Pentium III-Intel(r)82801AAAC'97 system updated by WindowsXP without Mother Board CD is not available after completion of the WindowsXP installation Audio controller not working.
Respected Sir, Pentium III-Intel(r)82801AAAC'97 system updated by WindowsXP without Mother Board CD is not available after completion of the WindowsXP installation Audio controller not working.
4 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Sound card not working ( no sound output ) mother board intel 810E
Go to Settings, Control Panel, Sound and Audio Devices, check "Place volume icon in the taskbar." In your Device Manager, pls verify that the drivers for your sound card are completely and correctly installed with no yellow or red markings. Likewise, verify that in your CMOS/BIOS settings, the onboard audio has been enabled. The sound driver/installer for an Intel CA810E has the filename 4035full.exe and uses a DOS component.
Should this not work, you might not have an Intel motherboard but one that just uses the Intel 810E chipset. Please post back with a more specific motherboard brand and model.
While it is true that the 810E chipset is by Intel, it does not necessarily mean that the motherboard entirely is by Intel. It could be by Asus, MSI, PCChips, ECS, Soltek or others. The sound therefore need not be the same for all versions of motherboards using the said chipset.
The Intel mb that uses this chipset carries the model CA810E or CA810 which uses Creative Sound Blaster* AudioPCI 128V audio solution or Crystal Semiconductor CS4297 AC '97 stereo audio codec;
The Asus CUWE-FX/RM, FlexATX or i810E uses the same Intel 810E chipset but different sound. Asus can and may use CMI, Crystal, Creative, ESS.
An ECS BKi810E(V7.3) uses the same Intel chipset but C-Media 8738 for sound.
An MSI MS-6188 uses the same chipset. It may have used an Avance-Realtek AC97 for sound.
Hope this be of some help/idea. Pls post back to confirm that you have an Intel CA810 version or by some other motherboard manufacturer.
Good luck and kind regards.
Posted on Nov 06, 2007
SOURCE: audio driver installation failed from mother board cd
The most common solution was this: open device manager click "system devices" disable "microsoft UAA bus driver for high definition audio" uninstall "UAA bus driver" make rescan devices (Note: Not all had this step. You may want to skip it.) D.W. install realtek driver the realtek driver includes the UAA driver too.Hope this helps.
Posted on Sep 22, 2008
SOURCE: intel-82801dbm-ich4-m-ac-97-audio-controller-driver
You can try this:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?locBasepartNum=hd-17950-2&lang=English+(US
That's the SoundMax driver that my Compaq 82801DB ICH-4 motherboard uses, DevID: 8086:24C5 Subsystem ID: 0E11-0088 REV-01
In theory, they are all the same - if it doesn't, and you are a brave soul, go to the directory in which it unzipped the driver, and edit the file SMAXWDM\W2K_XP\smwdmCH4.inf, search for pci\ven_8086&dev_24c5&subsys (and what not) and replace the values that match your card. (If you know how to get them... Everest Ultimate Edition would do the trick).
Posted on Apr 18, 2009
I could use a diagram of the mother board for a Pentium 4 2.4 Ghz processor. I picked one up second hand to replace my old processor
If your processor 2.4 Ghz HT you need socket 478 motherboard,System bus 800.without HT you need 533 FSB Motherboard.You can buy easily.Where you live? I do not know.China are available made 478 PIN mother board.
Mar 18, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Sir i have intel 865 motherboarg i have installed many time AC 97 driver but it shows error Ac 97 have not pasiing the system compatoibality plz reply what i do
Install the Drivers that are compatible with your current Operating System. If the drivers available with you are suitable for only Windows XP Operating System and you are installing them on a Windows Vista Platform in your computer then the compatibility problems will arise.If you are using a high end or a new version of the operating system download the drivers that are compatible with your Operating System.
Nov 18, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Intel pentium 4 865gv mother board sound drivers
Hi Sachin,
Please let us know which drivers you have tried, do you have the driver CD or you are downloading from some site.
Also, the motherboard model you supplied is not complete. Please check and let us know the model number.
Meanwhile, you can download the required drivers for 865 family from:http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1049&lang=eng  Select your operating system to download the required drivers.
Also, you can get the automatic graphic driver download from Intel here: http://www.intel.com/support/graphics/detect.htm
And, automatic audio driversdownload  from:http://www.intel.com/support/motherboards/desktop/detect.htm
Hope this solves your problem For more help or clarifications, please reply. Thanks.
Aug 04, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Want my audio driver intel pentium 4 865 gv micro 478
download the driver magic and install it, while running the driver magic it will ask for login, select skip option and go further, if it ask for registration or other options give negative clicks, then it will display all your driver list, and you can find the name of your display card, soundcard, ethernet card etc.,
note down the display and soundcard name... and mail.. i will help you further.. (md_ehsan_1@yahoo.co.in)
download driver magic
http://www.symplisit.com/en/drivermagic.html
Jun 17, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Sound driver failed to install from motherboard cd
Hey, you just download this latest audio driver for your intel motherboard from the
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=1704&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go!
after downloading completely, you just remove your old audio driver completely and restart your machine.
After that, install the new audio driver that you downloaded and than restart your machine.
May 16, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
No sound in computer
This board supports AC 97 ADI available at this linl: http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=889&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go!,,,,,,sodeep Try clicking the link below
. document.write("Audio: AC 97 ADI*")Audio: AC 97 ADI* (18962KB)
Mar 31, 2009 | Intel D845GEBV2 Motherboard
I dont have cd for intel pentium 4 how can sound system works
you have to install drivers(it is just like software for your devices) for this
goto this link
and select Operating System & search for your SOUND & GRAPHIC DRIVERS.
Feb 02, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
USB Driver for Intel Pentium II
I received a message from someone else who wants to know the make and model of the mother board to my P II Machine. If he cannot help me solve the problem, I shall revert to you.
Jan 13, 2009 | Intel Pentium 3 , 450 MHz Pentium III...
Audio driver problem
that means your audio driver might have been already installed if not so just download the ac 97 audio driver from internet [ search "realtek ac97 driver" in google] nd install it... that will solve the prob
Sep 02, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
