I have a Ricoh 1035 black and white copier/networked printer. There are 4 trays but the copier only sees tray 1 and tray 2. So when I try to print to tray 4 using a desktop utility with the correct driver, the printer takes paper from tray 1 only.
There is a wire harness that connects the two bottom trays to the main machine. The connector might be loose or have a break in the harness. The main machine is not seeing the bottom two trays. Let me know if this helps.
We have a Cannon PC 940 and the paper is stuck at the end where it should come out. There is a green...
(More)
We have a Cannon PC 940 and the paper is stuck at the end where it should come out. There is a green up arrow and the paper is stuck under that - moving the knob up does not release the paper - it is accordianed in the machine and we can not even putt the paper out or straighten it - please help
Can you please send me the instructions for replacing the developer and also how to reset the...
(More)
Can you please send me the instructions for replacing the developer and also how to reset the "wrench"? Thanks very much!
