Question about Dell 1815dn All-In-One Laser Printer
Dell 1815dn laser printer prints completely black pages
I have even tried replacing the ink cartridge with an empty one... and it still prints completely black pages! Dell support advised me to buy a new printer as my warranty has expired ;-) The justification was that replacing the high voltage power supply, which they pinpointed as a culprit, would cost almost the same as a comparable new printer. Is it possible that the roller is causing this - it's completely covered in ink... Perhaps it's not the HVPS? Thank you in advance.
  • jc rose Apr 24, 2009
    I have the same problem, the pinter printed multiple black pages. Now it constantly reads JAM 2OPEN REAR& FRONT DOOR. Is there a cure?
  • tigertail
    tigertail May 11, 2010
    If it is black all across the page to the edges then it will be the HVPS board, if there is a margin then it is most likely the laser head itself. Either way it would be more economical to replace the printer than to get an engineer to swap parts. Sorry can't be of any more help to you this time :-(
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 53 Answers
1. Charge – Print Quality (PQ) -- The charge roller evenly distributes a negative charge on the photoconductor (PC) drum. This evenly distributed charge acts as the film that is discharged (exposed) by the laser to create the latent image.
a. Print Quality effected: Faint, Entire Black background, Grey Fog/Haze
b. Parts Involved:
i. Drum -- A drum cartridge is coated with a photoconductive material that allows electricity to pass when exposed to light. As an example of why this can be the failure, if you leave a drum out in light long enough, you will get dark backgrounds or just black pages. However, drums do wear out over time too; specifically the photo material the drum is coated with. As this degrades, more of the positive electricity on the inside of the drum gets through and grabs toner, as if the laser wrote to every square inch of it. A damaged or defective PC drum can cause black streaks/lines, voids, speckles and various other print quality problems.
ii. Charge Roller Also known as the BCR or Bias Charge Roll. The charge roller pulls double duty. It energizes the outside of the drum with negative energy and as a result it cleans any previous latent images. If the charge roller were failing to energize either due to the HVPS or the charge roller itself, it wouldn’t clean any previous unused toner deposits from the last revolution would start to accumulate and appear on paper more and more causing haze. A missing charge roller causes completely black pages.
iii. HVPS – High Voltage Power Supply -- Responsible for charging components such as the inside of the drum, the charge roller, and transfer roller. If the HVPS does not give enough to the charge roller it can fail in erasing the drum, causing entirely Black pages to be printed.
Posted on Apr 27, 2009
Dell 1815dn - when faxing, the fax goes through but all pages are black. when attempting to scan, pages are black. when trying to scan to a PDF file, the file is blank or black.
Welcome to Fixya
Try to print a document and see if you will be getting same issue. Try to copy a document and see if same thing will happen also. Check if the cartridges are not running out of ink.
Thank you for using Fixya!
Aug 02, 2011 | Dell 1815dn All-In-One Laser Printer
Can't get printer to print in black
unfortunately some printers will not allow such and needs to have all the cartridges working for it to print. this is regardless if the black is still okay. i suggest to go to your nearest store and purchase one.
Jun 19, 2010 | Dell 926 All-In-One InkJet Printer
Black toner replaced; now all black printing comes out faded grey
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 02, 2010 | Dell 1320c Laser Printer
Reset ink levels on dell 944
If you refilled the cartridges, you may want to try new Dell branded cartridges.
May 27, 2009 | Dell 944 All-In-One InkJet Printer
Prints faint copies
If the print rubs off the page, this means the toner is not being fused to the page. Fused......this is done by the fuser. This would have nothing to do with light print.
The dell (1600n and 1815n /1815dn) printer drivers has a toner saver mode, which can contribute to light print.
To turn Toner Save Mode off, (Windows XP) perform the following steps:
  1. Click the Start button, click Settings, and then click Printer and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser MFP 1600n, 1815dn, and left-click Printing Preferences.
    The Dell Laser MFP 1600n, 1815dn Printing Preferences window appears.
  3. Click the Advanced button.
    The Dell Laser MFP 1600n, 1815dn Advanced Options window appears.
  4. Click to highlight Toner Save.
  5. Click the drop-down list and change it to Off and click OK.
  6. Click OK.
One thing that you mentioned in your post "it takes the printer forever to warm up". The fuser does have to reach operational temperature in order for it to fuse the toner to the page. So it is possible that you are having fuser problems, because of the time it is taking for it to warm up. Another thing that can contribute to the warm up time is not plugging the laser printer directly into a wall outlet. This would be true for any laser printer, not just a Dell laser printer. The low voltage power supply is what works the fuser, along with sensors and other motors in the printer.
Replacing the fuser and or the low voltage power supply in this model of printer is not an easy task. If using a Dell branded toner cartridge and checking the toner saver mode does not fix the issue. Then you would be looking at more expense then the machine would possibly be worth.
May 04, 2009 | Dell 1600n All-In-One Laser Printer
Refilled my Dell Ink Cartridge
yes, it's safe, and if you are dissatisfied with the cartridge, take it up with the cartridge re-filler...better yet, spend about $100 on a black & white laser printer (HP), and get 2000 pages per cartridge, and reduce cost per page by 20 times or more! And If you buy compatibles for this (which are more reliable) -save even more.
*please rate me
Mar 24, 2009 | Dell 948 All-In-One InkJet Printer
Fading on one side of the paper - Dell 1815dn laser MFP
The Printhead IS located above the toner cartridge on this model. There is a small opening that allows the laser light to shine through the case to the imaging unit on the toner, but you can not access the the laser without disassembling the printer.
Even though this is a new toner cartridge, it may be defective, even more likely if it is a non-Dell or remanufactured toner. Try reinstalling the old toner cartridge. Even if it prints light because it is low, if it is uniform across the page then the new toner is defective. Return or exchange it with the manufacture.
Sep 25, 2008 | Office Equipment & Supplies
Dell All-in-One InkJet
replace ink cartridge first then uninstall this printer from your pc and reinstall the printer driver again
Nov 27, 2007 | Dell 924 All-in-One InkJet Printer
Dell 1815dn All-In-One Laser Printer Logo
2,511 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
