Question about Canon PIXMA MP780 All-In-One InkJet Printer
Wast ink What does waste ink near full mean.. I keep getting this mssg on my printer MP780 Cannon
    Problem Solver:
  • 6 Answers
Your MP780 printer has decided you have too much ink from the cleaning cycles in the absorbent pad inside the printer. Go to www.fixyour ownprinter.com and put "MP780 waste ink" into the search function. Follow the leads to find out how to clean the waste ink out and more important to find the code to reset the printer to get rid of the waste ink message.
Posted on Jun 01, 2009
Why was ink obserber near full
Ink Absorber is a big reservoir which fills over time every time your printer does a Printhead clean. This is a built in system of Obsolescence with Printers. However people like to keep printers long after they are considered out of date. Depending on what model of printer you have you can reset the Wast Ink Absorber counter however you do this at your own risk as eventually if the waste ink absorber is not emptied when the reset is done it will overflow and cause damage to the printer, the furnishings near where you keep the printer etc.
Oct 11, 2014 | Brother HL Office Equipment & Supplies
The wast ink absorber is almost full
the waste ink absorber is a small unit inside the printer where the waste ink goes in. it is a common problem in cannon printer. the ink absorber cannot be replaced mate so when it says full, buy a new printer because its not worth repairing it.
Jan 06, 2011 | Canon PIXMA iP90 Mobile Printer
I have a Canon PIXMA iP400 - it refers to the
My printer is still giving me great pages and pictures but I am now getting this same message about wast ink absorber being nearly full solutions please.
Nov 10, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
means that the little sponge or waste tank is full, this happens when your printer does a head clean or primes the printer heads & basicaly dumps ink.
Nov 06, 2009 | Canon PIXMA MP780 All-In-One InkJet...
The waste ink absorber is nearly full on a Cannon Pixma MP110 printer - how can I change this without resetting the printer software?
The software won't help, you need a shop to replace the absorber pads and reset the counter thru service mode.
Sep 29, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Waste Ink near full shows on screen. Won't print!
Hi ...
Cannon Pixma MP780 have an absorber and this error is related to this absorber.
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible. Press the <Stop/Reset> button to cancel the error. You will still be able to print for a short period. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset.
I would suggest that you take your printer to the nearest cannon service centre and get it repaired.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
If ink absorber is already full what should i do next?
it is not possible for you it is the problem mantainence wast tank full it mean when we print then chack cartridge is automacily clean then some ink fall under pad this pad is full ink then machine say ink absorber tank is full
you go to aservice centre only support printer canon. Thy clean wast tank and reset your printer
Jul 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Message "Waste Ink Near Full"
Waste Ink Tank Reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 30, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Where is the foam pad located so I can clean it?
Your Printer needs servicing
The waste ink pads are the pads that the print head sits on on the right of the printer. You see when the cartridge returs to its neutral position on the right of the printer the pads below it are the ones you are looking for..
You need to replace the pads and reset the printer or it still wont work..
you can also take the pads out , wast then with rubbing alcohol and put the back in the reset the printer..
HERE is the service manual that will give you step by step instructions on how to do this
http://www.nodevice.com/manual/newmans/1164257699mp750780smpdf/get13922.html
ENJOY
Dec 06, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
286 people viewed this question
old marine
old marine
