Question about Toshiba Satellite A105-S4004 Notebook
Start up problem
I was watching a DVD and it starts shutting down by it's self when I had it plugged in to the wall. When I hit the power button the battery indicator light flashes and nothing happens. I put a battery in it a week ago and now the battery light does not even flash. I't won't turn on at all.
    Problem Solver:
  • 17 Answers
Hardware failure....take in for repairs...possible motherboard issue. JJ
Posted on Sep 16, 2007
SOURCE:
E3 error on LIfesmart heater
Even after replacing thermostat and motherboard offered from company, my heater would trigger e3 error code and shut off. After several (maybe 100!) different attempts to plug in and operate, here is what worked for me!
Depress the power button on the heater while plugging in to wall circuit. Continuously depress power button. It will run through a test cycle and attempt to start. Keep depressing the power button as the heater tries to start, then shuts down with e3 error. While the power button is still depressed, unplug the unit from the wall. When I plug back in the wall the E3 error is gone. Good luck
Nov 03, 2012 | Lifesmart DYNAMIC 1000 to 1100 Square Foot...
Blue led power light blinks even after shutdown
What operating system are you using? When the power led continues to slowly blink, that means that the laptop is in standby mode and not fully shut down. In Vista, if you hit the power button on the laptop or the power button under the start button, it is configured to go to standby and not shut down. Make sure to hit the arrow all the way to the right and select shutdown from the list of dropdown options.
Aug 28, 2009 | Gateway Computers & Internet
6210 Stuck in self test mode
Perform the steps provided below.
  1. Unplug the power cord from the HP All-in-One.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while plugging in the power cord to the HP All-in-One.
  4. Release the buttons after the HP All-in-One starts up.
  5. The HP All-in-One will now be reset to factory defaults.
AFTER PERFORMING THE STEPS IF THE ISSUE PERSIST FOLLOW THE STEPS PROVIDED BELOW.
  1. Press the Power button, and turn off the HP All-in-One.
  2. Unplug the power cord from the wall outlet.
  3. Unplug the power cord from the back of the HP All-in-One.
  4. Wait for 20 seconds.
  5. Plug the power cord into the wall outlet.
  6. Press and hold # and 6 while plugging the power cord back into the HP All-in-One.
  7. Turn on the All-in-One by pressing the Power button (c01150476.jpg ).
Aug 21, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Help
go to sharpusa.com and click on support, they have all the model airconditioners and all the help. its in pdf format and i dont know how to paste the info. really easy problem to fix.
Basically, tells you to make sure air filter is clean.Unplug from wall, then hold Power/on/off button down and plug unit in wall. press Power/on/off button until you hear a beeping sound(approx 5 sec) then disconnect powerplug from wall. plug back in and start your ac again. it should work!
If this dont work try the same thing but by pressing the Mode button and same kind of operation as above, but the unit will start to operate after you press mode and herar the beeps. turn off by pressing On/off button. then start as normal. if you cant get it go visit the website.
Jul 16, 2008 | Sharp ENERGY STAR AF-S60FX...
GT5032 W/XP Media Edition
Try unplugging and opening the PC and removing the mainboard battery. *It's about the size of a quarter, a little thicker though" Hit the power button about 5 times. (Mind you this will reset ther board to factory settings and you will have to go into set-up and set the time back) plug the pc back up and you may be in buisness.
Hope this helps!
Jul 02, 2008 | Gateway GT5032 (827103078121) PC Desktop
I have a Panasonic EH100 HDD/DVD recorder. Yesterday I left it on for several hours playing a DVD when I realised I switched it off. Shortly afterwards I turned it on to watch a program and it went into a...
Holding certain buttons down at power up can activate unintended test modes. Wrong sequence can lock up processor! Unplug and let sit for 24 hours to re-set processor. Turn set on as normal. If you can, remove DVD before this procedure to avoid reading at start up
Apr 21, 2008 | Televison & Video
DVD Stuck in Player
While the above problem is not in the manual, I would try pushing and holding down the Open/Close buttton for an extended period to see if the unit will 'unlock' itself.
Mar 16, 2008 | Sanyo DWM-390 DVD Player
Downloading new version 6 to my roadmate 700-760 gps
I had a very similar problem downloading the new version for my roadmate 700 as well. I chose to shut system down .I then unplugged everything. I reinstalled the dvd into my computer.I powered up the roadmate700 and hit the enter button and the screen came up to pick user I hit user one. I plugged the USB calble in and started the download again and it worked out for me just fine. I hope this works for you also. Good Luck
Dec 21, 2007 | Magellan RoadMate 700 GPS Receiver
My dvd Player started turning itself on and off all by its self.
don't bother fixing it, bring it back to store. You'll void any guarantees by tampering with it. Most likely the power button is damaged in some way. These are not repairable.
Oct 10, 2007 | LG DN191H DVD Player
Can't find codes for the remote
is it a universal remote? if it is, then you can look for the code manually. hit code search button and hold it down and then hit the source button. in this case it is a dvd. then let go of the sourch button and then let go of the search button. you have to do all the while the dvd player is on. then start hitting the power button till the device shuts down. his set button/or some remotes enter button and then you should be able to use that for the dvd player. good luck
Apr 22, 2007 | Samsung PCK5315RX TV
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
102 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
