PC model X1700 won't turn on It self shut down night before last and when I turned it on it sounded rough for awhile but ran OK, This am its off again and when I hit the on button I get just a blip of 'blue on' .I have surge protection, been sormy but before problem. Disconnected power for awhile, replugged, nata. This thing is brand new.
. does this sound like a timing problem?
Maybe. Do a compression test...
Jul 31, 2017 | Cars & Trucks
The car shut down while making a sharp right turn but fired right back up and ran albiet roughly with the check engine light flashing for about 3 miles then shut down again going up a short gradual...
Flashing for awhile?
Don't you always start will check light issues first,
& resolve them?
There are codes sometimes even without check lights
You need a professional scanner or PC Scan Software
The fuel pump may be seizing up mechanically or have an
elcetrical issue,such as worn out. Again an Oscilloscope would
be nice there also
Jul 11, 2011 | 1997 Oldsmobile 88
Had a question bout my mazda rx8 I was driving it one night it was running fine the next day went out and it won't turn over it takes awhile bit it finally starts and idles real rough and you give it...
Too many possibilities
Won't turn over is one problem -battery,cables,grounds,
starter,solenoid,etc
Idles rough-- vacuum leaks,spark plugs never replaced,
egr valve etc
Worn O2 Sensors
Dirty MAF Sensor
Old Fuel Filter
You have to go into a lot of technical detail & history
on your vehicle, for us to even guess.
May 23, 2011 | 2005 Mazda RX-8
GE Profile 30" slided in range/oven. Ran standard
shut down the power to the machine,disconnect the touchpad ribbon,turn the power back on and let it sit for a day,if the code comes back you have a bad board,if it doesn't come back you have a bad touchpad
Apr 02, 2011 | GE Profile 30" Self-Cleaning Slide-In...
Latitude d 600 locks up
Dear we have provid the solutation for best my self
just do it
1.click the start
2.click ran
3. type recent
4.click ok
secon option is use for
1.click the start
2.click ran
3. type temp
4.click ok
this two setps in all file is come to desktop in open the new windows and afrer Remove the all file.
99 % you problem is solve but not solve your problem just install the antivirus program with latest update and your pc or laptop full scan
and remove the all virus ............ok .
Mar 28, 2009 | Dell Latitude D600 Notebook
Phillips 64" PTV Issues
sounds like vertical problems see if you have bad solder connections then get back to me
Nov 02, 2007 | Philips 50P8341 50" Rear Projection...
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
