Question about Olympus FE-130 Digital Camera
Power supply for Olympus fe-130
Hi
Could you tell me whether there is an alternative to using 2AA batteries with the Olympus Fe-130 camera (example like the CRV3 Lithium, Batteries CR-V3 sort). Just that the 2AA batteries does not last very long and costly doing it that way. I've researched as much as I could but can't find any suitable alternatives.
Pliz help!!
Cheers
Ralph
    President:
  • 919 Answers
(In addition to the batteries provided with the camera, the following types of battery can be used. Choose the power source best suited to the situation.
AA alkaline batteries/ Oxyride batteries
The number of pictures that you can take may vary considerably depending on the
battery manufacturer and shooting conditions.
AA NiMH batteries (rechargeable batteries)
Olympus NiMH batteries are rechargeable and economical. For details, refer to the instruction manual for your charger.
(Lithium battery packs (CR-V3) and AA manganese (zinc-carbon) batteries
cannot be used.
(Power consumption by the camera varies depending on which functions are used.
(Power is consumed continuously during the conditions described below causing
batteries to become exhausted quickly.
• The zoom is used repeatedly.
• The shutter button is pressed halfway repeatedly in shooting mode, activating the auto focus.
• The monitor is left on for an extended period of time.
• The camera is connected to a computer or printer.
(The battery life varies greatly depending on the type of battery, manufacturer,
shooting conditions, etc. Because of this, there may be cases where the camera
turns itself off without displaying the battery level warning, or displays the battery
level warning sooner than usual.
The camera also has an optional accessory of an AC adapter that can be used as an alternative power source. It is model number E-7AU.
An AC adapter is useful for time-consuming tasks such as image downloads to
a computer or when running a slideshow for a long period of time.
To use the AC adapter with this camera, the optional multi-adapter (CB-MA1) is
necessary. Do not use any other AC adapter with this camera.
Note
• Do not remove or load the battery or connect or disconnect the AC adapter or
multi-adapter while the camera is on or the camera is connected to the other
equipment. Doing so could affect the camera’s internal settings or functions.
• The AC adapter can be used within the range of AC 100 V to AC 240 V (50/60
Hz). When using the shape of abroad, you may need a plug adapter to convert
the plug to match the AC wall outlet. For details, ask at your local electrical shop
or travel agent.
• Do not use travel voltage converters as they could damage the AC adapter.
Posted on Apr 21, 2009
How to recharge battery
Take the battery out of the camera, put it into the supplied LI-40C battery charger or a compatible, and plug the charger into a power outlet. If you need a battery charger, you can order a compatible charger from
http://www.overstock.com/Electronics/3-piece-Battery-Charger-for-Olympus-FE-220-FE-230-240-LI-42B/6081946/product.html
Jul 30, 2011 | Olympus FE-280 Digital Camera
I have Olympus FE-270, 7mp Camera. I bought it in 2007. I have a problem with that. since i bought the camera I can never manage to find out a battery supported with this camera. I used AA Camerlion...
You need to use rechargeable batteries only with your camera. Alkaline batteries, as you've discovered, do not sufficient power to run your camera and may only last for a small number of pictures. If you still have the user manual for your camera, you may dicover that it's also recommended in your manual to use these batteries. Modern rechargeable batteries have over 5 times more power than alkaline batteries. Here's some examples from Amazon. For international readers, here's some examples from Dealextreme. If you do decide to purchase, remember that you'll also need to purchase a charger with the batteries.
Jun 30, 2011 | Olympus FE-270 Digital Camera
Power on olympus camera
Do you experience low battery? Have you tried using brand new and fully charged rechargeable batteries like NiMH or NiCd?
May 06, 2010 | Olympus FE-340 Digital Camera
"Battery Empty" Message
extra dose 12V power pinch for 3 sec
Jun 18, 2009 | Olympus FE-20 Digital Camera
Serial number of olympus Muster-fe-100
This software supplied with the camera does not need a serial number usually.
However the best advice I can offer for Softwarer supplied with cameras is to leave it in the Box
Windows does not need it to access images and there is plenty of better software for image manipulation available free for example Google Picasa
May 29, 2008 | Olympus FE-100 Digital Camera
Olympus fe 130
Ive had the same problem with my camera and found that it was the quality of the batterys. you have to use good quality high drain batterys for digital cameras.
Nov 02, 2007 | Olympus FE-170 Digital Camera
Olympus fe-130
This need looking at - Check Olympus Tech Help- especially if it is a recent purchase
May 22, 2007 | Olympus FE-130 Digital Camera
Olympus FE-130 will NOT focus
It sounds like the focus motor in the lens is jammed. This could be caused by a knock or possibly sand. You could try tapping the camera (not too hard...). This might free up the motor the only other solution is to take it to a shop.
Apr 14, 2007 | Olympus FE-130 Digital Camera
Olympus FE-130 Video Playback has no volume..............PLZ HELP!!!!
well did u use zoom while u made the videos???? if u did forget because the camera while doing zoom doesn´t record sound, u didn´t use zoom, probably the camera microphone needs to be replaced.
Feb 09, 2007 | Olympus FE-130 Digital Camera
Olympus FE-130 Digital Camera Logo
112 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
