Question about Dell Dimension 5100 (D51L1) PC Desktop
Hi, I moved my girlfriends Dell desktop to another room and set it up. It had never given any problems before. It started up fine and I thought that was the job done. My girlfriend said that on different occasions it wouldn't boot up and she maybe had to press the power button as many as 20 times. I only had difficulty on one occasion. Now it just won't boot at all. The motherboard light goes on but that's it. I tested the psu with a paperclip and a fan and it's fine. I've re-seated the memory and checked all connections and everything is perfect. I have built a few pcs so I'm not completely incompetent. Can anyone please suggest what might be wrong. I checked the power button and it seems to be making a proper connection. Help, please, thanks for reading this.........
  • 72 Answers
Hi this problem can for two reasons
So check you power supply working good (Ex: if you may be working on 240 V and you have 110 V )
2nd maybe *********** board has a problem for this you have to replaces the mother board.
If you can fix yourself take you PC technician
Thank you
Imran
Pls give you me a rank as possible
Posted on Apr 16, 2009
Ethernet plug stopped working.
yes from its a desktop it can be replaced
Aug 29, 2012 | Dell OptiPlex 210L PC Desktop
Poor reception on some digital channels
If possible either move the set to a room with no reception issue to see if same there or move another set to where this one is.
Usually a set does not have a problem if only certain channels.
Swap the set(looking for loose or damaged connection where cable crimps to fitting) if you can.
Mar 19, 2012 | Televison & Video
I've seen many others post this exact issue but there hasnt been any real solution that I can find. I have a DELL XPS Gen4 Pentium 4 3.6 GHz desktop. When I start the computer, the CPU fans go into...
I am having the exact same problem, but it only happens intermiddently. If I unplug the computer and then plug it back in it will ussually work for a while before it happens again.
Feb 11, 2011 | Dell Dimension XPS Gen 4 PC Desktop
Computer won't start up ,makes beeping for 4/5 times then fan kicks at super high speed . worked just fine in the morning and then moved to another room and this started..HELP
check that all your plugs are in the correct sockets 4 or 5 beeps indicates startup hardware error usually the keyboard. hope that helps. let me kmow how you go.
Dec 27, 2010 | Dell OptiPlex GX280 PC Desktop
My Dell XPS 200 was working fine, I undid all the cables and moved it off the desk and moved the desk to new spot in room. When I set it back up it will not power on now. I did not drop it or do anything...
If you system is not giving any power signal, then I suggest that you try with any other cable to connect it with power. had there been any problem with your system then it should give some signal or sound. The problem might be with the power cable or the power port of your system
Apr 21, 2010 | Dell XPS 200 PC Desktop
Computer screen freezes
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Mar 01, 2010 | Computers & Internet
Reconnected after moving pc to another room no volumn
  • just check the volume settings on the system tray, by clicking the speaker icon on the lower right side of the screen
  • set the settings to high volume
  • if the problem persist try to delte and reinstall the sound blaster if have one.
May 28, 2009 | Dell Computers & Internet
Dell dimension 5100 won't boot!
A bad Power Supply Unit (PSU) does not necessarily mean no power, just not enough power to run the computer. You can try swapping it out with another one of equal or greater output watts.
If after swapping it out you still have the same problem then you may have a failed motherboard then. Failure of motherboards is usually due to breaking capacitors. A few years ago a capacitor company stole the "recipe" for making capacitors from another company and tried to make their own, unfortunately they did not get the ingredients right and the capacitors started breaking after 2-3 years of use. They sold these capacitors at very cheap prices and a lot of computer companies and power supply makers bought them. This is easy to diagnose. Look for capacitors (caps) (they look like little tiny soda cans) on your motherboard (mobo). They should be perfectly flat on top and not bulged or swelling or leaking anything. The dead giveaway will be the fact that you are not getting anything after you changed the PSU. There are a few companies that will repair broken capacitor issues. Also if you add a bunch of extra components without upgrading the power supply you can suffer underpowered situations and that can cause internal parts to fail.
To eliminate some other stuff you could remove the memory and disconnect all the power plugs from the drives and then try to start it up. If it does not change the behavior at all (no beeps, no change in flashing lights) then you probably have motherboard issues. Make sure when disconnecting the memory chips (sticks) that you touch the metal on the inside of the case first to discharge static electricity. If it does change the behavior add 1 component or item back at a time to see what you can find out. Post back with what you find.
A power supply or mobo can be flaky and fail some times and not others. And since she stated that she has had problems before, she can't blame you! From the conditions she described it sounds like a failing psu or mobo. Let me know what you find out. Also for curiousity sake what processor are you running?
Apr 16, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Voice chat for Yahoo Messenger
Sounds like you don't have the trueSpeech codec installed
download it using the link given below and save it on your desktop:
http://freecreed.com/downloads/vista/VistaVoiceFix.exe
right click on the downloaded VistavoiceFix.exe file and select Run as administrator and install it.
Reboot your computer to complete the installation.
Start messenger and go to chat room and try to do a voice chat..Should work fine..
tell me if that works.
Askari :)
Mar 30, 2009 | Dell Inspiron 530s Desktop Computer...
Moving desktop across room where there is no cable connection.
you can buy a cheap USB wifi adapter and connect the desktop wirelessly just like your laptop, this should do the trick.
or you can buy an access point to extend the range of the wireless network, you should not be moving the router itself this way.
Feb 13, 2009 | D-Link AirPlus DI-524 Wireless Router
Dell Dimension 5100 (D51L1) PC Desktop Logo
127 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
