Question about Cell Phones
Hello! Concerned Skype Dualphone 3088.3, I get a continual BUSY signal when pressing the green button intending to make a call. Any ideas why, please? John.
  • jcol2 Apr 17, 2009
    Hello. Thanks for your help so far. I have tried the suggestions you made, but the fault is still there. The handset appears to work OK - for example for an incoming skype call. I can also call out from my contacts list. But the problem occurs when I want to make an ordinary call out. When I press the green button, up comes the "Call in Progress" message and the busy tone sounds.
  • jcol2 Apr 18, 2009
    Hello Again,
    Thanks for your suggestions - the problem is still there when I change the Privacy settings to 'anyone'. But I do not understand what you mean by 'VM setting'. Please explain what this is - I have searched the User manual!! Once you have explained this, I'll change it too, and try again.
    John.
  • 90 Answers
U need a cleaning service for your mobile switch panels. Just go to any mobile service persons and ask them to clean the bottom of panels..there may be some shortings with ur panel board. it wont cost u much..ok
Posted on Apr 18, 2009
  • 526 Answers
Hi jcol2
First, check to see if you have the latest version of skype.
but try this.
First check privacy settings are set to anyone, see what happens.
Then, try changing both privacy settings and VM settings to anything, exit out of the program and try running skype again in a few minutes.
let me know what happens.
Posted on Apr 17, 2009
  • adi Apr 27, 2009
    do you still need help?
  • adi Apr 27, 2009
    what version is your skype?
  • Cell Phones Master
  • 19,396 Answers
If this is sharing landlines with an house phone, try unplugging the pother phone.
Test the phone on a different socket.
Try removing batteries(if and unplugging adapter to reset the skype phone.
Try removing broadband filter. If it was the broadband filter , then replace it.
If you are using a phone extension, test without extension.
If the above still did not fix the problem, get the phone replaced, there should be a phone number listed on phone documentation that you can call when the phone is faulty.
Posted on Apr 16, 2009
  • Ginko
    Ginko Apr 17, 2009
    It is important that you alreadi tried removing handset battery.
    If that did not work try a firmware update:
    try a firmware update from the phones advanced features.
    Press top left arrow key
    Select settings
    Select advanced
    Select firmware update
    Select current firmware - if not ver 233 11.19.2007, rel 6 then do an update
    If still no luck , then a bad phone line in your house can allow the skype phone use, but not the landlines, check this out with phone company, after calling the support number listed on dualphone documentation.
Dualphone will not connect to skype
Why can't I sign in to skype
Jul 26, 2012 | RTX DUALphone 3088
The person i am calling cannot hear me dualphone 3088
I downgraded the firmware to a version back and then upgraded back to latest and it worked for me.
Jun 18, 2012 | RTX DUALphone 3088 for Skype
Hi, I buy two phones 3088, and in both, time to
There are a few things that cause what you describe:1. The landline is having problems and your phone is trying to alert you so that you know not to use it2. The internet connection is having problems,3. You have voice mail or other notifications that wait your attention.To avoid any issues you should update the firmware on both devices.
Have a nice day!Vlad
Dec 24, 2011 | RTX DUALphone 3088 for Skype
MY DUALPHONE IS REG. WITH BASE STATION WHEN COMEING TO SIGN IN PART IT WONT RECONISE MY SKYPE NAME OR PASSWORD WHICH IS RIGHT PERFECTLY JUST KEEPS SEARCHING ONLY SAYS SIGNING IN TILL I STOP IT
Hi
I had the same problem when i first installed this, I found that username and password have to ONLY contain lowercase characters or it wont register or login to skype correctly
I hope this helps
Mar 07, 2011 | RTX DUALphone 3088
The microphone of my dualphone 3088 is working properly with the land line but not at all with skype.
You have to change te properties of microfone and speaker in the Skype to the phone.
Go to tools->options, enter audio settings and define your phone for mic and speaker.
Nov 13, 2010 | RTX DUALphone 3088
Dualphone 3088 is completely black. \r\nchanged
The Dualphone 3088 LCD screen has a terrible habit of coming loose from the ribbon connector socket on the main board. If you take the phone apart, carefully remove the LCD screen from the plastic surround it is in and you will see the ribbon and its board connector. The small clipson either side of the connector have a habit of coming loose, freeing the LCD screen. Carefully put the ribbon cable from the LCD screen back into the connector, you will need to press both clips on the connector at the same time to lock it in place. (yes its fiddly and I have to do it all the damn time)
Jun 14, 2010 | RTX DUALphone 3088
No ring tone on RTX Dualphone 3088 handset. All settings same as second phone which works.
there must be problem with the loud speaker or ringing speaker of the phone.take it to product care center
Mar 31, 2010 | RTX DUALphone 3088
I cannot sign in to skype with my dualphone 3088
I have a skype dualphone 3088 and I cannot sign in.
Nov 17, 2009 | RTX DUALphone 3088
The phone can not sign in
I had excatly the same problems and therefore I called the Dualphone hotline. A very helpful person send me this code, which I used and after 2 days with many frustrations this solved all problems within 30 minutes:
"Dear Sir, madam,
Thank you for contacting dual phone Support.
"Press menu followed by 1 – 3 – 9 – 7 – 5. You will prompt to one pageFWU configuration and select Beta firmware. Install the 0247 beta firmware."
Best regards,
Dualphone support"
Hope it can someone
Stein
Aug 03, 2008 | RTX DUALphone 3088
Cell Phones Logo
144 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
