Question about RCA 27F534T TV
HELP HELP HELP!
I have an rca truflat TV.. i plug it in and i hear the click.. from the electricity going to the cercuit board... i know this is cercuit board because i took apart the tv and plugged in to hear were the sound comes from.. also when i plug in i see blue light then it turns off fast... then after 10 or 15 minutes then the lights turns back on... some one plz help!
    Problem Solver:
  • 6 Answers
Here is something that I found that might help?
http://www.netnoise.com/boycott_rca/rcabook2007-8.html
Posted on Dec 19, 2007
SOURCE:
My rca truflat 27f520t27'' tv keeps turning off and all
There is some shorted component/s on the main power supply regulator baord to your TV. Work with main power board circuit is fatal to any inexperienced person, as 80% of the components at this stage will be Hot [electrically], when the set is switched ON. Without switch it ON, you cant check the voltages at this section. S, if you are not experienced to do this work, contact any experienced service technician to get this set repaired.
Jul 20, 2012 | RCA TruFlat 27F520T 27" TV
My tv plays for about an hour and after that it keeps blinking on and off till i turn it off and it just keeps at it till i unplug the unit
Maybe theres a loose connection in the cercuit board, you need to resolder the board. you need a qualified technician to fix your problem.
Jul 23, 2010 | RCA TruFlat 27F520T 27" TV
I have an RCA-27F530T-27''-TruFlat-TV that my son has somehow gotten stuck on MONO mode while installing his games and I cannot figure out how to get it back to Stereo mode for normal function. We do have...
Ur IR control board one of it button might be damage.Tries unplug the tv for couple hours see if it reset itself tv might work again.If u lucky.Or the IR control board is bad or the IC that help the IR board is dead.
Sep 04, 2009 | RCA TruFlat 27F520T 27" TV
Hello, I have an RCA Truflat tv that I bought
If you can hear sound and the sound coems from your TV, try changing the volume with teh TV remote control. Your TV isn't off it is still on. Just the video board or portion is cutting out. this could be a ton of things, I would try changing out the power strip or plugging the tv into the wall directly to make sure it has enough power. other then that you can try a home brew solution like putting a fan next to your tv to cool the component that seems to be overheating and shutting down your picture.
Aug 25, 2009 | RCA Televison & Video
I have a RCA 27" flat SDTV purchase in
Ur power inverter board is dead.
U need new one.
Aug 20, 2009 | RCA TruFlat 27F520T 27" TV
Rca standard defintion truflat
the power supply is main cause problem of tv,you coldsolder the main board of your tv.
May 04, 2008 | RCA TruFlat 27F520T 27" TV
Wierd problem
Sep 15, 2007 | RCA 27F534T TV
WONT WORK *****
if you see near plug it might be due to sparking in socket or plug by calling electrician it might be repaired easily. But you have seen blue light in tv & chattering sound than it is dangerous. do not put on tv &call skilled person.
Sep 15, 2007 | RCA 32V550T 32" TV
RCA 27F534T TV Logo
62 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
