Question about Refrigerators
Wot setting do l put my freezer at 1, 2 or 3
L have a whirlpool fridge freezer and l dont now what setting to put the freezer at is it 1, 2 or 3
    Genius:
  • 1,122 Answers
If it does not tell you then you should put both dials(if you have 2) in the middle setting,say you have 1,2,3 for the freezer then set it on 11/2,same on the frig side-mike
Posted on Apr 16, 2009
What number do i put my leibherr fridge freezer on and why do they have numbers 1 3 5 9 if you dont use them what are they for
Most thermostats need to be set at mid scale. Set yours to between 3and5. The reason for the other numbers is for some uses a warmer temperature or a colder temperature is needed. For most freezers thermostats set to mid scale will control temperature to around 0 degrees Fahrenheit.
Hope this helps!
Apr 17, 2016 | Refrigerators
Ice maker quit working
Brenda, try the following.
1. disconnect power from the wall.
2. open fridge and freezer doors and leave them open for at least 5-6 hours. salvage foods you can.
3. after a few hours you will see a puddle of water under the fridge.
4. clean the floor and the fridge and freezer of any collected water.
5. power up the fridge and set at recommended level say 4.
6. you will hear humming noise. Let the fridge and freezer cool.
7. dont overload food.
good luck
Apr 08, 2014 | Whirlpool : GX2FHDXVY 22 cu. ft. Bottom...
Whirlpool SXS.....1. compressor cooling fan quit so fridge and freezer stopped working. 2. replaced cooling fan and fridge and freezer working again. 3. Now the fridge and freezer works but runs nonst
Check to see if the sensor in the freezer compartment is encased in ice. If so, do a complete defrost and restart the unit. Another possibility is a bad thermostat and/or sensor.
Jul 25, 2012 | Whirlpool Refrigerators
I bought a whirlpool fridge freezer last two weeks it was working fine but i noticed that the freezer is making too much ice when i set it at temperature 7 which is melting and i keep seeing water under...
Water under it is fine as long as it is not on the floor. It should be in a pan that came with the unit. You should have 2 temp setting for the unit..1 for the freezer and one for the frid. set the freezer for 5 to start. and then set the frig at 5. and adjust only the fridg side after a few hours. If this does not wrok call the place you bought it from as it may have a bad swthch on the indoor fan or a bad flapper door that allows cold air from the freezer to cool the fridg. But you have to start at mid range and adjust only the fridge side moving it up or down buy 1 number at a tiem.. Let me know know. I hope this helps Jon
Aug 13, 2011 | Whirlpool Heating & Cooling
I have a fridge/bottom freezer fridge and i would like to know at what temprature i should set my fridge. Its a manual setting ranging from 1 to 7. which is the coolest setting?
#1 is warmest going colder as you go upto #7.fridges should be set at +3C,adjusting the control for summer and winter.you could do the lettuce test,if it goes soggy/black,its too cold.
Jan 25, 2011 | Whirlpool Refrigerators
Hi We have a whirlpool side by side no ice maker in the past week the freezer is cold and frosty fridge is warm up to 15degrees at the top bottom of fridge is 5 degrees. Top vent from freezer is not in...
3 things
If you have ice on the freezer side.
1. defrost timer not working
2. blower fan failed, if it has one
3. defrost limit switch failed..
i dont think it is #2 but 1 or 3
last but not least your defrost heat coil has failed
Dec 18, 2010 | Refrigerators
I have an integra fridge freezer arl 7561g. one control only in fridge. how do i defrost the freezer and wot setting numbeer would i use in the fridge.thanks alot.
hi barbra,just turn the unit off at the mains and let it defrost NATURALLY.(dont use a hairdryer)best left for 24 hours to clear ALL the ice.then clean out and dry,(use bicarb to clean)when fully defrosted, turn on,and let it return to cold then use a fridge thermometer to set the fridge at +5c (keeps lettuce crisp not soggy)you may have to turn the setting up/down depending on ambient temp in room.
A full defrost should be done even if "frostfree"at least yearly(gives you a good excuse to clean out the unit).regards.geoff.
Nov 26, 2010 | Refrigerators
Compressor overheated and shut down.
Pleas put setting in the middle and give it 24 hrs and check temps
freezer would be good at 0 to 10 f
I thing you have the damper door closed.
May 24, 2010 | Whirlpool GS6NBEXR Side by Side...
Whirlpool intgrated fridge/freezer is not keeping
7 is coldest. but how cold is the freezer? all cold is made in freezer. ma be developing a frose problem
Jul 06, 2009 | Whirlpool ED2GHEXN Side by Side...
Refrigerators Logo
64 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
