Question about TORK Digital Interval Timer Ssa100r-24
Wireing a tork clock timer - TORK Digital Interval Timer Ssa100r-24
Following link shows Tork timers and manuals, with wiring diagrams:
http://waterheatertimer.org/Tork-timers-and-manuals.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Jan 23, 2011
5 Suggested Answers
  • 384 Answers
SOURCE: Tork mechanical timer for pool pump
Any Hardware store.
Posted on Jun 23, 2009
  • 760 Answers
SOURCE: Not sure how to wire my Tork 1103 timer
The L terminal would be for your "hot" incoming black wire. The X terminal would be for your load outgoing black wire. Connect both white neutral wires to the blank terminal (notice this feeds the timer motor. The other two terminals (1&2) are not necessary if it is a 110V single circuit.
Posted on Aug 03, 2010
SOURCE: Im installing a TORK 1103.. Im hooking this timer
Tork 1103 is mechanical timer with 125V 3 watt clock motor
Dial on front face rotates when clock has voltage
Dark and light colored pins connected to dial, and turn timer on and off
There is removable brass bar that connects poles L and 1
You have 4 wires:
Red >>> I'm not sure about this wire, is this Hot wire coming from tandem breaker?
Black >>> this is Hot wire coming from tandem breaker
White >>> this is Neutral wire
Bare ground
Test wires:
Please test Black and Red to bare ground to see if these are both Hot
Test Hots to white to confirm this is Neutral
Solution ASSUMES black and red are both Hot, and white is Neutral
You have 2 problems:
Prob 1) Clock does not rotate dial: so clock is bad -or- clock not wired correctly
Prob 2) You are able to control 4 plugs using manual override, which means load wires are correct
However, you want to wire timer 'without red wire' (which is confusing, since red wires are connected to outlets)
Solution Prob 1:
1) The diagram show the N or Neutral wire is connected to Unmarked pole on timer
2) Black Hot has to be connected to pole L
3) Unmarked pole and pole L must be wired with 120V as shown before dial will rotate
4) If wiring is correct and dial does not rotate, then clock motor is bad
5) If dial rotates, check outer rim of dial to see if you have dark and light pins for on-off functions
6) Notice that all the Neutrals connect on Unmarked pole
Solution Prob2:
Are you saying that the household wiring extends beyond the 4 plugs, so when you turn off the 4 plugs, it also turns off more plugs and switches farther down the line? If so, you need to wire plugs with separate hot wire.
Let me review features on timer which might help:
1) There is removable brass bar between poles L and 1
2) If brass bar is removed, then you need Hot wires on both L and 1... but you can jumper between L and 1 with short black wire
3) If brass bar is there, then one Hot connected to either L or 1 will power both clock and load.
4) Timer is DPST double pole single throw ... so you can control 2 different loads ... one load connects to Unmarked pole and pole X ... another load connects to Unmarked pole and pole 2
If brass bar is removed:
Jumper between poles L and 1 ... so only one Hot wire is used on your timer.
Below shows jumper on poles L & 1: hot to load is on pole 2
Posted on Oct 07, 2010
SOURCE: I have an Intermatic T103 DPST timer installed now
T-103 has 120V clock motor with 5 terminals A 1 2 3 4
Tork 1101 has 120V clock motor with 4 terminals L 1 X 2
T103 is DPST and can control one-or-two 120Volt loads, or one-or-two 240Volt loads.
Tork 1101 is SPST can control one 120Volt load
Common ground between these timers one 120 Volt load
Changeover for one 120 Volt load:
White wires T103 terminal A go to Tork terminal X
Black wire T103 terminal 1 goes Tork terminals L and 1 (there is brass connector plate that connects L and 1 - if connector is missing, jumper between L and 1)
Black wire on T103 terminal 2 goes Tork terminal 2
If Load requirement is greater than T1101, Grainger sells T103 clock motor for $16
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK1?Pid=search
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
How to wire T103
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
T1101 wiring manual
http://waterheatertimer.org/pdf/110111021103WIRING.pdf
Posted on Dec 02, 2010
Can a tork timer 1101 be used to control a 240 volt pool pump motor by controlling only 1 lead of the motor thus having the other lead hot all the time?
Yes: 240 volt can be controlled by turning off 1 hot leg of 240V circuit.
But the tork 101 clock motor still requires 120Volts (unless you buy a tork 240volt 201 clock motor to replace the 120volt 101)
Copy following links for handy resource and wiring diagram:
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
http://waterheatertimer.org/images/Tork-1101-wired-to-control-240.jpg
In the wiring diagram above, it shows white neutral wire running to Tork 1101 timer terminal 2. Bring this white neutral wire from any nearby 120volt outlet.
In event that you do not have this white neutral wire, you can connect ground wire to terminal 2 and that will give 120volts to the 101 clock motor.
Completing circuit to clock motor using ground wire is violation of national electric code for many reasons, however the tiny clock motor only draws 3 watts, and you will remember to bring a white neutral wire to this timer at later date so you can sleep better at night.
Additional resources:
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-12.jpg
Gene
h
Aug 27, 2013 | Hardware & Accessories
How can onr tell if timer on Tork 1101 is not working?
Is the dial rotating?
1) Copy following link for Tork 1101 product wiring and manuals:
2) Tork 1101 120Volt timer uses #101 clock motor.
If clock motor is working, then dial rotates around clockwise once each 24 hours... assuming timer is wired correctly.
3) Jan 2013, Add a comment and say what you are wiring.
Jan 30, 2013 | Hardware & Accessories
15600 wiring problems
You probably have wrong voltage, or wrong wiring.
For example 15600 is 120Volt timer mechanism made by Tork and sold by GE.
This timer will not work with 240volts.
Other cause: Line and Load wires might be reversed.
Check circuit breaker.
Use non-contact voltage tester to see if power is live at timer.
Check wires at each terminal and make sure wire insulation is not under the screw plate.
Copy following link for wiring diagram:
http://waterheatertimer.org/GE-timers-and-manuals.html#15600
FYI, it is usually cheaper to buy T101 timer than GE15600, and then parts are more widely available and cheaper.
For example WG1570 clock motor for Intermatic T101 is $16.
Tork replacement motor is twice as much.
If you have 240Volt power, instead of 120Volt required by 15600, then you can buy Tork 201 clock motor and replace the 101 motor.
GE 15600 uses Tork p47 trippers.
http://www.globalelectricalsupply.com/Tork-Motors-p/motors.htm
Jun 17, 2012 | Hardware & Accessories
My Tork 1101 24 hr timer has stopped working. I hear it running, but the clock will not turn. I have to turn it on and off manually for my pool pump. This happened 2 years ago, then the following year...
You might need $45 clock motor for for Tork 1101 120Volt.
http://www.frontierlighting.com/product.jsp?part=10431&process=search&show=&&gdftrk=gdfV22514_a_7c834_a_7c3267_a_7c10431
Open following link to identify timer and see replacement clock motor and trippers:
Intermatic crossover shows T101 timer replaces 120Volt Tork 1101.
Amazon sells new Intermatic timer for $45 with super shipping
http://www.amazon.com/Intermatic-T101-Hour-Dial-Timer/dp/B00002N5FN
Crossover wiring from Tork to Intermatic:
Black wire on Tork L and 1 connect to Intermatic terminal 1
White wires on Tork X connect to Intermatic terminal A
Black wire on Tork 2 connects to Intermatic terminal 2
http://waterheatertimer.org/How-to-wire-T104-Intermatuic-timer.html#T101
Add a comment for more help
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Jun 04, 2011 | Vacuums
I noticed the Tork 1104 timer box was not working. It does not make a sound. And the clock does not move. I measured the incoming and outgoing wires with a multimeter and both measure at 240V. I'm...
13 years is good run for clock motor. Timer will last longer than clock motor.
Tork 1104 has 240Volt clock motor
Frontier lighting sells the >> 120V Tork motor: List price 40.33/ your price 45.49
So 120Volt replacement motor costs as much as new replacement timer
Intermatic replacement is240 volt T104 timer for $49.62 with 'free' shipping:
Also Intermatic trippers and clock motors are cheap and easily available
http://www.amazon.com/Intermatic-T104-208-277-Volt-Mechanical-Switch/dp/B000BQOX88
Crossover wiring from 1104 to T104.
Tork L goes to Intermatic 1
Tork 1 goes to Intermatic 3
Tork x goes to Intermatic 2
Tork 2 goes to Intermatic 4
Intermatic A is not used unless you have neutral wire or 277V
GE sells the same 240Volt Tork timer under GE model 15307 in indoor-outdoor enclosure available at Home Depot for $59.00. Year 2011, GE does not pay US income tax, but takes US profits and pays tax in foreign nations. No replacement clock motor is available, but crossover wiring is same.
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
Upvote the help.
May 09, 2011 | TORK Variable Cycling Timer 8601
Tork timer "time clock motor"kaput...someone set
You posted under Tork 8601 timer:
I don't think that clock motor is sold separately.
New timer costs 115 at Chapman:
http://shop.chapmanelectric.com/tork-8601-minute-120v-spdt-p-2361-l-en.html
120Volt Tork clock motor that fits some models is sold at frontier for $43:
http://www.frontierlighting.com/product.jsp?part=10431&process=search&show=&ID=,Photo.Cells...Time.Controls,Replacement.Motors
Usually the clock motor is held with 2 screws and then wires attach to screw terminals.
Look close at your screw terminals to see clock wires.
Normally timer mechanism snaps out of box and clock motor is on back of mechanism.
Jan 25, 2011 | TORK Variable Cycling Timer 8601
Can i put 120 volts to the dry contacts on a tork dts400b timer?
1) DTS wiring shows on link below:
http://waterheatertimer.org/pdf/1TORK.DTS400A.DZS400A.WIRING.pdf
Timer appears on page below:
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#DTS
2) Tork DTS400B is 4 channel timer, so you can control 4 different Loads with different programming for each Load.
3) I am not 100% certain what you are asking.
Timer can be wired for 120V operation.
Clock motor has separate wiring from Load wiring.
4) Clock motor is shown in wiring diagram as 'Timer supply'
Timer supply is on lower row of terminals.
120 Volt Hot connects to screw terminal identified as 120
120V Neutral connects to screw terminal identified as N
Clock motor wiring does not pass to the Load or channel terminals.
5) Load terminals are not fed by 120V connection to Timer supply.
Each load is wired separately.
For example lets say Load 1 is channel 1 or CH1.
Hot to CH1 connects to terminal C.
Neutral to CH1 connects to terminal NO, or to NC terminal.
6) Terminal NO normally open turns ON when timer turns ON
Terminals NC is normally closed is ON full time, except when timer tuns ON. So NC turns OFF when timer turns ON.
Jan 23, 2011 | TORK Hardware & Accessories
Tork 1104 is wired 120 vac. hot wire connected to L with jumper wire to 1.hot wire for outdoor lights connected to X. nuetral wires are wire nutted together. not connected to timer. clock not working....
The clock isn't working because the Tork 1104 clock motor requires 240 volts. Jumping the 120 volts over from terminal L to terminal 1 doesn't make it 240 volts. You need another 120 volt leg (180 degrees out of phase) to do that. The Tork 1103 timer is what you need, or change the 1104 clock motor to a 120 volt.
Dec 16, 2010 | Hardware & Accessories
I have an Intermatic T103 DPST timer installed now (120v). The clock mechanism has failed. I bought Tork 1103 guts to replace it. The wiring is a bit different. Can u map for me which wires go to which...
How to wire T103
T1101 wiring manual
Dec 02, 2010 | Intermatic T103 Indoor 120-Volt 40-amp...
TORK Digital Interval Timer Ssa100r-24 Logo
412 people viewed this question
Top TORK Hardware & Accessories Experts
 Kenneth
Kenneth
rgbypoet
Andrew Taylor
Andrew Taylor
Are you a TORK Hardware and Accessory Expert? Answer questions, earn points and help others
