Question about Grundig G4000A FM/AM Radio
AM/SW no longer functioning - FM still works fine
I am no longer able to receive AM or SW broadcasts on my radio. It still works perfectly on the FM band, but when I switch to the other two, I only hear "clicks" as I tune the radio up and down. It does show the digital frequency readout still, but it does not show anything for signal strength on AM or SW. Is there anything I can do myself, or should I send it in for repair? I contacted one repair facility that requires a $30 deposit to look at it. Would I be better off just buying a new radio? Thanks.
  • MC Nuggit Oct 02, 2008
    I have the same issue with a different Grundig FM/AM/SW portable radio. A friend said the internal AM antenna (a small 'metal thing') had probably come loose/broken off internally. I took the case off but couldn't see anything obvious...
  • Grundig Master
  • 8,081 Answers
If it can fixed at a reasonable price, it might be better to try to have it repaired.
Hope it helps.
Posted on Nov 09, 2009
SOURCE:
2003 grand marquis radio am does not work
Does anyone broadcast AM radio any more?
If you know you have a good AM station in your area, and you can verify its frequency, and your radio can't receive it but CAN receive FM stations... then that radio just isn't going to get AM. It's probably not worth fixing.
Aug 07, 2014 | Sony CDX-GT320 FM / AM / XM Radio / Sirius...
Nothing but static on all bands
There may be interferences from electrical appliances fridges, TV. Move the radio to some other place. For AM rotate the radio to get the best signal. For FM and SW deploy the telescopic antenna. For SW you may use an external antenna. For SW, to tune in on a station you need to know the broadcast time and the frequency.
Dec 12, 2013 | Sony ICF-SW77 AM/FM/SW Radio
Why won't FM radio work on the Motorola 6310 two-way radio?
It's a two way communications radio, not a broadcast radio, hence it won't receive FM/AM broadcast radio stations.
You should not confuse the two as they work on different radio bands, most FM broadcast radios are on the 86-108MHz bands, whereas two way radios operate on the following bands:
1-86MHz, 108-174MHz, 220-520MHz & 865-920MHz
I don't know which band your radio works on, but not broadcast bands I'm sure.
The only exception to this is the smaller hand helds, which may have FM broadcast programmed, but if this is the case with yours, This issue is out of the realm of two way radio queries, as Broadcast radio is not two way radio, but one way radio, and I'm not competent enough to answer Broadcast radio issues.
Cheers, [email protected] Team
Nov 17, 2012 | Radio Communications
SW reception is very poor. Can receive no Ham operators only powerful broadcasts like Havanna. AM not bad, FM fair.
SW transmission depends on an atmospheric layer called the ionosphere. The density of ionized atoms present in the layer is dependent on the light from the sun and on solar activity. The rule of thumb is to tune in to the larger meter bands ( 49m, 41 m, 31m, 25m ) in the evening and at night and the shorter meter (31m, 25, 21, ...16, 10) bands in the day.
To tune in to a particular signal you need to know the exact frequency and the broadcast time. You can search the Internet for the frequencies of a particular radio station and the times when that station is broadcasting in direction of your region.
Apr 06, 2011 | Grundig Satellit 800 AM/FM/SW Radio
Radio does not function-will not operate at all. Is there someone who can repair Sony ICF-2010s?
I know time has passed.... I do repairs on SONY receivers. email me and we can go over the details. Rod ( [email protected] )
Mar 27, 2010 | Sony ICF-2010 AM/FM/SW Radio
My 4 year old YB P 2000 suddenly quit broadcasting AM. I took the radio apart and cleaned everything. Now only some FM stations and no SW reception. Can you help?
Look at the front case and locate reset hole. Insert cocktale stick or similar and listen for slight click. Insert new batteries, ensuring correct polarity and that there has been no leakage from old batteries on terminals. If leakage ie green/ uneven appearance, try to scrape clean with suitable implement when disconnected from mains only.
Feb 10, 2010 | Grundig Yacht Boy P2000 AM/FM/SW Radio
Grundig Satellit 800 display problem
HI,
THAT IS COMMON WITH PLL TUNERS THAT THE SLIGHTESS
TWEAK ON THE TUNING KNOB WOULD MAKE THE DISPLAY MOVE .COMMON ON DIGTAL PLL TUNERS........
Nov 20, 2008 | Grundig Satellit 800 AM/FM/SW Radio
Sony CDX-GT360S NO AM OR SHORTWAVE RECEIVE
am fm receiption not the same most likely antenna make sure the antenna wire fit tightly in radio cheers
Jan 08, 2008 | Sony XPLOD CDX-GT200 CD Player
Menu display help
might be the ribbon going out mine did the same till it eventually completely tore, had to order new calbe from pionner to repair
Jan 08, 2007 | Pioneer AVX-P7300DVD
Grundig G4000A FM/AM Radio Logo
267 people viewed this question
Top Grundig Audio Players & Recorders Experts
k24674
xxxxxx xxx
Sheldon Dedek
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
