Question about Meade LX200GPS Telescope
Azimuth motor stalling missing the electronic home sensor
Lx200GPS 14inch Meade telescope:
During the alignment procedures, the telescope do not stop and return from the south home position. Motor stalling is displayed in the Hand Box Control.
    Genius:
  • 1,027 Answers
Check for binding in the gears; my 10" had aluminium chips in the fork base that jammed the gear. Cured by removing the RA manual adjust assembly - was useless anyway, as it could only be used with the RA unlocked. One setscrew in the fork base holds it in place,just loosen and pull up.
Posted on Apr 18, 2009
How or can I fix my meade lx 200 gps that is not sensing the home poisiton. It also rotates past the point wheree there should be a stop.
This can be caused by:
a bad hand controller cable (buy a new one)
a blown circuit board (only Meade can repair)
Improper setup-- read the manual and do all the setup, and initial alignment.
Nov 15, 2010 | Meade LX200GPS Telescope
My telescope-Meade LX200GPS when tracking the star,it can catch it in some minutes ,but later the star out of eyepiece,is it not tracking the goal? when I tracking the jupiter,the telescope can find the...
To track the scope must:
1. Have a Calibrate motors done
2. Be well Trained using the training routine
3. Must have the correct TIME, DATE, and SITE, and Daylight Savings Time
4. Must be properly aligned on two stars.
Have you done all of the setup procedures listed in the manual? Locate a local Astronomy club and the members will help you with your telescope.
Nov 13, 2010 | Meade LX200GPS Telescope
My meade LX200GPS can't track the stars? wheater the bad weather of observation points will affect the accuracy of automatic alignment? how can I improve the tracking
You must Calibrate motors using the same power source as you use at night outside, then do a TRAIN drives. Some of these scopes also have a Calibrate Sensors -- and some do not.
Then do a two star alignment and center both alignment stars. Daylight Savings Time = Yes right now in the USA, check that it is set to YES.
Oct 13, 2010 | Meade LX200GPS Telescope
I have a meade lx200gps 10" scope. The ra up is not responing. the down is working only. After initializing and fining north the auto star says stalled motor.
Do a calibrate motors and make sure you are using a separate 12 volt power pack or BRAND NEW internal batteries. All goto scopes work better with smooth, regulated power. The internal batteries will NOT work well for very long.
The Calibrate motors routine adjusts the motors for the power supply being used.
Oct 10, 2010 | Meade LX200GPS Telescope
When I started to make the azimuth motor rotate, it rotate, suddenly it stopped and warned me.. motor stalled.. With a message of what cold be the causes, but I can restart all the process without moving...
First, always use a seperate 12 volt power pack and NOT the internal batteries. Do a Calibrate Motors -- first thing whenever you turn on the telescope.
Sep 30, 2010 | Meade LX200GPS Telescope
Scope is 12.5, 9 years old. We align by going to "named star," selecting one, slewing, correcting, hitting synch. Repeating with another star. Almost always the scope goes to accurately there after. (We...
Runaway DECLINATION is what this is called. Usually it can be fixed with a new hand controller cable. If a new cable does not fix it, then it has a blown motor circuit board and must be returned to Meade for repairs.
Meade customer service:
http://www.meade.com/support/index.html
Aug 18, 2010 | Meade LX200GPS Telescope
Inability for the telescope align
Replace the battery for the GPS.
Start from scratch.
Reset the hand controller, calibrate motors, train drives, calibrate sensors.
Make sure you have either fresh batteries, or better a seperate 12 volt power pack. The above will eleiminate everything except an actual BROKEN electronic part (such as a bad gps board).
If it still will not align using the gps, time to send it back to Meade for repairs. Make sure you have the latest firmware in the hand controller which is 43Eg. You can download the firmware using the UPDATER free software here:
http://www.meade.com/support/downloads.html
May 08, 2010 | Meade 8" LX90 Schmidt-Cassegrain Telescope...
I've made every possible alignment on my 10 inch Meade LX200GPS telescope, training,set-up, calibration, etc...but when I slew to a star....it is ALWAYS very far off in Dec....though RA seems to be well...
You might want to join the following Yahoo group:
http://tech.groups.yahoo.com/group/LX200GPS/
I am not familiar with the LX200, but there are probably folks on the Yahoo group that can help.  The only thing I can think of is if you are using a wedge and the wedge isn't at the correct angle (should match your lattitude).  Or you are not using a wedge and the Meade controller thinks that you are.  But one would think the calibration would solve that.
Apr 26, 2009 | Meade LX200GPS Telescope
Problem with lx200gps meade telescope
It might be a voltage or electrical current problem. Make sure your DC power supply is between 12 and 14 volts. Make sure all electrical connections are tight. Where the power cord plugs into the connection panel, make sure the center pin on the panel fits tightly into the plug. It is a Radio Shack type "N" plug. If tou still have a problem, remove the bottom plate from the scope base and make sure all the connectors are properly seated on the circuit board. Check the connector on the end where the black and red wires are. That is a main power connector and if it is too loose it will not conduct enough current. There can be enough voltage drop that the drive motors won't operate, or they will and the scope will slew uncontrollaby. Be careful handling the wires so that you don't damage them. Good luck, Dave
Aug 30, 2008 | Meade LX200GPS Telescope
Meade LX200GPS Telescope Logo
398 people viewed this question
Top Meade Optics Experts
Experi
Level 1 Expert
Joe Wright
Level 1 Expert
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Meade Optic Expert? Answer questions, earn points and help others
