Question about Dirt Devil V6 Canister Vacuum
Opening up Centrixx V6
I'm trying to figure out how to get into a Dirt Devil Centrixx V6 Canister cleaner that suddenly cut out and went dead in use. The fault may be the connection of the power cord in the cord spooler that got damaged when it was pulled out too far.
I've removed all the screws that are visible and one at the back under the tube support bracket that isn't, but the top cover doesn't feel any freer.
Are there any other hidden screws - like behind the wheels? If so, how do you get the wheels off? I've taken the trim disks off the wheels, but nothing shows underneath. Are there screws under the cord release or power buttons? Or is it just glued together?
Any help would be really appreciated. Thanks.
  • BarryVac Apr 18, 2009
    I've now worked out for myself how to dismantle the Centrixx V6 Dirt Devil for maintenance, if anyone else is interested it may be of use to them too.
    Remove the canister
    Lift out the 'D' shaped plate beneath it, by prying from the straight face.
    Remove screw and washer beneath this plate.
    Remove larger and two smaller screws from top of front of the base.
    Remove the silver 'D' shaped support bracket on the back of the cleaner (used to store the cleaning tube and brush head) by removing the single fixing screw through it.
    Remove the screw to be found in the deep, recessed hole beneath it. It is captive, so you won't lose it.
    Remove the cord retraction and power buttons by inserting a slim, flat blade screwdriver or similar between the back narrower edge and the body about 1 cm (1/2 inch) in and pressing the tip of the screwdriver gently to the front to release one of the 3 holding hook tabs. The buttons can then be removed completely by manouvering the other two hook tabs out.
    Remove the screw to be found in the recessed hole beneath each of these (also captive).
    Lift top away.
  • BarryVac Apr 19, 2009
    The above comment is the solution.
I live in Israel. My vacuum cleaner broke down. Where can I fix it in my country.
Posted on Jan 06, 2011
Dirt devil turbo clean sd40060 Cyclonic vacuum. Was given it as a present. Floor tool won't spin. Checked everything! Belt, for hair through out. All ok. Why isn't it working?
You should find a large button or flap on the floor tool. This is usually spring loaded and needs to be OUT. This should then let air in to drive the turbine which drives the spinner.
Check out Vacuum Cleaners Upright Hand Stick Canister Vacuums Dirt Devil
Aug 08, 2015 | Dirt Devil Vacuums
Won't turn on
change the switch with a brand new one and that will fix the problem the switch has gone out on another dirt devil vacuum and that is so common it is hard to explain it is a defect in the way the switches are made
Mar 17, 2014 | Dirt Devil SD30035 Express Bagged Canister...
No suction in vaccum cleaner
Look for a clog somehere in the intake path, perhaps right at the top of the canister.
Feb 13, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Latch on my dirt devil total pet canister to empty is stuck. how do I make it open
I bet I have the same problem as you. My vacuums canister was put back together backwards and now will not move far enough to click unlocked. I am not sure how to fix this and I cant find anyone on any forums who do :( If you figure it out post it! So far ime just trying to muscle it open.
Mar 26, 2012 | Dirt Devil Breeze Bagless VacuumVacuum
I have a Dirt Devil M130000 I Dual, which just shut off.
yOU MIGHT TRY LOOKING DEEP INTO THE DEVIL PAST THE CANISTER INTAKE AS THIS IS WHERE THEY CAN GET A HUGE CLOG THAT YOU CAN'T SE UNLESS YOU STICK YOUR HAND WAY IN THE UBE. DO THID WITH THE DEVIL TURNED OFF. CHECK FOR A SHORT IN THE CORD AS WELL BE SAFE FIRST.
Jul 23, 2010 | Dirt Devil M130000 ''i'' Dual Cyclonic...
Need a users guide in english for my dirt devil M2614-8
Motor hot and stopped. How to start the vacuum cleaner again?
May 10, 2010 | Dirt Devil V6 Canister Vacuum
Dirt devil easy steamer need directions to use
Thank you for responding to my question. I should have spent some time really looking at my little machine. It wasn't hard to figure out -once I found and read the back of the cleaning solution bottle and tried my luck following the water to cleaner ratio.. Opening, adding the cleaning solution and water and re-closing the reservoir was pretty easy. Everything worked out fine...and my carpet is...spotless. Thank you, Cmarie
Mar 27, 2008 | Dirt Devil Easy Steamer Upright Wet/Dry...
My dirt devil featherlite vacuum cleaner
that vacuum is self adjusting it will do it by itself
Jun 11, 2007 | Dirt Devil M085570 Bagged Upright Vacuum
Dirt Devil V6 Canister Vacuum Logo
268 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Nick Olsen
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
