Question about Poulan Pro 25hht 25cc 22" Gas Hedge Trimmer
Broke pull cord on my Poulan 25HHT Trimmer
Hello. How do I change the recoil starter on the Poulan 25 HHT Hedge Trimmer?
4 Suggested Answers
  • 11 Answers
SOURCE: Wont coil back into its housing, so trimmer wont start. Has compression though
Hi, this a cut&paste from elswhere but it applies to your problem:
how to repair a recoil spring: whats missing is this, you should always wgear eye protection when dealing with springs of any kind.
remember safty first. :)
Remove the recoil shroud and take a look at the assembly.
You might have a broken spring or just a rope that has slipped out of the reel.
The spring usually breaks at one of the end tabs. If so, you will need to get a replacement spring and carefully wind that in, before re-assembling the rope reel. You might wish to replace the rope also, if it shows signs
of wear.
You will need to remove the entire cooling shroud. There should be 4 bolts on the sides. You might need to remove the fuel tank also. Pre-wind the recoil reel by hand [about 6 turns, to set the spring tension] and clamp it with Vise-Grip pliers. Remove the old rope. Thread
the new rope through the shroud housing eyelet and to the reel hub. Let the reel re-wind itself until it is full. If there is not enough spring tension you can wind it a couple of turns more by slipping the rope around
between the reel and shroud. Re-clamp the reel. Cut the rope to length and thread it though the handle. At all knots, burn and melt the rope with a
lighter to prevent untying. Re-assemble.
(special thanks to "Micheal"the author)
Posted on May 19, 2009
e-Guru
  • 3917 Answers
SOURCE: i got no spark --
Hi
Remove plug and ground and see if you have spark at electrode.Sometimes it will not fire under compression.Check that kill switch is not shorted, just remove the wire going to ground and try again.If that is not the case then check for bad coil.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 24, 2010
eugbug
  • 479 Answers
SOURCE: The poulan hedge trimmer engine
Check the air filter isn't dirty.
If the machine runs ok on high speed but cuts out while idling, the idle speed may be too low. There is usually an adustment screw for increasing the speed.
If the fuel line is a flexible type which moves around inside the tank, check it is able to move freely because if you are cutting at awkward angles, the end of the line can end up above the surface of the fuel, **** in air and airlock the line. You can eliminate this as the problem by fully filling the tank.
Check whether there is a one way check valve on the tank. This vents air into the tank as the fuel leaves for the carburettor. Sometimes particles of dirt can get stuck in this.
Posted on May 13, 2011
Replacing pull start on 223l trimmer
Its pawl has either come off the recoil spring or the recoil spring has broken. There are videos on youtube showng you how to repair this fault.
Sep 20, 2012 | Husqvarna 223L
Replace pull cord
Go to smalleng.com they have video on how to do what you need. Check it out awesome website! The cord you can buy at any local home center. or repair shop.
Jun 08, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Hht 25 will not start
CHECK THE COMPRESSION 90LBS MIN.
Sep 22, 2009 | Poulan Pro 25hht 25cc 22" Gas Hedge...
I have a gas powered trimmer Model#GTI 15 Weed Eather
most any small engine shop can help you in getting parts for you trimmer.then might have discontenu this trimmer for pars if so or go on line google and sercret for this trimmer let me know what you fine out.ok
Jul 24, 2009 | Poulan Pro 25hht 25cc 22" Gas Hedge...
Starter cord not recoiling
To get to the starter rewind, you have to pull off the clutch hub and clutch. Without the proper tools, it would be best to take it to a shop. Dwain
May 26, 2009 | Poulan "Poulan" Pp325 17" Gas Brushcutter...
of wear.
May 19, 2009 | Poulan Pro 25hht 25cc 22" Gas Hedge...
Poulan Pro 25hht 25cc 22" Gas Hedge Trimmer Logo
283 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
