Question about StarTech.com StarView SV211K 2-port KVM Switch
How do I access "The Box" menu to input codes. Iknow the 1570 one but can you take me through the procedure after this as I cannot input the codes I have Fitz101
  • John Fitzgerald Apr 16, 2009
    Hi thanks for that. I can get in ok. Its inputting the code that is the problem. It appears to be too long for the boxes in the Nagravision. They are NTL codes.
    Yes the code is similiar to that but the one I have to enter is much longer. Thanks for your efforts I really appreciate it. I know how to enter codes etc it is just the code I have is so much longer.
    President:
  • 159 Answers
Hi, press menu, then quickly press 1570, this will take you into engineers menu. press ok, on nagravision, and you are in.
hope you understand that.
Posted on Apr 16, 2009
  • jim lan
    jim lan Apr 16, 2009
    Ok when you ok on nagravision, do you see something like this?
    ntl
    00
    5C 2C 26 36 CF 81 AB 66
Cant access hidden menu on starview boxes even after entering 1570 code
Type the code 1570 when you access the set up menu. Then click ok on nagravision you will then be able to access the codes for you current supplier.
Hope this helps.
Oct 06, 2009 | StarTech.com StarView SV211K 2-port KVM...
Tip
Box t eurovox or digivox
firstly be more helpfull on the type of box you have if you have loaded the latest firmware or not is it a cable box terrestrial box or sattelite box this info is most helpfull when trying to answer these questions step 1 you must first down load the latest firmware for the box you have if you download the wrong firmware you will corrupt the box or what they term as brick it step 2 after you have down loaded the firmware connect the box to your tv set and aerial/cable/dish these are connected with what are commonly known as F fittings step 3 scan your box you should have a manuall to explain how to do this for the box you are useing step 4 after you have completed the scan you must turn the emu on .on the box you are scanning step5 example if it is the boxT you scanned go to menu press 1570 this then opens a hidden menu on the very bottom you will see key emu left or right press on the > < to turn the emu on after you turn the emu on press exit exit back to main screen you should at this stage have everything working if not redo step 2 on again HINT if you cannot access the hidden menu then you have not installed the latest firmware you cannot access the emu without the firmware been loaded first right hopefully you have all this done and you have your channels happy viewing last hints for you BOX T access code is 1570 .. EUROVOX access code is 1969 ...DIGIVOX code is 1004 now hope this helps
on Apr 25, 2010 | Audio Players & Recorders
I have starview box and its losing stations slowly has anyone got same problem or a solution.i live in dublin south (for ntl)
When my box does this I just re-scan it..that normally works...press menu then factory setting type in 0000 then go to installation and auto re-scan (will take several mins) when done make sure the emu key is on. and you should have all your channels back.
Good luck
Gord
Ps if you need them the NTL codes are
00=B0 B8 4F 04 E6 5F 87 80
01=A3 EB EC 07 D6 49 D2 EB
To input the codes press menu then key in 1570 this will bring up another menu..enter nagravision to input the codes.
Mar 17, 2009 | StarTech.com StarView SV211K 2-port KVM...
Code problem
go to menu, and type in 1570 code, then it will say nagvision, put the code in there
Feb 17, 2009 | StarTech.com StarView SV211K 2-port KVM...
I cannot find the menu which allows me to input starview codes
press menu 1570
press ok on nagravision
letters are coloured buttons and audio and pause
Dec 22, 2008 | StarTech.com StarView SV211K 2-port KVM...
Digivox Box
tyr 1570 then turn on your nagra vision
Dec 19, 2008 | StarTech.com StarView SV431USB 4-port KVM...
The box-t
enter menu then press 1570 which takes you to a secret cas menu. then click ok on nagravision and enter your code .ps make sure emu is on . do you have the codes for c****s mmds . i only have them for cable thanks. kinvara64
Dec 18, 2008 | StarTech.com StarView SV211K 2-port KVM...
Starview 4 thebox super usb
hope this is of help to you if not let me know .
press menu.
press 1570.
look down list to make sure EMU is set to ON . press ok.
code screen service provider tab should be 5A01.
00. go to the bottom of screen and change the codes saving each code entered.
go to the 00 tab and press right to 01. go to the code tab and change codes saving each code as entered.
0.C0 F6 61 87 91 F9 67 57
1.F0 83 35 E5 28 40 49 B2
Dec 11, 2008 | StarTech.com StarView SV211K 2-port KVM...
I HAVE A DIGITAL RECIEVE CALLED THE BOX IT HAS BEEN UPDATING ALL DAY AND I CAN ONLY GET 4 CHANNELS ID THERE A CODE I CAN RESET MY BOX WITH PLZ.
the new key is cd 11 58 05 ee 96 e7 f3 you need to enter this code in the secret menu to access that press menu on the control then key in 1570 then go to nav option then your on the page it should have ntl 5401 then 00 underneath then you write it under that
Apr 04, 2008 | The Box Active Noice Cancelling Headphones
StarTech.com StarView SV211K 2-port KVM Switch Logo
154 people viewed this question
Top StarTech.com Computers & Internet Experts
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
