Question about Motorola Mobility RAZR V3
My razor turns off after I push any key. I chave to restarted and than I have the same problem. My battery is fully charged. I cannot do a master reset because as soon as I click on menu it turns off. I removed the battery and it still turn off. Any idea?
    Brigadier General:
  • 7,752 Answers
The mainboard boot-up is corrupted, take the phone to a mobile center and have them fix it for you.
Posted on Feb 17, 2008
SOURCE:
Worx mower. I was mowing fine..stopped to change bag.. Wouldn't restart when pushed the key button. handle engaged and it would power move forward. Engine would not start.battery fully charged
sounds like, a valve clearance adjustment problem. starts when cold, looses some power when hot, if turned off or stops, won't restart until cold.
Aug 04, 2015 | Garden
Tip
How to extend the battery life of Razor Scooter Batteries
You can extend the life of your scooter's battery if you take proper care of it. Most people report trouble in getting more than a year or two out of their razor scooter battery set. This is actually a common problem with vehicle batteries.
  • Keep your battery charged
It is recommended to keep your battery fully charged to avoid the build-up of sulfate-ion inside it. Sulfate-ion accumulates when the battery is in a discharged state for a long time.This is the most common reason of premature depletion of lead acid batteries. This can be easily avoided if the scooter battery is kept in a constantly charged state.
  • Charge you Razor Scooter Battery during the Off-Season
Even if not used Sealed Lead Acid Batteries will self discharge over long periods. This will leave the battery in a not fully charges state which will enable the sulfate-ions to build up inside the internal plates which will slowly deplete the battery's capacity. In order to prevent that, you should charge the razor scooter battery at least once every three months when it is not in service.
  • Use a Battery Tender
Battery Tender chargers are a great way extend the life of your SLA batteries as they are designed to fully charge and maintain a battery at proper storage voltage without the damaging effects caused by trickle chargers.
References:
Battery Maintenance 101 How to Extend Battery Life of Razor Scooter...
BU 804b Sulfation and How to Prevent it
Deltran Battery Tender
on Jun 19, 2015 | Razor E100 Electric Scooter
Razor ground force battery says its fully charged but gokart wont turn on
Here is the owners manual for the future (in case you don't have one.)
http://www.meijer.com/assets/product_files/pdf/1000422_groundforce_manual.pdf
It sounds like the push button fuse next to your charging plug. Push that in and try again. Otherwise it could be a wiring defect.
Aug 19, 2012 | Razor 300001-SL Ground Force Go Kart
Razor E200 wont move until pushed to a speed
check the areas by the tires and charge battery fully. first start on a very small hill or maybe your drive way.
Aug 10, 2012 | Razor E300 Scooter
My son's ground force drifter is showing a charged battery but will not go. I see the full charge lights on the throttle but it when i depress the throttle, it does don't move. Anythought? Thanks
If the battery is gone(bad), sometimes it will show fully charged (volts are good).. but it has no amperage to "push" the voltage... It takes amperage to make the drifter move... (time for a new battery)... they don't last long...
Aug 03, 2011 | Razor USA Razor Ground Force Drifter Go...
My razor won't stay on!
try a new battery and also take the phone and have the firmware reflash on the phone to correct this problem
Sep 30, 2008 | Motorola Mobility RAZR V3
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Slowness of keys when using my razor
First thing is first: try restarting your phone. Turn it all the way off, remove the battery for about 20 seconds, then turn it back on.
If that doesn't help, then Motorola provides a factory reset function that you can try. This will delete all of your contacts, so make sure you have a way to pull them off. (If you have a Mac, and your phone has Bluetooth, try iSync.) Once you've done that, follow these steps:
  1. With the phone on and at the home screen, press the Main Menu softkey
  2. Choose Settings
  3. Choose Initial Setup
  4. Choose Master Reset (near the bottom)
  5. If you haven't changed your password yet, it will be 1234
And away you go.
Dec 05, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
111 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
