Question about Dell Computers & Internet
Primery IDE not connect - Dell Computers & Internet
    President:
  • 2,692 Answers
The ribbon cable that goes from the hard driver to the motherboard  may have come loose or disconnected.
Posted on Apr 16, 2009
How do you connect IDE device to GA-Z87X-UD4H
This particular motherboard does not provide IDE connections for external devices. The safest option would be to use an IDE expansion card that will plug into the PCI bus and provide normal IDE connections for your devices.
A quick search to google for "ide expansion card" will provide many good results.
May 11, 2014 | Gigabyte GA-Z87X-UD4H rev. 1.0 Socket H3...
My 1999 Chrysler town & country limited my engine light came on. I whent to get a test done, it said DTC Reported P0505= idle control system malfunction P0351= Ignition Coil A Primery/secondary Circuit...
-Possible causes are Faulty Idle Control System motor
- Idle Control System motor harness is open or shorted
- Idle Control System motor circuit poor electrical connection
- Faulty Powertrain or Engine Control Module
- Vaccum leaks or damaged hoses or improper routing check for vaccum leaks first if this was helpful please leave good feed back
Read more: http://engine-codes.com/p0505_chrysler.html#ixzz3Mq1J8Bho
Oct 29, 2013 | 2007 Jeep Grand Cherokee Overland
Ide to usb connector sata cable attachment
The connection should be simple where you match the connections. The long connection is for the power and the short is for data. You can't really mess up the connection but be carefull when trying to connect and not to force the connections.
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
Nov 12, 2009 | Adapters.com Serial ATA IDE Converter and...
Is motherboard kaput?
are you german tink so
i think you can not go to windos. then *********** board bios might be at wrong way
(this is not the case in 99% i say)
try bios cnfiger .
in this msasage you gat onley about ide secendary then ide primary mightr be working try set ahard to it and set the bios primery boot driver it
this dosent work neer the cmos tou well see a jumper known as cmos_JP,cmos_J put the jumper to the other way and torn on torn off put it back it where restart
this might work if not
Most dafaneetly you mather board is Kaput
Jun 09, 2009 | Mercury KVM266PM-U (KVM266PMUD1600)...
945GCT-M/1333 recognize Primary IDE Master as IDE 3 Master
Hello. Some motherboards set SATA1 as IDE primary master, for compatibility. Try connect the DVD RW to SATA2 or SATA3 Port.
Feb 26, 2009 | Computers & Internet
Dll gx280 case
first off does the motherboard have both sata and ide connections or just sata or just ide? (sata are small about maybe 1/2 inches in length and 1 mm wide and a ide connection is approx 5 inches long with about 4 inches long with over 100 pins and about 1/2 inches wide) i know that the opliplex 520 are nothing but sata so if it uses the same mobo as the 520 and you have ide then its imposible to install on your computer unless it either has a ide connection or you get a ide pci or pci-e controller card and install that onto the computer. but for the most part a ide connection needs a ide cable and a sata connection needs a sata cable.
Jan 23, 2009 | Dell (2336V) Motherboard
Connecting new hard drive
If the old one is still conected you can connect it the same way if not here is how to::
Well firstly they are 2 types IDE (large connector) and SATA (small connector)
IDE
of an ide cable has 3 jacks 1 for the main board and 2 for IDE drives
2 drive must be set to master and the other to slave
Set the drives by using the jumper on the back the instructions are written on the drives
Connect the Ide Cable and then the power and turn you system on
IF ITS SATA
connect the sata cable to both hard drive and main board
connect the power cable and your done!!
NB:: sata ports are labeled SATA 1 SATA 2 etc
IDE are LABELED IDE 1 IDE 2
Ide is a large grey cable black connector SATA is usually orange or red and small
Oct 26, 2008 | Gateway (M520HD80G) Hard Drive
Setting up a Computer to install Windows XP Professional.
Pedro -
I'll assume each of these is an IDE device, meaning each has a wide connector versus a narrow SATA connector commonly found on newer hard drives.
Your motherboard should have two IDE channels, labeled IDE 1 and IDE 2, Primary IDE and Secondary IDE, or something similar. Each IDE channel can support two devices.
For best performance between the drives, you will want to have the Hard Drive connected as Master(Drive 0) on the Primary IDE channel; The CDROM should be connected as Slave(Drive 1) on the Primary IDE channel. Connect the DVDROM as Master(Drive 0) on the Secondary IDE channel, and the ZIP Drive as Slave on the Secondary IDE channel.
When connecting the drives, make sure you set the jumpers correctly; Both the Hard Drive and the DVDROM should have their jumpers set to Master, the CDROM and Zip drives should have their jumpers set to Slave. An alternative is to set the jumpers for every drive to Cable Select(CS), allowing the physical connection of each drive to determine whether its a Master or Slave device.
*Note*
If your Hard Drive is a SATA device, connect it to the '0' or '1' SATA connector on the motherboard. Have the DVDROM set up by itsself as Master on the primary IDE channel, the CDROM as Master on the Secondary IDE channel, and the ZIP as Slave on the Secondary IDE channel.
Hope this helps!
-thinstatic
Jun 11, 2008 | ASUS P4S8X-MX Motherboard
Connection of two harddisk
One ide channel can have two devices, most pcs have two ide channels primary and secondary.
if You have 2 ide channels then you can install total of 4 ide drives into your pc.
if you have only one ide channel / connector on your motherboard then you can install only 2 ide drives into your pc.
your pc might also have sata slots for devices.
1 drive / connector.
Installing a drive is very simple.
open the pc case.
Locate a free ide cable, connect your harddrive to it and also attach the power cable. Thats it.
May 08, 2008 | Intel Motherboard
HP Pavilion dv5000 PC Notebook
i have hp dv5000 as well. and i had the same problem.
what helped me is that:
you go to start - control panel - administrative tools -
then take: device manager.
in the device manager window you click on the plus near:
IDE ATA/ATAPI controllers
right click on: primery IDE channel
and select uinstall.
at that moment you will probably feel that the computer is back to its speed. restart anyway.
it will tell you new hardwear found, click: ok to everything it will install the primery IDE chenell again.
well that worked for me...
Jan 17, 2008 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
21 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
