Question about OEM Systems PIXMA iP3300 Photo Printer
Usb printer problem "port in use please wait"
My new Canon ip3300 will print once after a reboot. the second print job waits..."port in use please wait" is the message. this is a USB printer. I have tried both the USB ports in the back and the front of the HP PC. bob.
  • bspurzem Sep 17, 2007
    the solution was simple...as it turned out, my old printer was still on the printer management page and its status was 'deleting'. I needed to open it, and cancel the maintenence job that was hung. Once the job canceled, the old printer removed itself. This removed the contention for the USB port and my new printer works perfect. thanks for your help. bob.
  • OEM Systems Master
  • 705 Answers
Can you advise which operating system you are using? Assuming 32bit windows: Unplug the printer from the USB and try deleting the printer from the printers folder. Then download the latest driver from the Canon web site. Once you have you have it, in the control panel go to SYSTEM and into HARDWARE tab and then DEVICE MANAGER. Look under UNIVESAL SERIAL BUS CONTROLLERS and check that there are NO yellow symbols. If there are yellow symbols you need to remove the offending item from the list (making a note of it's description) and then reboot your machine. When it comes back up it should advise that new hardware has been found and go through the process of installing the drivers. You can now go the manufacturers web site and download the USB controller driver for your device. If the file is a zip extract it to a folder on your PC. When it asks if it can go online to find a suitable driver, let it do so and you can also specify a location for it look (where you extracted the download above) Once it finds the driver required and has finished installing it, reboot your system and then install the printer driver you just downloaded. Hopefully this will get you back on the go. If you have a windows 64 bit system I'm afraid you are on your own. 64 bit drivers that work are very hard to come by. Let us know if this is any use to you, if not we may more to offer.
Posted on Sep 16, 2007
  • Inky Fingers
    Inky Fingers Sep 17, 2007
    That was going to be my next suggestion.... honest!
SOURCE:
My printer X5270 has lost connection. In the properties field of the printer, under the General tab the location field is blank and under the Ports tab a check is placed by the USB...Virtual port for USB....
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/nb3gkh. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 19, 2011 | Lexmark X5270 All-In-One InkJet Printer
Tip
Samsung SCX-4500W restore wireless printing on cryptic error
For those having trouble wirelessly printing to their Samsung SCX-4500W printer from a Windows computer, I have this "easy" 13-step process that usually fixes my most common printing problem:
The symptom:
You haven't used your printer in a couple of days and have just hit the print button in an application you wish to print a document from. Instead of your printed document gracefully emerging from your printer, a Samsung status window appears on your computer above the task tray, cryptically announcing "The current printer port is not supported for the current printer status". You scratch your head in complete confusion.
The solution:
  1. Go into the room where your printer is. Observe that it has dropped its wifi connection and not reconnected automatically - the blue light indicating wifi is no longer illuminated.
  2. Turn off the printer, wait a few seconds, and turn it back on.
  3. Rebooting always causes a blank page to be ejected - how annoying! Open up the tray and reinsert the blank sheet.
  4. Wait for the blue wifi light to come on.
  5. Return to your computer and open the printer job queue window. Locate your document in this window with "Error" status next to it: right-click on it and select restart so its status changes to "Printing".
  6. After a while, notice the status has changed to "Error - Printing" or "Error - Sent to printer". Since restarting the job was not successful, right-click and select cancel. Press the OK button in the confirmation dialog. You may have to do this a second time before the job clears.
  7. Return to the application you printed from and re-print the document.
  8. Double-click on the blue Samsung "S" icon in the task tray. A window titled Samsung SX-4500W Series will appear in the lower right. Observe the status first says "Please wait..." then show the same cryptic message "The current printer port is not supported for the printer status". Grrrr.
  9. Check if your computer really can access the printer by opening web browser and typing its ip address. For me, it is 192.168.1.70. Alternatively, click the "Printer Setting" button in the window of step 8. Observe that the printer reports it is alive and ready for action. This is good.
  10. Check if any other Samsung software is able to use the printer: Open SmarThru 4 software, select "Scan To", "Folder", then hit "Scan" button. Observe that scanning from the printer works absolutely fine. Close SmarThru. So the problem is just the crappy printer driver.
  11. Close any Samsung windows you have open. Navigate the start menu to Samsung SCX-4500W Series->Maintenance. The installer will run in maintenance mode and find your printer on the network (and show its ip address), as well as an option to use it on "Local Port". Select the printer on network and click Next. Select "Samsung SCX-4500W Series printer driver" to repair and hit Next. The driver will re-install. Click Finish when done.
  12. Return to your application you wish to print from and activate the printing of the document again.
  13. The Samsung status window will once again appear in the lower right proclaiming "The current printer port is not supported for the printer status". Ignore this stupid message and close the window. Go to the room with your printer and with any luck, you will find your printed document waiting for you!
Once you are well practiced at this, and can fully appreciate how useless Samsung's software developers are, you can just do steps 1,2,3,4, 5, 6,11,12, and 13.
on Mar 09, 2011 | Samsung SCX-4500W WiFi Multifunctional +...
Our Canon MX310 printer is flashing Waiting For Report and the In use/memory light is on all the time. There are not reports to print as far as we can see
  1. Remove all print jobs at your computer
  2. Turn off printer
  3. Disconnect printer power supply
  4. Wait 30 seconds
  5. Reconnect printer power supply
  6. Turn on printer
May 07, 2009 | Canon PIXMA MX310 All-In-One Printer
Printer stopped working after I cancelled a print job
Turn off your printer and completely unplug the USB cable (from both the printer and the computer). Next check if the stopped document or the later documents are in the print spooler queue. If you can cancel all documents from the queue, do so. Otherwise: from Start Run (or the command prompt)
type: net stop spooler [enter]
then type: net start spooler [enter]
This works in XP and older MS Operating Systems but I've never tried it in Vista.
If you only enter the first command, you need to reboot the computer and then take a long coffee break after logging in before trying to print again.
May 06, 2009 | HP Deskjet D1455 InkJet Printer
After docking laptop I have to add port prior to printing
I assume you're running Win Xp. Disconnect the USB cable from the docking station. Go to START/CONTROL PANEL/PRINTERS/VIEW PRINTERS. Double click on the Konica icon. In the print queue that opens, delete any pending print jobs. Go to START/CONTROL PANEL/ADD REMOVE PROGRAMS. Uninstall any Konica software. Go to START/CONTROL PANEL/PRINTERS/VIEW PRINTERS. On the MENU bar, click on PRINTER/SERVER PROPERTIES. Click on the DRIVERS tab. Remove anything that says Konica. Click on the PORTS tab. Remove ALL the Konica ports. Reboot Re-install the printer driver - DO NOT plug in the USB cable until it tells you to. That SHOULD do it. If it does not, please let me know and I'll research it further. Ed
Jul 13, 2007 | Konica Minolta PagePro 1350W Laser Printer
Open Questions:
See all OEM Systems PIXMA iP3300 Photo Printer Questions
OEM Systems PIXMA iP3300 Photo Printer Logo
19,171 people viewed this question
Top OEM Systems Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Inky Fingers
Inky Fingers
Are you an OEM Systems Office Equipment and Supply Expert? Answer questions, earn points and help others
