Question about Frigidaire Refrigerators
I keep getting plastic shavings with ice dispenser. I adjusted the end thrust washer and replaced the blade on cylinder that pushes ice cubes out but no help in solution of this problem.
  • 1 more comment
  • omega60 Apr 16, 2009
    farfield,
    Need to get eyes and ears on problem--postively sure its not prior shavings of plastic. It may be the auguer part that is shaving the plastic off the bottom before it was the blade that had execessive play. However at the end where the thrust bearing is located there is alot of play--that is the hole is not perfectly round but rather oblong and yes I replaced the end cap and measured it and it was the same dimensions as previous cap. It oblong hole the thrust washer fits in allows the auguer to travel vertically along its axis thus it must be causing the auger to scrap at the bottom of the ice container producing the plastic shavings. I still don't know how to resolve this unless I purchase another auguer. What do you think?
    Perhaps if I disassemble it again and lay a straight edge along the horizon axis of auger I may find a bent auguer--don't know until I try it.
    thanks
    Good idea. Thanks! I'll try that.
  • Farley Redfield
    Farley Redfield May 11, 2010
    You have to be eyes and ears on this problem. Find where the Plastic is getting shaved off from. This will tell you what to look at. You will probably see why its coming off when you see where its coming from.
    Sounds like you had a great idea at first. Are you sure the plastic your getting now is fresh? Could it have been left behind from previous scraping?
    Guru:
  • 462 Answers
Yes you are onto it. Take the auger out and roll it on a flat surface noting the center axis. If it wobbles its bent.
Posted on Apr 16, 2009
Getting shaved ice instead of cubes
Several possibilities, but check first for cubes that are too small (means too little water is coming in during ice maker fill) and those cubes fracture into smaller bits when they are dispensed.
Another possibility is the cube/crushed plate inside the dispenser is stuck. This is a curved plastic piece that lies next to the crusher blades inside the dispenser head of the ice storage bin. For cubes this place must be retracted (swing away from) the crushed fingers to allow the cubes to pass without being broken up.
Oct 30, 2016 | Refrigerators
Dispenses crushed ice only, not cubed
remove the dispenser bucket where the ice drops into inside the freezer and get a Tupper ware bowl,remove the bucket and dump this ice into the bowl,then rinse with the dispenser bucket with warm tap water to melt any ice on each end of this ice maker,then wipe dry and replace into freezer where you removed it to get cold again and leave empty till the next harvest of ice,this can be normal on some units after so many weeks,as it will not let the blades retract so as just to dispense only cubes,once bucket is cleaned of ice jams the solenoid and blades will again retract for cubes only
Feb 10, 2013 | Refrigerators
My samsung rfg297aa dispenses crushed ice whether its set on crushed or cubed. why will it no longer dispense cubes?
This answer probably comes too late for you (you posted the question 9 months ago), but I want to record it here for posterity, since I had the same problem, and searching on Google for it brought up your question.
Anyway, I managed to fix this very problem by removing an ice cube that was wedged in the ice dispensing mechanism. The way this unit works is that it pushes the ice cubes through the mechanism, which always rotates the "crushing blades". When you select "cubed" ice, a lever opens up the exit chute wider, which causes the blades to simply push out the ice cubes as they pass through. When you select "crushed" ice, the lever closes the "exit" for the ice cubes to be narrower, so that the ice cubes can't be pushed through by the blades, and instead get crushed by them. I had an ice cube wedged in there that had the same effect of closing the exit to be narrower. Removing it fixed the problem.
You might want to collect all the ice cubes that have accumulated in the ice bucket in a container, empty the ice bucket, clean out the mechanism from any obstructions, and then put the ice cubes back into the ice bucket.
Feb 16, 2011 | Samsung RFG297AA (285 cu ft) Bottom...
Ice cube dispenser will only deliver crushed ice
Remove the ice bin, and in the back of the freezer you'll see a square opening with a white plastic piece inside. When you dispense cubed ice this piece lifts up, lifting the long metal rod that runs along the bottom of the ice bin. When that rod lifts it opens the ice flap at the front of bin, allowing cubes to be dispensed. If the flap is not open, the cubes will be ground against the cutters and you will get crushed ice.
Here's what you can do to make it so that you always get cubed ice. Take a wine cork and stand it on end. Using a good knife, I positioned the blade about 1/3 of the diameter from the edge and cut all the way through the length of the cork. Then remove the ice tray.
Now put your finger in the sqaure opening and lift up the white pastic piece. Slide the modified cork under the flap so that it is jammed into the raised position. (This is the position it should be in when you are asking for cubed ice.) Now slide the ice tray back in while using your left hand to push the plastic ice flap at the front of the tray to the left side (again, the position it should be in for delivering cubed ice). Peer under the tray while you're slowly sliding it back in so that you can see if the metal rod connected to that ice flap successfully slides into the square opening at the back. If it can't slide in above the cork-raised plastic piece, you may need to pull the cork back out and trim a little more off it.
This worked for me... I can't get crushed ice anymore, but I've only needed crushed ice once in the 16 months I've lived here so that's not an issue for me.
Apr 02, 2010 | GE GSS20IEP Side by Side Refrigerator
Ice cube are not dipensed only crushed ice
I had the same problem you do - the solenoid that lifts that white plastic piece is dead. But I also rent the place where I live, and it comes with the fridge. It's not likely the landlord will want to deal with this issue since I can still get ice, not considered a necessity, etc. So here's what I did to make it so that I always get cubed ice.
I can only get crushed ice, no cubes
This solution will work if you want to avoid replacing the solenoid and are willing to settle for alawys having cubed ice.
Jul 06, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
In door water and ice cube not working
Water dispenser is a simple touch switch in door energizing a solenoid water valve behind ventilation grate above refrigerator. Water tube runs down into and ends at ice dispenser chute. Should hear solenoid click at top of fridge when activate water touch switch. Can unhook discharge side of solenoid valve temporarily to prove water output. If water dispenser tube acts blocked it could be frozen where it ends-look up the hole at the bottom of refrigerator control buttons.
Ice maker is totally different system. No clicking when push ice button but ice in bulk tray may mean the simplest of malfunctions: Ice bin not pushed in the last half inch if ice auger not lined up with drive pegs. There are hidden switches behind ice bin that need to be engaged or nothing will happen in the ice maker: no auger noise, no clicking, no new ice making. Ice bin will be flush with sheet metal if it is in the right spot. Also plastic juice rack won't hang properly if ice bin not pushed in all the way.
Dec 19, 2008 | Sub-Zero 690 Side by Side Refrigerator
GE Freezer Side Ice Dispenser
It isn't supposed to free wheel and the only solution that I know of is tumbler replacement. I have the same issue and am currently hunting replacement parts.
Jun 16, 2008 | Refrigerators
Problems with ice maker
Bsbbj,
If the cubes are fusing together (such as when you overfill an ice tray), your solution could be as simple as adjusting the fill volume (there should be an adjustment under the front plastic cover, and the cover should just pop off and snap back on unless you see screws attaching it) and when your ice maker was replaced this probably wasn't calibrated correctly. Your mention of the side of the maker bulging also leads me to believe the water is overflowing and freezing within the dispenser (causing it to bulge and not dispense).
I hope this helps and Good luck.
Mar 16, 2008 | Frigidaire FRS3R5EMB Side by Side...
Icemaker problem crushed only not cubes
Whenever the ice tray is removed, you need to reposition the cube/crush selector rod that is attached to the bottom of the ice tray. This rod swivels: down position for crushed, up position for cube. At the back of the freezer, there is an opening to which this rod inserts. It houses the solenoid for cube/crushed operation. For cube position, the horizontal plastic piece is slightly above the center of the opening. Slide out the tray until the rod is past the solenoid. Pry the solenoid down as far as it can go. It is spring loaded and will not break. (If it doesn't feel like it is spring loaded, stop here and call a repair tech.) Now swivel the rod on the tray up and slide back in making sure the end of the rod is ABOVE the solenoid. DONE!!! Now you have cube ice. Good Luck.
Nov 02, 2006 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
550 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
