Question about HP Computers & Internet
Sumivision universal laptop charger causing mouse problem???
I think I'm having a problem with my sumivision universal laptop charger. It gets extremely hot whilst I am using it, and has recently started making a small buzzing noise.  Furthermore, I have been having problems with my laptop gouchpad mouse.  I have spoken to technitians from HP and they have advised me on everything to to try to repair the mouse.  Anyway, none of it made a difference.  The only thing I have noticed is that when I unplug my charger, the mousepad works fine.  When the charger is plugged in, the touchpad does not respond.  I am using the charger on 18.5V, the same as the original charger for this HP G6000 laptop. Anyway, any help would be great... I am writing a thesis and majorly worried that I'm going to lose all my work if I don't sort this charger out soon.
  • HP Master
  • 20,706 Answers
So what does work right? matters, to any tech.
and that heat means. is.... for sure..
1: it's bad.
2: its the wrong one and is overloaded
and OLD vista PC LT. cira 2007 old. at the end of the 10 year product support.
might i guess the original is bad and thus the cloned powerpack used?
get the correct line power pack
HPG6000
most hp have many differnent power levels
matching CPU and GPU power needs.
so only one pack works or get the high powered one.
see this tag those numbers have meaning
if you dont post them we can NOT match the correct parts
ever. this is not yours, its just one of 10000.
Sumivision universal laptop charger causing mouse  - tag1-2jdpwl5rzy0jli2jzniw3f4h-5-0.jpg most are 65watts, I looked at 8 of the many.
see this below is the huge list of g6000 models
and not all use the same power pack wattages
sorry they dont, next time post that tag data.
why not look your self? 19vdc and correct wattage or more.
https://parts.hp.com/hpparts/Search_PS_Result.aspx?mscssid=CD18FB69F6974069982D243208856352
Posted on Mar 17, 2017
  • Anonymous Mar 17, 2017
    the voltage on the pack
    is only correct, when wattage is NOT EXCEEDED
    OHM's laws. in force every day.
    if you overload it, the voltage drops!
    and something fails. it can be the mouse
    or any thing, in the PC.
    if you used a voltmeter you'd of seen that
    illegall low voltage.
SOURCE: Touchpad Not Working
http://www.motherboardpoint.com/t138781-vaio-touchpad-drivers.html
Posted on Oct 08, 2007
SOURCE: Mouse doesn't move
Well in case of opto-mechanical mouse all u hav to do is open d mouse and just clean d rollers(as d ball moves d rollers also move and that decide d X-Y coefficients) which are clogged with sticky dirt n dust.
In case of optical mouse it's d crystal which is most vulnerable to failure,so after detailed tests procedures change d faulty component,u might require professional guidance.
Also cleaning d lens below the LED will help.
Repairs of optical Mouse is not worth it,considering d obsolute nature of electronic circuits,and d rapid fall n d prices,replacing is d only option for an optical mouse
Posted on May 31, 2008
SOURCE: touchpad/mouse problem
Same thing here, I can not find out how to diable the touch paid. I spent an hour chatting on-line with Dell Tech support and they did nothing to help!! I am starting to think it can not be done on this machine. Please someone tell use how to do this?
Posted on Sep 05, 2008
  • 14 Answers
SOURCE: Disabling the touchpad on HP 530
Go into your windows device manager.
Search for your touchpad (should call synaptics input device)
give it a right click and disable the device.
I rather think that your mainboard is having problems, tried a bios upgrade and the latest drivers yet?
Posted on Dec 12, 2008
those laptops have a button just over the touchpad if the light in it is orange/redish its of if its blue its turned on if the touch pad doesent work while its a blue ligt it may be some thing wrong with it.
Posted on Jan 02, 2009
The cursor will not move I think I have locked the touch pad by mistake
Use a temporary external USB mouse, Click Start button from your laptop. Type "mouse" in Search Program & Files, click mouse under control panel. click Hardware tab,click properties, click change settings, click driver tab, check if the device is enable or click update diver or rollback driver if necessary.
Aug 25, 2014 | Fujitsu Siemens ESPRIMO MOBILE V5535...
Persario/HP charger scam
Remove the battery before you plug in the charger/adapter and see what it will do. It can't recognize a battery mode if there is no battery. Maybe the charger you are using is not appropriate: different voltage, wrong polarity, the tip is not in contact with the plug terminals, or the circuit is not closed to allow the passage of current.
Rocketfish, Targus , and a few others, manufacture universal chargers that work with may laptop makes and models.
Mar 30, 2014 | HP Compaq Presario CQ60-249US Notebook
Computer wont charge with universal charger
Please check the technical specifications of your computer charger and see that your universal charger fulfills the same. Generally it is found that the universal charge may supply the required voltage but may not provide the required amperage. That is the reason most of the electronic companies insist on their chargers. If your charger is not working please get one from the company rather than using the universal charger and the spoiling your computer. Universal chargers are OK for some of the electronic devices which do not require higher currents.
Dec 27, 2010 | Dell Inspiron 1525 Laptop
I lost my charger and bought a new universal charger now my notebook charges and goes on but after a few minutes it switches off, what could be a problem?
wrong spec of universal charger,check connector plugs (if you have them) are corect way round ,will cause seriouse damage if you cannot define correct set up(look for marks on the side of plastic adapters) and the polarity is correct
Sep 06, 2010 | HP Compaq Business NX9110 Notebook
When playing certain movie files on my sumivision micro adapter the voice goes out of sync ,pausing brings it back but after a while goes out of sync again,is ther a updated firmware to stop this and if so...
i think you should get the necessary codec for those files since not all the file behave that way. you can get this codec from the link below:
pls rate me. thanks
http://www.free-codecs.com/Combined_Community_Codec_Pack_download.htm
Jan 22, 2010 | Computers & Internet
Advent laptop, been on holiday for a week, it has not been used in that time. It won't power up with the charger plugged in or not, the power lights are also off. Charger is broke but pc world techguys...
Well, if the chargers don't work that leaves a problem with the power connector on the motherboard. If the socket was or is loose it could be causing a short on the board. The cost of the motherboard will most likely rule out any thought of replacing that. If you have a working charger try removing the battery and with the power disconnected hold the power button down for 60 sec. Then plug the charger in and try to turn the PC on. I've seen this work before and it makes no sense that it does but you can try it. The only other problem I can think of that might cause this symptom if the lid cutoff switch is stuck in the down position and over riding the power switch.
Oct 12, 2009 | Advent Netbook
I need a charger for eMachines D620 laptop
I buy all my chargers on Ebay at a store called Monster Parts. These chargers have extra long cables and good warrarties, all for under 40 bucks. Most chargers are 25-25 bucks.
Oct 12, 2009 | Computers & Internet
Replacement AC Adapter causes touchpad problems
OK here is the problem your laptop use a certain amount of power to is parts to operate too much power from the adapter causes glitches where as the mouse pad would freak and stuff or certain keys not functioning so you have to look at the old acer adapter u have and make sure it has the same amount of MA = mili ampage to the universal one your thinking of purchasing also the same amount of imput and output voltage and if not too certain carry your laptop to the store and try the one that they have
Sep 11, 2008 | Acer Aspire 5100 Notebook
Touchpad problem =[
the only possible reason that i can think of is that ur AC adapter is not the correct adapter for ur computer, if its not the correct charger contact dell.com and u can get the original charger for you laptop for under 60 dollars.
Feb 11, 2008 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
225 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
