder
Most mig welders have reversible feed spools. There is a good chance you have the spool in the .030 wire side. Remove the spool retaining clip and flip the spool to .023 wire for example. I don't know what size wire you are using. Also there is an adjustment for the drive spool. Tighten the tensioner spring thumb screw to increase the feed tension.
Apr 28, 2014 | Welding Tools
Rossi 220BZ Gas/Gasless Inverter Welder MIG MAG ARC Portable Welding Machine
The Rossi 220bz mig welder comes set up to use gas welding, that is with the Mig electrode connected to the positive terminal, inside the machine.
To use gasless mig wleding, the mig wire must be disconnected from the positive terminal inside the machine and reconnected to the Negative terminal - inside the machine. Open both the side coveres of the welder using a phillips screwdriver. Use a 13mm spanner to undo the hex nut holding the thick copper Mig lead to the terminal named positive, then lead it through the machine to the terminal on the oppisite side of the machine, labelled negative and screw it in place there with a 13mm hex screw. Be carefull not to bump any of the many electric parts inside the machine.
If you run the Mig welder in gasless mode with positive earth and positive elecrode it will blow the household electric fuse.
If you run the Mig welder in gasless mode with negative earth and positive electrode it will work, but the end of the Mig gun tip will get very very hot and start smoking abnormally from excessive heat.
But if you take the side covers off and rewire it (takes about 10 minutes) to negative Mig Electrode, the Mig gun tip remains cool and does not overheat. You will have to cut just one white cable tie, to get an extra inch or so of free Mig cable, so the thick copper Mig lead will reach accross to the terminal on the other side of the machine named negative. Stick the earth lead at the front in the positive terminal.
I did this on my Rossi 220bz mig welder.
http://www.weldequip.com/gasless-mig-wire.htm
Jun 25, 2013 | Welding Tools
Same problem here...using proper gas, more heat (setting 4) should penetrate better, no? have lots of flow from blueshield 8 bottle. What gives?
Your machine is rated for less than 1/8" thick metal welding. The only way you can have a depper penetration is by using innershield wire instead of metal core one. Innershield wire does not require gas and it will melt at lower heat.
Dec 31, 2010 | Campbell Hausfeld WG2060 Mig/Flux Versa -...
The Mars 180 MIG Welder Manual neglects to
Hi mate. Not sure on the power settings but the earth clamp is negative for gasless and possitive when useing gas
Mar 20, 2010 | Welding Tools
Instruction book required for welder
I didnt see a betaMig 170 model, but the manuals should be similar for the other betamig manuals. Here is the link:
http://www.hobartwelders.com/service/owners-manuals/
Aug 07, 2009 | Hobart Handler 140 Mig Welder
Welding Tools Logo
241 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
