Hoover U8171-900 / U8172-900 / U8173-900 / U8174-900 Savvy Bagless Upright Vacuum Logo
Posted on Sep 15, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Help hi there. i have a hoover savvy u8172-900 vaccum. the hose has great suction, but there is limited suction on the main unit and the brush does not spin when i try to use the product. we have cleared the brush of any debris and have also installed a new bag. a few days ago, we disconnected the hose to make sure there was not any foreign bodies stuck in the unit...nothing seems to help. any advise?
  • andi4fsu Sep 22, 2007
    Hello and thanks for replying. i was able to solve the problem before i got your post. i took the foot plate off and noticed that the belt was broken. when we went to replace it, we could not get the drive shaft off, so we took it to a vacuum repair shop and they fixed it for us. thanks for the info!
  • Delyse Nov 18, 2007
    The vaccum has fine suction with the hose and on the smooth floor setting but on the carpet setting, the brush will not rotate when the vaccum is pushed forward (only rotates when it is being pulled). We checked the belt and it is fine. We tried different hight settings and also cleaned the brush off, but it still is not working. Any Ideas? Thanks
Anonymous
Level 2:
  • Expert 209 Answers
  • Posted on Sep 19, 2007
Anonymous
Expert
Level 2:
Answers
209
Questions
Helped
119579
Points
570
As the hose fits into the base (if i am correct) the power at the base should be fine, make sure the base is clean and free from blockage, you say the brush doesn't spin, has the belt broken, if so replace it, (very cheap) and only a couple of screws to undo, the roller not rotating will effect the power of suction dramatically, start from there and see how you go if i have helped please rate me
Beater brush stuck on (keeps turning) in upright position and no hose suction with Hoover U5753-900 WindTunnel Bagless Upright Vacuum. I have tried adjusting the brush level up and down and moving the...
HI, it's Jim from Crucial Vacuum!
Your Hoover may be losing suction in the hose and having an issue with the brush roll due to a clog within the vacuum, or possible debris stuck on the brush roll itself. Here's some tips that will help.
First off, if your brush roll just keeps turning be sure to turn off your vacuum before examining it. In regards to the lack of suction in the hose there may be a clog in the vacuum itself.
After every use, make sure to empty your unit's dust cup. Allowing for fine dust and debris to rest in your unit's dust cup for a long period may cause your unit to become clogged, which leads to poor or even no suction, for the hose as well.
It is recommended to wash and clean your unit's filter weekly. To do so, empty your filter screen outdoors to take off any excess debris and then clean under running water until the water comes out clean. Allow the filter screen to fully dry before inserting it back into the unit. This may take up to several hours. Be sure to allow it to FULLY dry.
Lets look at the hose itself. Stretch the hose out entirely to see if there are any clogs within. A handy way to unclog your hose is to use a broom handle or coat hanger. Make sure the coat hanger is a plastic one. You don't want to tear the walls of your hose.
As for the brush roll itself. Is the belt intact? After usage the belt will stretch out and lessen the tension on the brush roll. This could be causing the brush roll to have a lack of resistance against it. You want to be sure the belt is on there nice and tight. Also, manually spin the brush roll to see if there are any clogs or debris stuck within.
You can purchase replacement parts for your Hoover direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=hoover+windtunnel&limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Dec 14, 2014 • Vacuums
1helpful
Hi my Dyson dc43 has no suction when using the stick and attachments. It will have suction for about 1 second when I turn on the Vaccum but that's it. It works fine when using the the full function mode....
Hi there my be a blockage at the bottom of the suction pipe. turn the hoover over so its laid flat ,You.ll be able to see were the pipe ends theres a piece plastic which you can press in ,push the clip in and it unclip pull out the plastic unit check for blockages you,ll also be able to see the brush bar.
Nov 02, 2014 • Vacuums
My Hoover brush spins, but doesn't have very strong suction. I've checked the filter, tubes, but it seems as though something is stuck inside. Can you tell me how to check behind the roller to...
To get the roller out.Turn the machine upside down.You will see some screws.Remove them.That allows you to remove that plate.The roller will just lift out.Some have a cap on it and can fit tight.On the back of the machine are two more screws that hold the hose on.You can take the hose off there ,if you have not already.Running a straightened out wire hanger through the hose will insure that there is not a clog you may be missing.As it is a few years,replace the belt while you have the roller out.It is on one end of the roller and the other end slips on a small wheel.It is easy to do and may improve the over all performance of the vacuum.
4helpful
Brush spin,good suction at hose, no suction at
Air passage from back of brush head, through the joint, and up to bag, may be blocked.
1helpful
Panasonic MC-E468 vacuum cleaner loss of suction
HI If the cleaner is loosing suction make sure to check all inspection tubes and the dirt channel hoses after the spinning brush. Also check the main hose for any clogging. One of the worst faults of this model is clogging hoses. Hope that helps you.
Hoover Savvy has limited suction when cleaning the floor and carpet
With the unit standing upright, double check the clear plastic air passages on the sides of the vacumn to see if they are clogged.
Vaccum Cleaner
you probably broke the belt so check that. if the mains cord is damaged, you should replace it
When the vaccum is running the motor gets hot & smells & is very noisy.
Sounds like yu may have a clog, either in the inlet by the brush roll, or the hose. If the hose comes loose, see if there is suction there. If no suction then it is clogged. If suction, then the inlet maybe clogged.
Hoover savvy no suction on carpet setting
Check to make sure you hear the vac. motor is running when in that position. The switch in the handle could be bad if it is not.
Top Hoover Vacuums Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
