Question about Brother HL-2030 Laser Printer
Paper starts to feed then stops after feeding about 2 inches
Hi, i have a brother hl-2030 printer, i cannot get rid of the drum error, i tried the drum on another printer and it works ok
Drum is on an internal counter in the printer, so it will work fine on another printer. If the print quality is fine, then you can fool the machine into 'thinking' you replaced it. The instructions are here:
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000100/000054/faq000154_014.html?reg=us&c=ca&lang=en&prod=hl2030_all&Cat=7
please rate solution ;)
Posted on Apr 17, 2009
My brother printer HL-2035 keeps jamming the paper. I have changed the drum and toner and the drum light is still on when it prints. Can you help please?
I think you need to reset the consumables counter to clear the drum warning light as the printer can't automatically recognise new parts. If you've bought a genuine Brother drum unit there will be detailed instructions inside the box as to how you reset it which usually involves holding down the only button whilst switching the machine on. As for the paper jams, it could be something as simple as loading less paper and fanning it to get some air between the sheets before sliding it into the tray or it could be that you need to buy a new paper feed kit which is fairly cheap and easy to install.
Oct 07, 2010 | Brother HL-2030 Laser Printer
Brother hl 2035 laser printer paper feed problems
Remove the paper tray. Lift the printer and you have to see paper feed roller it is rubber, just clean of dirt with cloth and alcohol or water.
Aug 26, 2010 | Brother HL-2030 Laser Printer
Brother HL 2030 Paper not feeding at all
Mar 21, 2010 | Brother HL-2030 Laser Printer
My Brother hl 2030 has a permanent paper led light flashing altho there is no paper jam and all covers are secure
Feb 09, 2010 | Brother HL-2030 Laser Printer
Paper feeding problem
3 possibilites.
1.. the paper pick up rollers are jammed
2. you have a small piece of paper stuck inside
3. pickup roller gearsor solenoid are damaged
Apr 17, 2009 | Brother HL 5250DN Laser Printer
Brother hl-2070n; Paper jams half way through drum unit.
Usually there is a sensor right before the paper enters the fuser. If the paper sensor is bad the machine will stop feeding and output the error paper jam. This is probably the cuase if the paper stops in the same position all the time.
Nov 19, 2008 | Brother HL-2070N Laser Printer
Brother hl 2030
Hi here is a link to the brother site with a breakdown of the led status lights.
http://welcome.solutions.brother.com/BSC/public/eu/gb/en/faq/faq/000000/000100/000070/faq000170_005.html?reg=eu&c=gb&lang=en&prod=hl2030_all&Cat=6
There are quite a few reasons as to why the paper light is coming on.
the obvious ones are a paper jam, low paper or no paper or its expecting paper to be put into the manual feed on the front of the printer.
but there are a few less than obvious reasons as well according to brothers site.
hope this helps.
Jul 03, 2008 | Brother HL-2030 Laser Printer
Non stop paper jams
I had this same problem. I finally noticied that the problem occurred consistently on the right side of the paper feed. I discovered that a little part along the right side of my drum unit (just inside the paper feed area) had disconnected and was loose inside the drum unit itself. Once this little part was placed back into it's rightful place, VOILA! Problem solved! Hope this helps!
Jan 22, 2008 | Brother HL 5140 Laser Printer
RED LIGHT BROTHER 2040
light explain link check first!.... paper jam light indicates a few things ie paper mismatch.
possible dirty feed roller, confirm by using bypass slot.
slightly damp rag on rubber feed roller to clean if the issue
Dec 22, 2007 | Brother HL-2040 Laser Printer
Brother HL-2030 Laser Printer Logo
253 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
