Question about Hotpoint 23 in. BFI62 Built-in Dishwasher
Dishwasher flooded dishwasher has flooded now the water wont go in to the machine ?
  • 460 Answers
These 2 things that may happen
1.- the cycle was interrumped
to find out if this was the problem let the dishwasher go full cycle with out opening.
If this won't solve the problem let do a cleaning because
sound like is plug.
http://www.youtube.com/watch?v=nr6tIO5iNSc
Wasth this helpful?
Posted on May 15, 2009
What is aquastop
I presume that when you say it wont stop running, it's the empty pump that is running. This is an anti flood protection. Water from a spill has got into the base of the machine and tripped the flood protection sensor. To cure the immediate problem, pull the machine out and tip it on it's side or back about 45 degrees and the water in the base will run out and the flood protection will reset. The real question is though, how did the water get INTO the base? Most common is that someone used household detergent instead of dishwasher powder or tabs and the foam it created worked its way into the base and then turned back to water as it settled. If this is the case, the tip sideways will be a permanent fix. If not, you will need to trace and cure the leak
Sep 23, 2015 | Bosch Dishwashers
My asko d1706 dishwasher doesnt let water in. As I
Base pan full of water means there is a water leak. So your machine has a flood detector (floater) and it prevents feeding further water into the machine to prevent the flooding. I think this is the reason. You have to fix the leak.
Just to make sure first clean the base pan water and try it. It will work until again water leaks and activate the floater (flood switch)
Sep 25, 2014 | Dishwashers
Fisher and Paykel Nautilus Dishwasher wont advance to take water in .
The problem could be with flood switch at base of dishwasher. Press the float to check if it springs back. Otherwise switch under it is faulty.
Jan 19, 2013 | Fisher and Paykel Dishwashers
How to reset the flood switch on a fisher & paykel
Hi - unfortunately my good friend it cannot be reset as one would like quite easily anyhow... water has found its way to the base of the drwaers and have activated the flooding switch - one could pull it apart to dry it - tip the water out from the base but if the leaks not repaired you will have the same problem later and will be on-going.
5 Fault Codes
Fault Code LED Display Fault Possible Causes
F1 ----#
The flood switch has been activated.
A leak has occurred in the base of the dishwasher.
Cause
 The fill valve has failed open.
 The flood switch is faulty.
 Excessive water has been added to a wash sub cycle, indicating leaking seal or siphoning.
hope this is useful tp you - let me know if you require further asspstance...
Jul 16, 2011 | Fisher and Paykel DS602 Dishwasher
Displays E1 code. water is on
Hi there Dolly, error code E1 relates to water leaking. Its the code the machine displays when the flood switch in the bottom of the machine activates. The flood switch activates when the bottom of the machine gets filled with water from a leak. I surgest you have a look underneth the machine for signs of water. I hope this helps regards Gary.
May 04, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
Washing machine wont stop filling with water even on small load it floods my floor
If you have a problem with your washeror dishwasher continuing to fillwith water after the valve has closed, then you this tip will help youunderstand why that is happening.
Here is a tip that will help you...
Washer orDishwasher Fills with Water when off
heatman101
Apr 20, 2011 | GE Washing Machines
Kenmore disposal hums, nothing jammed, everything moves freely, but wont spin. reset button stays tripped & wont catch
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You shouldNEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
Apr 03, 2010 | Kenmore 13742 / 13744 / 13749 Built-in...
No water entering the machine
be sure flood control float is in place ..under rack..check flood control switch under bottom of dishwasher...check inlet valve and timer
thumbs up
Aug 17, 2009 | Hoover 24 in. DT999 Free-Standing...
Faulty dishwasher.
several poss faults tap turned on? if so probably the unit needs to have the meter tank and feed piping cleaned out. if this is all clean then it could be either the water valve is faulty or you have a leak into the base and the unit will not fill up when it is in "flood mode". (check this out by tipping machine to the side and see if any water pours from the base).
Mar 18, 2009 | Bosch 24 in. SGS57E02 / SGS57E08 Exxcel...
Dish washer not working, lights come on but nothing happens, will not drain water that is in there either.
flooding the sink won't have anything to do with the dishwasher.unless the check valve on the dishwasher got stuck closed. Can you hear the pump come on?
Oct 29, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Hotpoint 23 in. BFI62 Built-in Dishwasher Logo
702 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
