Question about Dell Dimension 5100 (D51L1) PC Desktop
Dell dimension 5100 won't boot!
Hi, I moved my girlfriends Dell desktop to another room and set it up. It had never given any problems before. It started up fine and I thought that was the job done. My girlfriend said that on different occasions it wouldn't boot up and she maybe had to press the power button as many as 20 times, sometimes only a couple. I only had difficulty on one occasion. Now it just won't boot at all. The motherboard light goes on but that's it. I tested the psu with a paperclip and a fan and it's fine. I've re-seated the memory and checked all connections and everything is perfect. I have built a few pcs so I'm not completely incompetent. Can anyone please suggest what might be wrong. I checked the power button and it seems to be making a proper connection.
Help, please,
thanks for reading this.........
  • 1 more comment
  • curlykale Apr 16, 2009
    Thanks for all the advice. I will swap out the psu with another one and failing that, I'll try again to source a mobo. None on ebay at the moment.
    Thanks again! There never was a burning smell.......
    The processor is a pentium 3.2. Thanks....
  • Roberta Smith
    Roberta Smith May 11, 2010
    stick your nose into the computer... smell anything burnt ?
    Novelist:
  • 166 Answers
A bad Power Supply Unit (PSU) does not necessarily mean no power, just not enough power to run the computer. You can try swapping it out with another one of equal or greater output watts.
If after swapping it out you still have the same problem then you may have a failed motherboard then. Failure of motherboards is usually due to breaking capacitors. A few years ago a capacitor company stole the "recipe" for making capacitors from another company and tried to make their own, unfortunately they did not get the ingredients right and the capacitors started breaking after 2-3 years of use. They sold these capacitors at very cheap prices and a lot of computer companies and power supply makers bought them. This is easy to diagnose. Look for capacitors (caps) (they look like little tiny soda cans) on your motherboard (mobo). They should be perfectly flat on top and not bulged or swelling or leaking anything. The dead giveaway will be the fact that you are not getting anything after you changed the PSU. There are a few companies that will repair broken capacitor issues. Also if you add a bunch of extra components without upgrading the power supply you can suffer underpowered situations and that can cause internal parts to fail.
To eliminate some other stuff you could remove the memory and disconnect all the power plugs from the drives and then try to start it up. If it does not change the behavior at all (no beeps, no change in flashing lights) then you probably have motherboard issues. Make sure when disconnecting the memory chips (sticks) that you touch the metal on the inside of the case first to discharge static electricity. If it does change the behavior add 1 component or item back at a time to see what you can find out. Post back with what you find.
A power supply or mobo can be flaky and fail some times and not others. And since she stated that she has had problems before, she can't blame you! From the conditions she described it sounds like a failing psu or mobo. Let me know what you find out. Also for curiousity sake what processor are you running?
Posted on Apr 16, 2009
    President:
  • 2,992 Answers
Probably it's just coincidence that the startup trouble is worse now that you moved the computer. It sounds like a motherboard issue that's been brewing for a while and has just become permanent.
You've already made all the checks I would have suggested, so the next step would be to substitute the power supply with a known good one. You tested the supply to see if it would come on, but that doesn't mean the supply has all the right output.
If a good power supply doesn't fix the trouble, you need to look for a replacement motherboard. If I remember correctly this computer uses a proprietary board and you need to get the same one so it will fit the case. Several companies sell parts and eBay is a good source as well. I frequently get system boards from Blue Raven Technology (www.blueraven.com).
Good luck with the repair!
2 Suggested Answers
mimranon
  • 72 Answers
SOURCE: Hi, I moved my girlfriends Dell desktop to another
Hi this problem can for two reasons
So check you power supply working good (Ex: if you may be working on 240 V and you have 110 V )
2nd maybe *********** board has a problem for this you have to replaces the mother board.
If you can fix yourself take you PC technician
Thank you
Imran
Pls give you me a rank as possible
Computer won't boot
Check if the connection between the wall outlet and the computer is fully plugged in. If it's good, maybe there's a problem inside the computer. Open your computer and make sure everything is plugged in correctly.
Sep 28, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
I have the Dell De051 and it won't finish booting... It keeps freezing and getting stuck...
Is there any error message?I have come across similar issues and got it resolved by The Best Pc Doctor Team.
You can also contact them on their toll free number.
www.thebestpcdoctor.com
877 407 9229(Toll free)
Sep 11, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
Can't boot up Dell 5100 Dimension, amber light flashes
When you mean the amber light, is that the blinking hard drive access light or the power light? Different cases have different colors on it. Mine has blue and green lights.
If you see the boot screen (bios) and then after it goes to boot, does it blink and hang?
This could be a simple operating system issue, hard drive or hardware/motherboard issue. If you could provide more information, that would help.
Jun 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Desktop Dimension 5100 is not booting up
please check first your bios settings.. its could be on the boot up settings. you must configure it out correctly..
May 11, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Hi, I moved my girlfriends Dell desktop to another room and set it up. It had never given any problems before. It started up fine and I thought that was the job done. My girlfriend said that on different...
Thank you
Imran
Apr 16, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Power problem on Dell Dimension 5100
plz check the ram and powersupply unit and try to reset the bios
Sep 02, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 won't start with new FireMV 2400 PCI Express video card
Did you check to make sure the video card is installed in the right spot? Has the onboard video card been disabled in Windows - and when you say it will not boot, do you mean physically no POST. Do you get any error codes? If you can get into the CMOS (Bios) Setup screen - change the primary display adapter from the onboard to AGP, PCI, or PCI-E depending on which card that is. Use this information at your own risk - hope it helps.
Aug 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
CD boot disc
you can get it  microsoft home site or from any software vendor
Jan 24, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Reload windows
Hi Dragon,
Try pressing the Ctrl and the F11 key at the same time, right after you boot the PC. You might have to try this a few time, because the time slot of this option is fairly narrow. Should give you the restore partition. Then just follow the prompts. Good Luck!
Jan 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
433 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
