Question about Quantum SuperLoader 3 LTO-3 Tape Drive
Elem Table Bad (2B) error
Quantum Superloader 3 showing elem table bad (2B) error. How do I fix it?
    Problem Solver:
  • 16 Answers
The element error usually points to the drive, the best thing is to do is run the full diagnostics for the drive, and see what other hardware codes you receive, if it still points to 2b, then it is either the drive or the solenoid of the magazine failing. If you have a two magazine setup, just reverse the other magazine and test it that way.
Posted on Jul 20, 2009
  • SirEbrum Feb 03, 2017
    Each position in the library is an "element" to software. If there is an inconsistency, this can be the resulting error.
    1. Always make sure you're at the latest compatible level of library FW.
    2. Make sure you haven't missed a hotfix or driver update from your software manufacturer.
    3. Attempt an Inventory from software.
    4. Power cycle the unit.
    ...and once you configure the library (i.e. Set to Random Mode, use a Cleaning Slot, etc.) leave it alone, as these alter the positioning of the element addresses in the library. If you, or anyone, alters the library configuration, expect problems if you don't follow up with a reboot and software reconfiguration to match the changes
My Ca Arcserve is showing that the quantum superload is constantly busy. I can not do anything as it also says that it is busy. I have shutdown and restarted the quantum drive a few times and all still...
power down both the library and computer, disconnect the library, power up the library. Check the operator panel of the library for an online ready status.
Jan 13, 2011 | Quantum SuperLoader 3 LTO-3 Tape Drive
I am getting a DRV PREV REMOVAL TYPE (46) message on display, every time I try and Inventory a tape or run Lable Media.
I have two of these Quantum SuperLoader 3 (with LTO3 drives) and one does keep giving me the same hassle. I haven't figured out how to fix this, but I've gotten past the error: disconnect the autoloader from the host computer (i.e. or stop rsm, mtx, or whatever controlling sofware you use), reboot the autoloader, get the tape out of the drive (e.g. move command from the autoloader's console or web interface), insert a cleaning tape (a few times), reconnect everything (i.e. start back up your controlling service).
Nov 29, 2010 | Quantum SuperLoader 3 LTO-3 Tape Drive
Superloader3 , don't recognize real capacity of tape
this may be a limitation on your motherboard. please check if your motherboard supports this much capacity. If you have another pc or laptop that is about a year or two, check if they would recognize the the capacity of the drive correctly. if not you may want check with quantum about their drives.
Jun 19, 2010 | Quantum DLT-V4 DLT Tape Drive
Quantum superloader not showing in windows device manager
First off, I have to say that I have had nightmares with Quantum tape libraries. It is possible that they are still manufacturing lemons. I had one replaced 4-times and it still did not work!
Start troubleshooting by making sure that it is identified by the controller card it is connected to. You should see this during the server POST before Windows starts. If you don't see it there then Windows definitely won't see it. Send it to Quantum for service.
If the controller sees it then make sure that you are using the Backup Exec drivers. Never use the manufacturer's drivers with Backup Exec. Veritas, now Symantec, has a downloadable utility called the Device Driver Installation Wizard that will make sure you have the correct driver loaded.
I hope this helps.
Nov 13, 2008 | Quantum SuperLoader 3 LTO 2 Tape Drive
Quantum Superloader remove jammed tape
You have to disassemble the unit and remove the tape. Chances are it's stuck in the carousel (the round thing at the front that spins tapes and plugs them into the drive).
May 06, 2008 | Quantum ATL SuperLoader Ultrium Tape Drive
Aeg competence b 8139-4-m - oven not heating up
your heating element is probably bad. all u have to do is, make sure the oven is off, pull elem. away from it's holders on the top or bottom of the oven, then pull the elem. loose from it's sockets then, straight out of the oven. take to home depot, or lowe's, or an used appliance store. installation is reverseal.
from sid
Apr 20, 2008 | AEG B2100-4 Electric Single Oven
Loading Media
Same problem with Backup Exec 10d and Superloader 3 LTO-3.
This is not my first problem with this Superloader. I think it is garbage and will likely be in the garbage very soon. Very expensive garbage unfortunately.
Mar 05, 2008 | Quantum SuperLoader 3 LTO-3 Tape Drive
Getting error message "Bad element"
you have to open the bottom and turn the motor or gears , just be sure to turn the cartridge gears too to wind the tape back in
Jan 18, 2008 | Quantum SuperLoader 3 LTO-3 Tape Drive
Quantum SuperLoader 3 LTO-3 Tape Drive Logo
4,278 people viewed this question
Top Quantum Computers & Internet Experts
Jax Planet
Jax Planet
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
