Question about Logitech diNovo Edge 9676850403 Keyboard
Not charging Brand new out of the box. Put it on the cradle, keyboard lights up briefly and the battery charging indicator flashes. Seems good BUT ... a few minutes later ... charging indicator is showing steady green (i.e. "charged") but battery is indicating only 1/4 charged. :(
  • 1 more comment
  • Anonymous Jan 24, 2008
    iv got the same problem. i took mine out of the box and put it on charge where i left it for 24 hours and it stil wont work out of the charger
  • Buddy57 Aug 05, 2008
    Same problem. Been charging for 3 days and only works when in the base. Charging light only flashes red and when I remove it from the base it doesn't do a thing.
  • Rikkert Oct 02, 2008
    Same problem, suggestion does not fix the problem
Try to turn on the Keyboard.
There's a switch in the right side of the Keyboard.
For more information download the User Manual at Logitech Site
Posted on Nov 06, 2008
  • 70 Answers
Try leaving it to charge overnight.Takes longer than a few minutes to charge and indicatores are rarley 100% correct
Posted on Sep 17, 2007
Yeah it's the power button on the right. Same problem here - problem exists between keyboard and chair.
Posted on Mar 20, 2009
SOURCE:
Mint Plus Turbo Charging Cradle won't function properly
Cradle and contacts are fine. Cradle circuit is nothing but a reed relay and few wires, relay closes on proximity to robot's body, therefore no voltage on contacts before robot is close to cradle.
There is a thermistor inside of battery, and mine was bad. I removed it and now I am charging the battery from my bench power supply at about 220 ma current, overnight, and it works. Probably the solution is to get a new replacement battery, but the one with the thermistor inside (OEM), easily recognized by the third wire, and all should be fine, assuming that nothing else is wrong with charging circuit or power adapter (12v/1A)
Hope this will give you some ideas of where to poke.
Once successful, please post your solution.
Jan 19, 2013 | Mint Plus Turbo Charging Cradle
Panasonic cordless phone rings, but when you answer the phone goes dead
Check the charging contacts make sure it is charging when in the cradle. If problem is remove the battery and let it stand for one minute than re-plug battery in unit place briefly in cradle, until display and or charge indicator lights up . Try making a call . IF ALL ELSE FAILS RUN TO TOP OF HIGH RISE BUILDING THROW HANDSET TOWARD EMPTY PARKING LOT !! BUY a BETTER QUALITY PHONE S#&@T HAPPENS
Sep 01, 2012 | Panasonic KX-TG1100 Cordless Phone
Remote not charging?
the battery can be charged whenever you want to charge it. There may be an issue with the cradle. can you please follow steps below and reply back with the answers?
1) Ensure the cradle is plugged into an active AC outlet and the LED light on the cradle is on. There is a switch on the bottom of the cradle to control the brightness of the LED, set it to the highest. Try different outlets if needed. Does the LED light turn on and stay on (does not blink)?
ANSWER:
2) Remove the battery. Place the remote on the cradle and check the LCD screen. The LCD screen should display a 'White' screen with possible colors before going off. Try this a few times to confirm behavior. Did the LCD turn on briefly?
ANSWER:
3) Reinsert the Battery. Have you charged the battery for at least 3 hours? If no, please recharge the batteries for at least 3 hours.
4) Did the battery ever boot the remote? If yes, please continue troubleshooting.
ANSWER:
5) Remove the battery. Check the 3 gold contacts on the battery to see if there are markings on all the contacts signifying it was connected correctly to the remote. Did the battery have markings on all 3 contacts?
ANSWER:
Jan 14, 2010 | Logitech Harmony One LCD Touchscreen...
My Logitech Dinovo Edge is not recharging. When I put it in the charger the battery charging indicator light flashes red instead of green.
Were you having problems with short battery life before this happened? Most of the time if the battery is not recharging it needs to be replaced. Have never seen the red flashing light before though. It may mean that the battery has shorted out.
Jul 24, 2009 | Computers & Internet
Phone charging indicator shows when in the cradle, but there seems to no power when taken out of the cradle.
If it shows it's charging and doesn't actually charge, then the battery is no longer good. It's probably a NiCd battery and they only last a few of years depending on the charge/discharge cycles. Hop down to Wal-Mart for a new battery, or Radio Shack if it's a hard to find one.
Oct 29, 2008 | Lands Phones
EX S880 not charging
you have a bad battery common when the battery sits to long with out being charged they are like 5 bucks on ebay.
Aug 05, 2008 | Casio Exilim EX-S880 Digital Camera
Digimax i5 problem charging battery
■ Charging LED
Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
 Green LED is on = Charging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
If the charging LED doesn't turn to green could mean a signal that the battery is bad or can't charge 100% anymore = too old, needs a new battery. Hope this helps.
Jul 06, 2008 | Samsung Digimax i5 Digital Camera
Samsung battery
Green:Fully charged
Amber:Improper connection
Red:Charging
Sep 04, 2007 | Samsung SCH-i730 Pocket PC
Logitech diNovo Edge 9676850403 Keyboard Logo
1,220 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
