Question about Toastmaster T2070W Cool Touch 4-Slice Toaster
How to remove bottom panels for cleaning Toastmaster Model T 2070
    Brigadier General:
  • 5,158 Answers
There should be a small clip or small metal piece that you move so that the doors swing open to clean.... open it over the kitchen sink tho as it makes quite a mess
Robert
Please take a moment to rate this solution thanks
Posted on Apr 16, 2009
How do I disassemble a Toastmaster Toaster Oven model 340B to access the controls/wiring/switches section?
You can't. The lawyers think it is too risky for consumers to attempt repairs. Even those who are competent to do so.
Jan 14, 2017 | Toaster Ovens
Is there a manual for easy clean waffle baker toastmaster 218?
http://kitchen.manualsonline.com/manuals/mfg/toastmaster/218_287_378518_and_287.html
Jul 19, 2014 | Toastmaster Kitchen Appliances - Others
I have a GE Profile Spacemaker PVM 2070 SMSS and the button pad needs to be replaced for the vent and lights. Can this part be purchased?
Sadly on the 2070-series models, GE does not make separate parts available for the controller.
Only the control panel subassembly is available, and these range from a few hundred to several hundred dollars, depending on your full model number.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can download GE owner's manuals and installation instructions here.
Jan 17, 2011 | GE Profile Spacemaker Over-the-Range...
Do they still make this machine? I have one that is probably 13 or 14 years old and LOVE IT. However, my problem is the bottom of the pan has gummy stuff on it. I clean it off and use it again only to...
Your pan and seal are starting to disintegrate. I have a older model toastmaster in almost new condition. If interested I can sell to you via paypal. You can try it for 7 days and if you don't like it you can return it. Let me know if you are interested. It's not a 1142, it is a toastmaster 1170S, "corner bakery" model,,,,supposed to make butter too but I don't have the little butter lid, but you could still make butter with it. Toastmasters are my favorite too. They are quiet and have heavy duty pans.
daryl441@msn.com
Jan 11, 2011 | Toastmaster 1142 Bread Maker
I have a toastmaster t80bc and the clear plastic part that locks down the handle on the inside popped off, anyone have a pic or diagram of how it goes back on. Nothing is broke it just came off and its...
yes I got the same problem, I Fix myself.(model T80BC)
unplug main power cable, remove top cover (remove 4 screw from the bottom and knob from the side)disconnect control panel cable from main board.look at the attached picture.in the photo close to power cable connector will see a slot
(look at the black arrow mark pointed ).insert plastic switch to this slot, make sure both side properly mounted.then move toaster push down lever up and down. it should move as usual without any obstruction. now put back control panel cable and top cover,knob,and all the screws. plug cable into the power,it should work.
see switch
Feb 26, 2010 | Toastmaster Kitchen Appliances - Others
Repair of 1939 Toastmaster Toaster Model 1b6
remove bottom plate.....remove 10 screws holding the bottom brown plastic base...loosen screw under push down lever....romove light, dark knob small center hex screw....cover will now lift off....gently....watch #20 toast "wires"
May 04, 2009 | Kitchen Appliances - Others
Lid removal
You have to disassemble the outer case to get to the screws.
Mar 14, 2009 | Toastmaster 1148X FastBake Bread Maker
CLEANING THE TOASTMASTER WAFFLE MAKER
If the plate are not removable, clean with soapy rag. Otherwise remove and clean with warm soapy water. After drying, re-oil with light coat of cooking or olive oil.
Mar 08, 2009 | Toastmaster 234 Waffle Maker
BISSELL QUICKSREAMER MODEL 2070
Here is a link, don't know if it will work for you or not:http://bissell.com/images/UserGuides/1960.pdf
But you put you cleaning solution along with hot water in the upper tank, the bottom tank sucks up the water as you clean. Pull the trigger to dispense clean while pulling it back towards you, push it forward and repeat until done. If that link doesn't work, you can call Bissell and order a operator manual.
1-800-237-7691
Mar 17, 2008 | Bissell 1770 Quicksteamer II Upright...
Toastmaster T2070W Cool Touch 4-Slice Toaster Logo
119 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Oscar Netto
Oscar Netto
Mohamed Ismail
Mohamed Ismail
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
