Question about ASUS P5LD2-VM Motherboard
I am unable to install win Xp. when trying to boot from a cd to install fresh win xp ser. 2. system reboot after copying few installation files. The Bios set up shows the Sata Hard Drive but unable to load an os
  • nas john
    nas john May 11, 2010
    can you get the same model near your are?
    it would help you to clone yours
    Scholar:
  • 87 Answers
Your HDD may be bad. I have had a number of HDD that appear fine in the BIOS but won't format either via the install disk or separately via a Linux boot disc.(You can somtimes hear them clicking on and off [seeking])
If you are mad keen on the drive, then D/L 'Hirens Boot Disc' and boot into the DOS mode (it also has a Mini XP mode).and use the HDD format utlity 'killdisk'. This will remove anything on the drive, format it and set it up ready for a fresh install.
If Hirens Boot Disk can't see the SATA drive then its stuffed.. for sure..
Posted on Jun 06, 2009
  • Nicholas Heyke Oct 24, 2009
    yep agreed its probably the hard drive. If its clicking or constantly seeking its stuffed.
    However, you may have a conflict. Check that the hard drive is set to 'master' not 'slave'. Sometimes they do not default properly and they get 'confused' and play up. Setting to 'cable select' doesn't always work.
    If you download Hirnes Boot disk it comes with a program called Hard Disk Regenerator.. run this utility for a day or so and it will fix the disk if it is not a hardware problem. It fixes disk surface problem which cause read and write failures. It may be able to recover your disk for you. I have tried this on numerous HDD and saved many that way.
    Note: I've had numerous Seagate's fail on me in the last few years and won't buy them any more.
Cant install os on this board
Try to find a copy of win XP ser pac 3 and reinstall
Dec 04, 2013 | Biostar M7nba Rev:1.2 Socket 462...
I bought a used ibm r40, changed the hard dsrive and tryed to load xp pro. after loading the system files the computer wants to reboot to finalise. After this it goes right back to fresh install start.
When you say you tried to load XP Pro, did the hard drive already have XP installed or are you installing it fresh from a CD? If you are installing it fresh from the CD and it is asking you to reboot, it seems as if you are letting it try to boot again from the CD. When it reboots and says "Press any key to boot from CD..." don't press anything, just let it boot. It should finalize the installation there!
Hope that helps!
May 23, 2011 | IBM ThinkPad R40 2722 Notebook
Laptop powers on, but windows doesnt load
Boot PC from Windows XP installation CD you will be ask to instal fresh copy or repair existing installation - go for "fresh copy" software will analyze you PC and try to find your previous copy of Win XP you will be ask again to repair copy of your existing Windows Xp now go for "Repair" option so installation software restore all Windows files and will keep all your settings*.
This solution is only temporary because IE 7 and 8 will no longer work after restoring - backup all your data and instal fresh copy of Win XP after all and always keep Your Backup up to date!!
Sep 07, 2009 | Medion (40010998)
Need to reboot my crashed computer cant get windows xp to reboot
HI how are u, ur Windows Xp is corrupted
Cause :
1. Viruses
2. Computer was not Shutdown properly
3. Some windows File Corrupted
Solution>>>>>>>1.
1. Go to Safe Mode at starting mode press F8.
2. If Computer Go to safe mode successfully>>
3. Go to start >> Programs>> Accessories>>System tools>>System restore.
4. Restore ur computer in privious date.
Solution>>>>>>>2.
1. Insert WIn xp cd in cd rom and restart it.
2. Repair Your win Xp via a Repairing utility.
Solution>>>>>>3
1. VIa a formmating utility U can install a new fresh copy of windowxs.
Thanxs
Mukesh Kumar
Mukesh_ibm@yahoo.com
May 12, 2009 | Microsoft Windows XP Professional
Install older version of windows xp professional
Hello.
First do this.....
Reboot the computer and enter bios by..
When the blue DELL™ logo appears, press <F2> immediately
You might have to try this a few times since you have to be really quick,
In system setup (bios)
Set CD Drive as first device in the boot sequence. Press F10 then chose "Y" to save.
1. Put your old XP CD in and reboot.
2. After reboot if asked if you want to start on cd chose yes.
3. start Win Xp installation from your old XP cd.
4. delete partiton 1 on your C: hard drive
5. create new partition
6. Start installation and format the c:drive
7. Follow the installation instructions,,,
Hope this helps.
Regards...
/Tech5508
Feb 16, 2009 | Dell Computers & Internet
"cant install win-xp on CQ-60"
Hello.
Hope this helps...
These are the normal steps on desktop computers but
should work in your case too with a fresh installation
1. Enter bios settings and set CD Drive as first boot device
2. After reboot if you are asked if you want to start on cd chose yes.
3. start Win Xp installation from cd.
4. delete partiton on C; drive
Feb 10, 2009 | Compaq Presario CQ60-220US PC Laptop
'ntlr missing' after restart.
I have had this problem in the past and it was a virus. I had to reformat the hard driver then renstall the windows.
Feb 07, 2009 | Gateway MX3225 Notebook
My computer will not boot up.
First, if there is no password set you may be able to simply press enter leaving it blank and continue with the repair.
Alternatively, you can reinstall WIN XP over your existing installation which will replace your windows files with fresh copies from the CD.
Jan 01, 2009 | Microsoft Windows XP Professional With...
Not able to install win Xp
CHECK THE CMOS SETUP OF YOUR MOTHERBOARD,CHECK THE CMOS BATTERY AND MOST IMPORTANT READ YOUR MOTHERBOARD MANUAL INSTRUCTIONS
Feb 04, 2008 | Asrock M810LMR Motherboard
Install win xp and erase win vista
Would like too know how to erase win vista and install win xp
Dec 29, 2007 | Microsoft Windows XP Professional With...
ASUS P5LD2-VM Motherboard Logo
316 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
