Question about Dell Dimension 3000 PC Desktop
Won't load windows...
It powers up but the monitor is a blank black screen. Is this the motherboard? harddrive? Everything in the tower sounds like it starts up but my screen continues to be blank.. My tower has a solid yellow light and my moniter also holds the solid yellow light like its not responding to the tower at all.... The fan is on and it sounds as tho my hard drive is working also... I'm just stuck on what i should do... I took the memory out and unplugged and replugged the hard drive same results still... What could possibly be the problem?
  • TheMadArtist Apr 16, 2009
    Ok. im going to check and see if thats the problem.. i will keep you updated if it works or not...
  • Anonymous Apr 21, 2009
    My computer wont allow me to connect t the windows web site and the printer wont work.
    Brigadier General:
  • 5,158 Answers
You video card is not working.... if you have onboard video use that until you have installed the driver for your add on video card
Posted on Apr 16, 2009
Monitor immediately goes to sleep. Tower shuts down from unplugging it.
have you tryed starting up in safe mode to see if you can get into your windows?
Apr 09, 2015 | HP Pavilion Media Center TV m8400f...
( Dell xps m1530 laptop ) Monitor blank, powers up but screen won't come on.
It ISN'T the LCD screen. Since you diagnosed with an external VGA monitor, you now know the problem is the laptop.
(When you connect an external VGA monitor to a laptop, you are bypassing the Video Cable, and LCD screen. You are connected directly to the laptop )
The basic Windows files aren't being found. The boot files. This may mean a bad Harddrive.
Do you have the Restoration CD Disk? Laptop on insert it into the optical drive tray, close the tray.
When asked choose - Repair. (Non-Destructive Installation)
If a checkdisk is done, you have bad sectors on the harddrive.
There IS a special procedure in replacing a harddrive.
[ More information on Harddrives,
http://computer.howstuffworks.com/hard-disk.htm ]
Regards,
joecoolvette
Feb 26, 2012 | Dell XPS M1530 Laptop
My computer randomly will not power on. It doesnt work more than it does work. It will power on but will not fully boot up, monitor screen is blank and mouse does not power on. Light on front of tower...
Open the cpu cabinet cover then clean motherboard and parts. Reconnect RAM memory.Pull cmos cell from motherboard for 10 minutes then put it back reconnect both connection to harddrive.Make sure motherboard is not ground with cabinet cover. Reconnect pci card if any. Let me know if you need further assistance. Thanks for using FixYa.
Sep 01, 2011 | Gateway DX4200-UB001A Desktop Computer
I buy a sony vaio pcg-f31m laptop and when i tried to format the HDD to install new windows was not accesible and i had blue screen with stop 0x000000007B or smt like it .... ! then i took it out and i...
Hi..
You nearly got it.....
Take the harddrive back out and format it on your tower,make sure it,s the right format,then place the harddrive back into the laptop and then install windows from your laptop..
Because if you install windows from your tower,your motherboard from your tower install the componants it needs to run from the windows disc,therefore it won,t run on your laptop because it,s a different motherboard...
Hope this helps...if it does please take the time to rate it,as i,ve taken the time the answer you..
Regards
Apr 02, 2011 | Sony Computers & Internet
Switch on computer tower and screen. Screen brings up LG logo and 'Activating power saving' then the screen shuts down. The tower continues to load Windows etc but I can't see a thing as the screen is...
For that when you power up the computer press F8 key then enter in safe mode then go to start menu->run type in run "chkdsk /r" without "" then restart computer then it fix errors .
If still not able to see windows then again press F8 then enter in enabler vga mode then go to display property and change screen resolution to 1024*768 then apply and ok then check.
If still same then you need windows disk boot computer with that disk.
When you power up the computer press F1 or F2 or "del" key then enter in bios then go to boot menu and set first boot device as cd/dvd rom then save settings and exit then it boot with that disk.
Follow the procedure and enter in recovery console then type "chkdsk /r" then it fix errors on harddrive then after completion restart it again boot and this time choose "repair previous windows" then it repairs it then you can use windows again.
Feb 22, 2010 | Computers & Internet
Signal out of range
If your PC is working with a different monitor then your monitor is going bad.
Mar 28, 2009 | Computers & Internet
Dell Latitude D830 with a blank start up screen.
Most likely, bad motherboard.
Cost. about $150 on ebay
This is assuming you've pulled the HDD and optical drive, tried RAM modules individually.
Mar 23, 2009 | Dell Latitude D830 Notebook
Compaq V5005us is weird. Powers on with black screen and freezes
It sounds like your Video card and/or motherboard are starting to give out or your LCD is giving way. Try plugging the laptop into an external screen and see if it still acts strangely or even displays on the external monitor.
Mar 18, 2009 | Compaq Presario 2100U Notebook
hi Lus;
What color do you have on the power button of your monitor? Check the VGA port at the back of your computer, how many VGA ports do you have? if you have 2, try the other port instead,
here is a VGA port:
http://www.google.com.ph/search?hl=en&q=VGA+port&btnG=Search&meta=
hope you see the images,
ill wait for your feedback
Jun 19, 2008 | HP Pavilion A730N (PJ510AA) PC Desktop
Green light blinking screen blank
Hi Suzee,
Is the green flashing on the tower or the monitor?
If it is flashing on the monitor, then it might be tht the monitor is not gettign signal from the tower.
To check, disconnect the monitor from the tower and check the monitor. If you get a msg on the screen like no input signal or check video cable, then 99% monitor is fine.
Check for the power supply light at the back of the tower.
Disconnect everything from the computer and then press and hold the power button on the comp for about 30 seconds.
Then connect the cables and check if it is working.
Jan 14, 2008 | Sony SDM-S73/B Monitor
Dell Dimension 3000 PC Desktop Logo
197 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
