Question about Garmin GPSMAP 76CSx Handheld GPS GPS Receiver
GPS LCD broken
My gps lcd broken and not work how can fix it?
  • Could you post the part number, that is printed at the back of the LCD?.
    You can find replacement LCD screens for Garmin here:
    http://www.pantallas.biz/epages/wwwpanta...
  • 3 Answers
Test
Posted on Sep 05, 2009
  • nuviowner234 Sep 05, 2009
    Okay, first post was just a test to see if I could post before typing all this out.
    First, you can find a new touch screen on E-bay for about 10 dollars. The LCD+touch screens are about 60. If you just cracked the screen but the display looks fine, you can just replace the touch screen.
    Now, for do-it-yourselfers. To open the back of the case, there are 2 small torx (star) screws on the back to remove. If you don't have a torx driver, sometimes just the right size eye-glass screwdriver can fit but be careful not to strip the heads. Once those are out, you need to seperate the back casing from the front. I used an old credit card to pry gently with all the way around until it pops off. Don't force it, just be patient, it will come off.
    Next, I recommend unplugging the speaker and battery so you can put the back aside for more room. There are 4 more phillips screws on all 4 corners of the circuit board. Take those out and the board comes out relatively easy. Don't force it. Once it is loose, there isn't much room to play with because of the ribbon cables. The large one is the LCD, the 4 pronged one is the touch-screen. There is a lever that lifts up and secures them in place. I got away with leaving them connected, but they are fragile and easy to tear. Next is separating the silver plastic part of the case from the black front that goes around the screen. I pried a bit with an eye-glass screwdriver around the area where the earphone jack and memory card go in. Again, using a credit card to pry all the way around is best that it won't leave scratches. Don't force it, just be patient.
    Once you have that off, remove the screen from the case. I did it by pushing with light-moderate pressure all around the edges massaging it out. The touch screen and LCD have a rubber/leathery thin tape going around the perimeter. On the front, I got under it with an eye-glass flat head screw driver and slowly worked it around until it was free, being careful not to tear it. On the back, I used a razor-blade to un-stick it from the LCD, but be very careful not to damage the LCD screen if it's still working. The goal is to get this off in one piece. Once you have that off, there is the LCD and touch screen with double-back sticky black tape holding them together around the edges. I used a razor-blade. VERY CAREFULLLY separating them. Once that was done, I carefully scraped the remainder of the tape off the LCD which was un-reusable. I didn't know what to use for putting the new screen on since I didn't have that special type of tape, so after raiding my tools, I found some rolled butyl rubber for installing windshields. I cut small pieces of this off and put them around the perimeter of the new touch-screen (VERY THIN) in the same place the old one was, as if I was installing a real windshield. This took much patience, but in the end it worked great. Before putting the new touch-screen on the LCD, I blew it off with some compressed air, being careful to never leave a fingerprint on it while working on it. After putting it on, I pressed softly but steadily to get the rubber to even out so there wasn't any high points. Then, I replaced the same sticky tape that went around the perimeter of the 2 screens the way it was. It wasn't as sticky, but I made sure it was in place and it kept there by the pressure on the sides of the screen casing. Make sure you get it on right, because I think it's there as a shock-absorber so that the screen doesn't break as easily if dropped or jarred. I plugged back in the LCD screen into it's corresponding place on the circuit board and closed the tiny lever that secures it in place. Then comes putting everything back the way it was in reverse order. Be careful and go slowly, I ended up accidently pulling the ribbon cable out for the LCD and Touch screen and had to go back and reconnect them. This is a good time to attach the battery and turn the GPS on to see if you have all your connections made securely before everything is fully together. Put everything back together in reverse order, remember, if you have to force it, then don't. Don't forget to hook the speaker back up.
    When it's all back together, if the new touch-screen doesn't tap where you tap it, you can calibrate it. This can be done by turning the unit off, then turning it on, then IMMEDIATELY switch it to the right(lock) position before it boots up and hold your thumb on the screen for about 30 seconds. There will be a callibration routine that will tell you to push dots on certain parts of the screen. If you do this with a stylus, it will probably be more accurate.
    Now hopefully, you will be more careful and not drop your nuvi again. I hope this helps.
Touch Panel Broken
there is a guy on ebay that fixed mine Trbilea1999
he repaired my touch screen and updated all the software
Jan 29, 2014 | Kenwood DNX7120 Car GPS Receiver
Garmin 660 broken screen
Its the LCD glass which has gone bad you cannot change it yourself,
Jul 07, 2008 | Garmin StreetPilot c340 GPS Receiver
Broken lcd screen
Ifthey don't give you a new one under warranty, are third party Garmin repair services that will fix it for cheap. Also, I found an DYI GPS repair guide,so you can do it yourself too, not that difficult.
May 27, 2010 | Garmin nuvi 250W GPS Receiver
Sonys nav-gps the lcd cracked can this be fix easly,and is this a problem with them.
if LCD cracked,then you have to replace it.
go to kingyijin@hotmail.com
to find GPS LCD,PDA LCD,PSP LCD,mobile phone parts,notebook LCD.Car LCD,CAR DVD LCD and other touch screens.
Nov 17, 2009 | Sony NV-U73T GPS Receiver
I am looking for a screen cause its broken
You have to replace a LCD,then i will work again.you can try to contact kingyijin@hotmail.com to get GPS LCD,PSP LCD,mobile phone LCD,notebook LCD,Car DVD LCD,industrial LCD,digital cameral LCD,game device LCD.
Oct 31, 2009 | Magellan eXplorist 600 GPS Receiver
Broken lcd screen on mitac mio c310x
You will need to replace a new lcd screen for your cracked mitac mio c310x gps,you can try to contact her,probably she can help you.
Email/MSN:kingyijin@hotmail.com
SKYPE:keyudakim
Sep 18, 2008 | Mitac Mio P550 GPS Receiver
Garmin 660 LCD broken
Are you sure the LCD is broken? or the touchscreen?
Jun 25, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 760 needs repairs
Hi, what is the lcd model number on the back of the lcd? Please write to me: jkzddq@gmail.com maybe we can provide you a new lcd. thanks
Jan 24, 2008 | Garmin Nuvi 660 GPS Receiver
How to fix a cracked / borken LCD digitizer for Garmin360 Nuvi?
You can purchase a LCD with digitizer from ebay. I noticed that a guy with ID nuvi2007 on ebay sell LCD for some nuvi GPS.
Jan 06, 2008 | GPS
Need replacement LCD for my GPS
Call 407 212-6900 GPSINUSA.COM quick turn around 3 days, great prices, great service.
Oct 21, 2007 | Magellan RoadMate 2200T GPS Receiver
Garmin GPSMAP 76CSx Handheld GPS GPS Receiver Logo
131 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
